Posts posted by GioMun
Ciao Shipmates!
So, i finally finished the planking. It´s still raw, still have to do some sanding, polishing, etc., but you can see the idea how it goes.
I decided to do not nail it, since the hull it´s going to be dyed in black, and anything of it would be visible. I will let that to the deck planking.
I´m not very happy with the result, there are some mistakes wich i wish they weren´t there, but they are! Some of them i just found them with the macro of the camera. They are barely visible for the naked eye. So, a lot to do better next time.
I hope you like it and thank you for your comments of course.
Also, i made the rudder and modified the head of the stempost, in order to make the space for the bowsprit.
Photos:
As i said, a lot to be sanded, polsihed and corrected!
I will post some picutres or the finished plank after this operations are done, and then.... Chapter 4!
Thank you for your interest.
Greetings
Giorgio
- Rik Thistle, Keith Black, ccoyle and 2 others
2
3
Hello @Dziadeczek, very interesting the video and the method shown.
Do you have any more infomration about the next picture, i mean the marking tool in the picture following the video.
Is there a way to build it or find it?
Thank you!!
Greeting.
Giorgio
Hi shipmates!
I started the planking. First i marked 4 rows, then divided them in to 3, in order to achieve the best number of planks. This done following, not precisley, the David Antscherl practicum.
As for the plans of the Luisito, i know that the plans we are using (i say we for all the modelers that are building it), are from of course a survey done, i mean a ¨as built¨ set of plans.
Of course Piedrabuena didn´t have any drawings available with him. He later said that he managed to remember the lines from his studies. This set of plans is signed by an architect who happens to be a shipmodeler too, maybe he maneged to draw this set after that survey. You can search in the web Arq. Carlos Rando Ferrer. He is an argentinian architect, teacher and shipmodeler.
The bullwarks are planked too, using 3 rows of planks in each side.
This wood i´m using is very easy to bend, so no big difficulties so far. For caulking i´m using black glue (school grade), once sanded down it leaves a fine line between planks. So, lets go to the pictures.
Chapter 3 - Planking, calulking and nailing.
Thank you all for all the likes, the comments, and the views.
See you next time!!
Greetings.
Giorgio
- Javelin, Keith Black, wefalck and 4 others
7
Hello. I´d like to share my new project.
It is about a little cutter, wich was built after a wreack of another bigger ship, in order to go back to civilization. A model and a surviving tale.
Chapter 1. Introduction and History
Luis Piedrabuena (August 24, 1833 – August 10, 1883) was an Argentine sailor whose actions in southern Argentina consolidated national sovereignty at a time when these lands were virtually uninhabited and lacked state protection. His biographers consider him one of Patagonia's greatest heroes. Piedrabuena rose to the rank of Naval Lieutenant Colonel, equivalent to Commander. Today, he is commonly known as Commander.
When his brig, Espora sank in March 1873 on Año Nuevo Island, and the possibility of salvaging the ship was ruled out, Luis Piedra Buena, its commander and owner, decided to build a boat to escape the difficult situation he and the crew members of the sunken vessel found themselves in.
It is still unclear whether the cutter was armed with timbers from the Espora or with the trees on the island, which was very close to the wreck, an ideal forest for using in the construction of the boat. The original type of Wood used, was ¨lenga¨, (Nocthofagus pumilio). The work was carried out by him and one or two crew members; the others were ill or simply uncooperative, which makes this feat even more impressive, not only because of his effort, but also because it was not based on any plans. He used his memory and knowledge of what was teached to him by Capt. William Horton Smiley, a whaler who was a friend of his father, and gave him the chance of learning sailing skills, and ship construction, and also, remembered the forms of chilean launches tipycal of the Patagonia, wich are very similar to Luisito.
In just over two months of work, he built the cutter Luisito, amidst storms and southerly winds. He named the cutter "Luisito" in honor of his deceased first son, who bore that name. Once the ship was completed, he left Isla de los Estados and arrived a few days later in Punta Arenas (actual Chile).
Once the cutter was launched and ready, it set sail to Punta Arenas, arriving after 11 days of sailing in May. After a stay of several months, amidst the southern winter, it sailed from the Isla de los Estados, and during that voyage, in August, it rescued the six shipwrecked people from the English brig Eagle, who were half-dead from hunger and cold on a rock. It led the rescued shipwrecked people to Punta Arenas and rescued them again, this time those from the German ship Dr. Hansen, whom it brought back to Punta Arenas.
Piedra Buena continued to travel along the southern coast with the Luisito.
In 1875, Piedra Buena had to travel to Buenos Aires, where Congressman Dr. Félix Frías needed his knowledge of the south to apply it to the border issues with Chile. In order to raise the necessary funds for the voyage, Piedra Buena decided to sell the Luisito, a sale that would be finalized in early 1876.
Ship Information
Length: 10.66 m
Draft: 1.52 m
Average Draft: 1.40 m
Displacement: 14 tons
Full deck, with a hatch at the Stern, and a storage locker at the bow.
One mast, with a trapezoidal sail, jib, and staysail.
Tiller.
Wales around the hull.
Chapter 2. Early stages of the model
So, the model is built in 1/48 scale, POB, in brazilian pine mostly, (araucaria angustifolia), and some parts in rauli (nothofagus Alpina).
I had the structure laser cut, for more precision, a practice that i will incorporate in my models from now on.
The model construction started with the assambly of the structure, and the bulding of a slipway, as usual.
After stat stage, i made some fillig between stations, in order to give the model more strength and a surface to do the planking and nailing.
Next, installed the keel, sternpost and stem, and of course set up the wales. First i had to build the transom, in order to correctly install the wales.
So that is all by now. See you in chapter 3, with planking.
Greetings.
Giorgio
Hello shipmates.
So, this is as far as i could get by now. As you can see, i imported the shiplines from AutoCAD, and y pasted every station on the side view,
but i still can´t create the surfaces, unless the wales, wich i could manage to.
I keep the fight!! I don´t know every time i try to generate the skin of the hull a problem pops up.
If any of you had experienced the same situation please tell me.
Thank you very much.
Greetings
Thank you for the kind replies.
I´m collecting your advices in order to find a way to go on.
In the moment i am searching for tutorials, specially the ones focused on ships.
Giorgio
Thank you for the answer.
Yes, that is what i´m trying to do right now. I´m looking at every YouTube tutorial i can find.
I know that is the way!
I was asking if there where any more specialized tutorial out there.
Thank you.
Hello!
I´m quite new in this section, so please be patient. 😌
I´m at the moment trying to start the art of 3d modeling our models in Rhino. Just as a form to understand the models that sometimes don´t have a good plan/drawing, and you have to take care of that (i hope you understand).
The problem is that i don´t know how to start. I have found a few tutorials on the web, but i´m having problems with generating surfaces ,curves, so, i´m still at the beginning!!
I see those pencil-like drawings that some of you make and i hope to achieve that some day! It reminds me when i started on this hobby at all.
My question is that is there any tutorial, made for shipmodelers, that would allow, eventually to achieve those drawings i was talking about?
Thank you very much!!
Greetings.
Giorgio
Hello mates!
So, finally the ship is ready to set sails! It's been a pleasure for me to build this model. A very nice model to build, specially for the details and the sails. A lot to improve, for the next builds of course, but i think this is the path.
I decided to show a painting of the time, that i took from the Chapelle book, The Baltimore Clipper, ther is a chapter that mentions the Virginia pilot boats.
Another thing i wanted to show is the H flag, that as you may know is the international flag for "I have a pilot on board", so i took Jack, made him a bit of a deck, planked, and added the flag.
So, i hope you liked it. Thank you for all the likes and comments.
See you next time!!!
Have a good modeling!
Greetings.
- GrandpaPhil, Keith Black, ccoyle and 1 other
4
Hello shipmates!
So, after all this time, i almost completed the project. The model itself is ready. Just a little more work on the wooden case and its done.
All riging, standing and running, its done, it's been a logn trip, a hard one, because i had to research a lot, thank you @Tim Holt for the help you gave me in this area. And to all the rest of the crew for the comments and likes.
So, here are the pictures. I hope you like them. You will find, as usual, lots of mistakes, and things that could be better done. So keeping that in mind, i hope you enjoy them.
See you next time!!
Greetings.
Giorgio
- Cathead, GrandpaPhil, mtaylor and 6 others
9
Outstanding Karl, as usual.
Wunderbar!!
Please keep coming more photos!!
Greetings.
Giorgio
- Keith Black, mtaylor and Jeronimo
3
Hi Kortes.
Your carvings are beautifull and very nice. I like the carvings, and the resault is even better than cnc.
And more satisfying than having a computer made product.
Your model is very beautifull and a pleasure to watch.
Keep the good work.
Greetings.
Giorgio
Hi mates.
Little progress here. I made the sails, and already started their setting. For the sails, i followed the Olha Batchvarov's tutorial for sailmaking. I suppose you know it, but just in case, i give you the link.
The result is not the same obviusly, but i made it.
So, here it goes:
Sails, fore sail, has the inscription, Swift of Norfolk on it:
The fisrt sails getting set.
Some close up views of the rigging in progress.
In the next post i will show the main sail in position, and more rigging details. And jib sail is installed too.
Fore sail and flying jib sail are still to go.
Little work ahead to the end. But a very lovely ship to build.
See you soon.
Greetings.
Giorgio.
- zifnab, Keith Black, ccoyle and 2 others
5
Hi shipmates!
A little update. I've been working with mast and spars, and of course, their installation.
Jack is checking everything is ok.
Here you can see Swift testing her sai..... no, templates. This gives an idea of how is she going to look once complitely rigged.
So, as i said, just a little update. Next i'll show details about rigging, blocks, lines, etc. And some sail making too.
See you next time.
Thank you for your interest, likes, and comments.
Good work.
Greetings.
Giorgio.
- Scotty W, Prowler901, Keith Black and 3 others
6
Hi @RustyNail123, nice project.
I'm building this little ship too, on scratch using the Artesania Latina plans, and also Katy of Norfolk's as a guide.
You could visit my build log, maybe you can find it useful.
https://modelshipworld.com/topic/29596-swift-pilot-boat-by-giomun-148-from-artesania-latina-plans/
Nice project, and very good start.
Greetings.
Giorgio
Hello shipmates! And Happy New Year! I hope this 2023 will bring us a lot of fun in our workshops.
Thank you @archjofo for your kind words. I'm a fun of your work so its a pleasure to know that you liked my work.
And thank you all for all the likes and comments.
So, a little update. The hull is ready, ready to receive mast and sails.
Made the new base, and of course, Jack got his new unifrom!!
I hope you like it. Next will be masting and standing rigging, wich is very simple in this model.
See you soon.
Greetings.
Giorgio.
- Jorge Hedges, Scotty W, CiscoH and 7 others
10
Hello shipmates!!
Just a small update. Y have installed the waterpump and the anchors. They are made of bronze, blackened.
One of them shows the cable, the other is just tied to the side of the ship.
The water pump is made of wood and bronze too.
Also installed the boom support with the first block of her manouver.
Next time i'll show the mast wich are under construction now.
See you soon. Hope you like it.
Cheers.
Giorgio
- archjofo, Jorge Hedges, ccoyle and 5 others
8
Hello! It's been a long time since last post. But i made same progress.
I maneged to find information about the Katy of Norfolk, another schooner that looks very similar to the Swift, i guess both ships come from the same plan, maybe the one that you can find in the Chapelle book i mentioned in another post.
Thanks to a fellow modeler from this forum i could find at least a picture of the Katy plans and now i can properly complete the Swift.
I completed the deck funriture, some finishing and more details. I hope you like it. Please tell me what do you think.
@Tim Holt i can't say anything about the ArtLat kit because i don't have it. Remember i'm building this model just using their set of plans, the rest is all scratchbuilding.
Thank you for all comments and likes.
As you can see, most of the work on the deck is ready, still missing the water pump and anchors. Then i can start with masting and rigging.
I hope you like it.
See you soon!!
Greetings.
Giorgio
Excellent work Johan as always.
Your work is from another planet, really.
Can i ask you a question? How do you polish your brass pieces? I mean what do you use? I really like that.
Congratulations again. Ausgezeichnete Arbeit!!
Greetings.
Giorgio
Finally a good HANDMADE carving work. And an extraordinary one!!!
I personally prefer hand made carvings, rather than having a robot doing that kind of stuff, or even more disgusting, casting them in wax and metal.
My respect to you @Alex jM, keep posting please. Specially the figure head, that in the Royal Caroline is very difficult.
Greetings.
Giorgio.
(By the way, i only expressed my opinion on carvings, that's all )
- druxey, mtaylor and Hubac's Historian
3
Hello!
Finishing my Le Coureur i decided to give a chance of having a scale "sensor".
So i gave a shot on some WWII 1:48 plastic kits i had. So i converted Soviet ground personel into XVIII's Century french sailors and officers.
Here are some pictures.
Maybe with some better painting skills the resaults are better.
Greetings.
Giorgio.
- Roger Pellett, AJohnson, mtaylor and 8 others
11
Cutter Luisito by GioMun - 1/48 - A small cutter built to survive a shipwreck in southern seas
Ciao shipmates!
First of all, thank you for all the likes and comments. They are very important to me.
Thank you @Rik Thistle, i didn´t know about the book. I confirm to you that the book is about Luis Piedrabuena, the constructor of Luisito, i´m sure it must talk about in the book, it must be some more information about it, surely.
So, with these photos, i complete the chapter. I opened the hawseholes, and gave to the hull some polishing.
Brazilian pine is a rather soft wood, but hard enough to stand a good polishing and dye, unlike other types of pine wich aren´t suitable for that. Anyway some scratches were too deep to correct.
So, pics:
See you in next chapter. Black colored, and hull fittings.
Greetings.
Giorgio
