davyboy
Members-
Everything posted by davyboy
Kurt, In that case can you explain why the (wrong) book that was sent one month after my order in October only took 11 days to get from the USA to Switzerland. Posted 20/11/20 arrived in my postbox 1/12/20. No 90 day delay in the post there. Just the usual excuses given out. Incidently,any ideas why it takes over a month for a (wrong) book to be sent after order and payment in October. Dave.
Hi Jorge, Luckily,at least you have some of your order,I'm very happy for you. I'm still waiting for the replacement book volume 2 of Speedwell which I was told was being sent one month ago. Original order made 3 months ago. Never known of such poor customer service anywhere. Far too many excuses are made for this company. Dave.
Hi Druxey, A replacement would be sent if you could contact him in the first place on the contact details on his website. If I hadn't called the number on the paperwork that came with the wrong book I'd probably still be trying to get a reply from him. A very pleasant lady at his shipper sorted out my problem at once,the correct book is in the post to me. I'd also like to know why it took over a month from him receiving an order and payment (in my case) to a book being sent. Incidently,it only took 10 days for the wrong book to come from Missouri to Switzerland (20th Nov to 1st Dec). Can't blame the US Postal service at all. Re my post on the 13th Dec,two members PM'd me. I PM'd them the phone number and their problems were sorted out,one of them I know was also given a tracking number,says it all. They can provide tracking numbers. Dave.
Good evening Maurice, Another beautiful model from your shipyard I look forward to following your next build. Best wishes for next year. Dave
- 261 replies
- muirneag
- vanguard models
Hi Greg,it's a waste of time doing that or telephoning the number there. I tried contacting him about the wrong book being sent,no replies. Found the number of his Blue Springs MO department on the paperwork that came with the book. Called and a very pleasant lady sorted my problem out straight away. Correct order on its way. Dave
Hi,you must have got the last one. Just checked and the item is out of stock according to their page. Dave.
Hi Ron,if you wish to add the buntlines just put a knot in the line and pull it up to the block. Job done,this can be seen on contempory models which have no sails fitted. This was also done for the leech lines. Dave
Very nice planking Maurice,bet you're happy with that hurdle cleared. I've started milling Buxus for my Speedwell planking above the wales,much still to do there,especially the short ones between the sweep and gun ports. Still,it keeps me out of mischief Keep up the good work, Dave
- 261 replies
- muirneag
- vanguard models
Hi RussR,the Proxxon 50mm blade #28020 has 100 teeth and is 0,5mm thick. It will do the job perfectly,I use one for plank cutting everytime. Dave
Hi Mark,I've been following your build since you started.Exemplary carpentry and dedication indeed. A little fix you may find useful when drilling hawse holes. Drill about 2/3 of the diameter required then open out the holes using a tapered reamer of the req size then ream from the other end.Then run a straight reamer through to remove the slight constriction in the holes centre. You wont get any tearout and really smooth hawse holes,no filing marks. Just a thought,anyway it worked for me. Dave
Good evening Maurice,exemplary work from you. Kit bashing is certainly your forte. Just a thought but I'm a bit surprised that you didn't think of using braided steel wire as used for fishing traces for your tyes. It comes in various sizes/diameters relative to breaking strain and is quite flexible. Looking fwd to following your next little masterpiece. Regards, Dave
- 195 replies
- lady eleanor
- vanguard models
Hi Voyageur, The top blade is for cutting softwood,hardwood and plastics. It's ok and cuts fast and well,downside it tends to leave toothmarks. The second is for cutting nonferrous metals,softwood,hardwood,chipboard,plastics and glassfibre items etc. Can't comment as I don't have this one. The last one cuts the same items as the previous. I use this for cutting Pearwood and European Boxwood,leaves a nice smooth finish. Hope this answers your question. Dave
Good evening Maurice,very nice mods you've made to improve your model. Super job. Just catching up as I'd lost your build due to this new system,just my opinion but I think the old system was better,now I have to jump from century to century to find the builds I follow. C'est la vie. Kind regards, Dave
- 195 replies
- lady eleanor
- vanguard models
Byrnes thickness sander vs Micro Mark's
davyboy replied to twintrow's topic in Modeling tools and Workshop Equipment
Hi Jagger, I have the proxxon DH 40 thicknesser. A couple of answers for you. 1/10 of a mm,just under .004". Blades not sharpened they have cutting edges both sides. When blunt turn them,when that side is blunt change them,they only cost about $10 in your money. Access is fairly easy. I've had a little tearout probably due to grain orientation,cured that by turning the plank around. Can't comment on waste comparison as I don't have a thickness sander. For me the fact that virtually no dust produced (at least with Pear or European Boxwood) is a winner. Dave -
Good evening Maurice,looking good so far. I knew you couldn't resist a bit of kit bashing Keep up the good work. Dave
- 195 replies
- lady eleanor
- vanguard models
Panart Royal Caroline Rigging Help
davyboy replied to lesser160's topic in Masting, rigging and sails
Alan,Parrals or a Truss. Dave -
Newbie Keel Problem
davyboy replied to Jim in KC's topic in Building, Framing, Planking and plating a ships hull and deck
Hi Jim, FWIW,I have had warped 1/4" ply. What I did was draw a straight line on the build board,draw lines 1/2 the ply thickness either side of this line. Glued small wood blocks on these lines and slotted the ply in there then screwed angle brackets to the board at each end of the false keel to keep it vertical. Glued and clamped blocks between the bulkhead slots,next day a perfectly straight keel. No need to faff about wetting ,steaming etc which may not work anyway. Dave -
I had the same problem with a Cruiser kit I bought some years ago. Most of the walnut was rubbish,I just bought replacement wood from a modelshop here. My reasoning being I would maybe have been sent more of the same. After this I went into scratch building,once bitten twice shy so to speak and much more satisfying. Dave
Hi Termi, There was no ship named HMS Neptune at the battle of La Hogue in 1692. If that is what is written on the kit box it's pure fiction I'm afraid,nor was there ever a 3rd or 4th rate named Neptune. The second rate HMS Neptune was at the battle of Barfleur not La Hogue. In any case,no two ships with the same name would be serving in the Royal Navy at the same time. I know what you mean about kit plans being "a little off". When you come to mast and rig her I recommend R.C. Andersons' 17th Century Rigging or his Rigging of Ships in the days of the Spritsail Topmast 1600 to 1720. These can usually be found online on Abe Books or Amazon,not expensive. Anyway,I'm just being pedantic I guess Enjoy your build. Dave
Hi Termi, This model should turn out to be a nice representation of a late 17th century 4th rate. However HMS Neptune of this period was a 90 gun 2nd rate launched in 1683. Later sailing warships bearing this name were all 1st and 2nd rates. The name given to this model is fictitious,not unusual for European kit manufacturers back in the day. Enjoy your build. Dave
Hi Malas,the wood caps (AKA trucks) on Mast tops were fitted with a sheave or sheaves for Flag or Pennant halliards. Perhaps if you said which masts,Lower,Topmasts or Topgallants you refer to may help with getting some answers If you are building a kit do a search on the forum,you might get lucky finding a build log there. Dave
