Thistle17
Everything posted by Thistle17
  1. I took the model down to measure it for a case as it was starting to accumulate dust and I could not resist starting to work on it. I repaired the main hatch covers as eye rings had come off and one hatch cover had come apart. In doing so I did observe that some glue joints on the hatch coaming also had loosened. That was repaired. In doing so the centerboard lift internal "iron works" came apart. It is incredibly tiny so I am struggling with its repair. While doing so I began wondering about the chain lift that hauls the center board up. I now observe that the chain appears to be "terminated at an "iron work" mounted to the main cabin roof. This is just visible in my entry posting above on the 3rd photo. On the drawing it is the dotted line shown heading for the cabin roof. The termination appears just in front and to the side of the main cabin smoke stack. The Smithsonian drawing does show a dotted line indicating this odd termination point. What is even more puzzling is how the center baord is lifted when required. It imust weigh over 500 lbs! Joe
  2. To say this gun tub deserves a good home is an understatement. One of the most troublesome parts of this project has been a hull that meets the replication requirements and is worthy of such a fine sub system as the gun tub. If one recalls the hulls were reworked products of United Boat Works of Bellingham Washington. As such hull drawings were minimal so we had to replicate via what we had including photos. Patriots Point photos have been the most beneficial. As we now are preparing to ready the hull for all the topsides detail such as the helm build out, the stern gun platform, all the topsides armor shielding and the canopy metal work we had to get one last hull detail right. The bow flair has plagued us from the get go. It just wasn't right compared to the photos supplied. So to tackle the problem the bow rub rail was built out in laminated form from about the chine entry to the bow with water soaked bass wood bent and pinned to shape around the bow port and starboard. This built a "shelf" to which more Rage Easy Sand body filler was added to "bulk up" the area. At this point we needed a product we could easily shape and sand to the correct contour. We discovered yet another Evercoat product called Metal Glaze Ultra that is advertised as applicable over painted surfaces that have been roughed up. It has the same open time as other Evercoat products (about 5 minutes) but this product has a consistency of thick mayonaise. Using a rubber applicator we were able to fair the surface to a near perfect contour. Sanding and checking with the guage to the left periodically yielded the desired result. Joe
  3. David its that Marine Green almost green/black. I will see if we can improve on the situation of our photography. Joe
  4. Yes it is a bit more friendly in my estimation. Still not a complete CAM per se and the drawing capability (CAD) is primitive. Joe
  5. I have the 3018 Pro and I find/found it was OK as a learning tool. I was not impressed with its front end software. It is more or less a CAM facility with limited capability. Supposedly you can import other file types but my experience wasn't too successful. Also I had startup problems as one of my axis directions was incorrect and it would not run the test programs until the "NVM" was corrected. Take a look an INVENTABLES CAM like front end since they help with bit sizes, tabs, material cutting and depth parameters. Also my unit did not have overlimit travel and I had to add it. And yet another comment hold downs/clamping can eat up real estate. So consider that in your decisioning. Joe
  6. Here it is 3 months later! Where does the time go? I wanted to show you the advancement of the forward Gun Tub that has been made since Jim began the build out of this very complicated sub system. The manual from NAVORD provided by ALROSS has been a break through event for us. We are so grateful. And I must publically compliment Jim on his incredible rendition of the 1:6 scale model of the gun tub. I knew from the outset he was the one to execute this unit and I knew it would be done with care and accuracy but my jaw dropped when I finally saw it all assembled and painted correctly. You will note the flash guards now mounted on the barrells. In addition, though hard to observe, he has detailed the innards with the fire control panel, charger system and rotational mechanism. The only thing he has left off and to come is the search light and 50 cal bandoliers. Joe
  7. It is all a learning experience. Once understood we move on to bigger things. I haven't looked yet but I assume the daugther board is offered as an accessory to the controller board. You have my attention. Joe
  8. I too have moved to a house half the size of the former one and that made my basement shop an OK place to work but lacked the space, lighting and environmental control I had grown accustomed to. I use the computer room in the new house. It isn't ideal as I still have to return to the basement for lumber milling. But the bottom line is the lighting, the comfort and there is no more isolation. That is probably the best part. Joe
  9. Too often I think we characterize this branch of service as secondary to the Navy. They are not! I recently did a presentation on this service for our model group on another lifeboat of the USCG. If you wish I will share it with you. PM me as I do not want to highjack your blog. Joe
  10. Nicely done Mike! Not familiar with the Web plan can you enlighten? Joe
  11. I have limited use of AYC to date but much more experience with boxwood. What I would say about the AYC in comparison is that it is obviously softer i.e. less dense, it produces a machined edge reasonably well in comparison but I find it takes more care keeping it. In terms of sanding it is easier to sand than boxwood. If you are using laser cutting it's char is easier to remove. I find you have to be more attentive to keeping it clean compared to box as it seems to smudge much easier. It has almost no grain evident but I can't say that it is characteristicaly so as I have not bought large billets. I understand it bends well in comparison owing to its density and fiber construct. In terms of price I believe you will find it considerably less expensive. I have even less experience with Beech so others should be able to help. Joe
  12. Opening up MSW and dialing in your build is akin to morning vespers for me. So much so that I brought out my Winne bulkhead assembly and placed it where I cannot ignore it any longer. Your work is so inspriational! Joe
  13. Stopping in again Mike. Inspirational work. I am painting Cheerful gun carriages in box by hand with acrylic and I am not liking the results. I have tought of pulling out the air brush and having at it. I was a dedicated user of Floquil products and even have much of a gallon of their solvent left over. Indeed a gallon! So my question is what are you using for your spray paints? Thanks Joe
  14. Jond even though I was born and brought up inland my heart is in New England. My mom was from Providence, I lived in Portsmouth RI for a time and my son lives on Cape Cod so we visit often. My first trip to Maine was so memorable and has remained with me. I remember we stayed in Darmariscotta and I recall the town closed up at 6 PM back then (60s). I looked at their web site and it certainly doesn't look like that now! Hope to get back to your lovely area soon. Joe
  15. I realized this AM I had a brain cramp when I wrote this earlier. I now have it as one of my "Follow" the build reminders. I have fond memories of Booth Bay as i spent sevral days nearby in the Pemiquid Point light house monitoring recordings of Navy equipment being tested off shore. I thought i lost the coin toss to go out on the retrieve vessel for the equipment until I picked up my partner in Booth Bay. He was literally a light shade of green after sitting out there all day in those sea swells. Your doing a masterful job. Joe
  16. Hello Nick!
    Allow me to introduce our model ship group to you. We are located in and around Rochester NY. We are a small group that was founded in late 2015. We have members in Buffalo, Rochester, Syracuse, Florida, and even one in Lisbon Portugal. We meet monthly and through the Zoom application we have been able to include our more distant members. You can learn more about us by visiting our web site modelshipwrightguildwny.org.
    We have located you through the “Community” drop down function on the Model Ship World forum and are reaching out to you to explore your possible interest and participation in a lively and talented group of modelers from all walks of life.
    Generally, sessions are structured with introductions of visitors, followed by a brief business segment and then we almost always have a central presentation topic or two ending with a show and tell of group models. The sessions usually last two hours.
    So you are invited to visit us (via Zoom) this Fall and see what we are all about. You might find us interesting enough to join us on a more consistent basis. Please PM me back and I will put you on distribution for our Fall schedule when released.
    We will not badger you beyond this outreach if you are not interested.
    Hoping to hear from you.
    Thistle17 on MSW (Joe) or go to our web site and contact me through that portal.
  17. We are all experiencing the effects of protracted medical needs being delayed or indeterminant. When things are not exactly dire and/or considered elective it seems we go to the back of the bus. I would imagine that the waiting is so frustrating. Limbo is an uncomfortable feeling for one so productive. Joe
  18. Allow me to introduce our model ship group to you. We are located in and around Rochester NY. We are a small group that was founded in late 2015. We have members in Buffalo, Rochester, Syracuse, Florida, and even one in Lisbon Portugal. We meet monthly and through the Zoom application we have been able to include our more distant members. You can learn more about us by visiting our web site modelshipwrightguildwny.org.
    1. Show previous comments  1 more
    2. Thistle17
      Thistle17
      Fred something must have gone wrong as I did not receive it. Here is my email address lwts use this to communicate.
      Joe
      jlorenzo2@rochester.rr.com
    3. FredSC
      FredSC
      I would, but the last part of your email address is blacked out.  Try me at fnicoll@hargray.com.
      Fred
    4. Thistle17
      Thistle17
  19. Allow me to introduce our model ship group to you. We are located in and around Rochester NY. We are a small group that was founded in late 2015. We have members in Buffalo, Rochester, Syracuse, Florida, and even one in Lisbon Portugal. We meet monthly and through the Zoom application we have been able to include our more distant members. You can learn more about us by visiting our web site modelshipwrightguildwny.org.
  20. Allow me to introduce our model ship group to you. We are located in and around Rochester NY. We are a small group that was founded in late 2015. We have members in Buffalo, Rochester, Syracuse, Florida, and even one in Lisbon Portugal. We meet monthly and through the Zoom application we have been able to include our more distant members. You can learn more about us by visiting our web site modelshipwrightguildwny.org.
  21. Allow me to introduce our model ship group to you. We are located in and around Rochester NY. We are a small group that was founded in late 2015. We have members in Buffalo, Rochester, Syracuse, Florida, and even one in Lisbon Portugal. We meet monthly and through the Zoom application we have been able to include our more distant members. You can learn more about us by visiting our web site modelshipwrightguildwny.org.
  22. Allow me to introduce our model ship group to you. We are located in and around Rochester NY. We are a small group that was founded in late 2015. We have members in Buffalo, Rochester, Syracuse, Florida, and even one in Lisbon Portugal. We meet monthly and through the Zoom application we have been able to include our more distant members. You can learn more about us by visiting our web site modelshipwrightguildwny.org.
  23. I realized that I can contact other upper NYS folk on MSW through the “Community” function. Here is an out-reach I am planning to send to about 35 folk as far away as the Albany area. Have any comments or suggestions.?
    Joe
    Allow me to introduce our model ship group located in Rochester NY to you. We are a small group that was founded in late 2015. We have members in Buffalo, Rochester, Syracuse, Florida, and even one in Lisbon Portugal. We meet monthly and through the Zoom application we have been able to include our more distant members. You can learn more about us by visiting our web site modelshipwrightguildwny.org.
    We have located you through the “Community” drop down function on the Model Ship World forum and are reaching out to explore your possible interest and participation in a lively and talented group of modelers from all walks of life.
    So you are invited to visit us (tune in via Zoom) this Fall and see what we are all about. You might find us interesting enough to join us on a more consistent basis. Please PM me, with your email address or cell, and I will put you on distribution for our Fall schedule.
    Thistle17 (Joe)
