Everything posted by Canute
Sorry to read that Jesse. It's always tough to lose family and friends.
- 1,306 replies
- syren
- model shipways
Tamiya Extra Thin with the green cap. It's acetone based so it evaporates pretty fast. Hold parts in place, a quick swipe with your glue brush, count to 5 and it's bonded. Not super hard; should let it set up an hour or so. I generally have 3 kits going, so I can rotate through various steps in a session. May want to rough up the mating surfaces even for CA glue. That works on resin parts, too.
- 77 replies
- icm models
- Markgraf
I'm in Jack. Check into Gator Masks. Same guy as the glue maker. The Measure 32 schemes are complex.
Yeah, modern AA gunnery directors couldn't handle the slow speeds of the Stringbags. Greg, that glue is still around, although packaged differently. It still smells. I've been using the Tamiya Extra Thin glue, with the green cap. It's acetone based, to boot. I try and keep the lid on that. CDW, if it's a wingy thingy, I'm in for the duration.
Denis, the wood is appropriate fuel for the Civil War, especially in the South. That pile on the tender is pretty close to what it might look like. Steam engines might only run 100 miles between water fillups and if in hilly country maybe water up even more frequently. And wood could be an issue if it burned up too fast. Soft woods also weren't as hot burning as oak. For modeling purposes, I second everybody else. If you have some dead azalea branches use them for the load. Colors then were pretty bright with reds and yellows. Boilers might be what they called Russia Iron (a blue tinged iron) or green. The General in the museum in Kennesaw is supposedly in period colors, but the brake gear my be a newer system. The Russia Iron blue is sort of like a deep blue chimney color on a wood burning stove. Best google it. Can you take a picture of the couplers? In the early days of railroading, they used a link and pin device. There was a slot in the end of each car and two holes above and below the slot. The pin (think of a long belaying pin) was pushed from top to bottom in the holes, trapping a link (think paperclip shape) between the pins in each car. Back then, the brakeman, whose job it was to insert said pins into the end beams, often had nicknames like "Three fingers", since they could get fingers pinched while coupling up. After the Civil War, railroads got more safety conscious and developed knuckle couplers and air brakes. Also pushed for standard time zones across the country, instead of every station/town having it's own "local" noon.
Cripes, I did that in front of my Mom, after a year in a giant fraternity house in Thailand. Got my mitts on some fresh, hot corn on the cob for dinner one night. Asked Mom for the bleeping salt. Wham, my little 5'2" Mom back-handed 6' me onto the floor. My Dad and sister were roaring in laughter, Dad in sympathy with me (he fought in WW II) and my sister just laughing at my buffoonery.
Green Elephant funny car by jct - FINISHED - 1/24 - PLASTIC
Canute replied to jct's topic in Non-ship/categorised builds
We had a fatality at the Englishtown, NJ drag strip with a car going off the end and into the weeds some years back. Upshot was the safety zone there was too small. Since they couldn't acquire any more land to get in compliance, they shortened the track to 1,000 feet between the timer lights. -
The canard concept was one the Wright Brothers used on their early flyers, along with wing warping to turn. The canard is a forward mounted tail plane with elevator surfaces. NASA experimented with an additional flying surface on some fighters to allow quicker tighter turns. And the Swedish Viggen has canards in front of it's delta wing.
Been there, done that, Lou. "Do you know where you are?" "Well, kinda"
I think they apply them to the foil to allow you to make the flags ripple in the wind. Probably need a flexible paint, like the stuff the RC guys use, since you want the paint to stay applied. I'd use a light gray color as a base, especially under red or yellow colors.
Sounds like the placement for ejection seat handles in fighters. Over your head, on the sides of the seat or between your legs. My preference was the overhead handles since it pulled a restraint out and over the top of your helmet and forced you to keep your arms pulled in tight to your body. Luckily, I only used it in simulations. Safety has to be a habit.
Denis, sounds like my gyrations trying to plumb the brake rigging on assorted HO scale railroad cars. Many holes are too small for the locator pins or assorted rods and piping. I end up reaming out or going to larger drills to assist the fit. I'll get some pictures later today to show you. I use fine plastic rodding and similar brass/phosphor bronze wires. Getting the tubing over plugs and distributor heads is frustrating; we need a mandrel to spread the tube end.
Straightening thin brass wire
Canute replied to vossy's topic in Metal Work, Soldering and Metal Fittings
Another source for brass wire is a company called Detail Associates. They make a number of sizes or brass wire. Another one is Tichy Train Group. They make phosphor bronze wire in small sizes. The pb wire is a little stiffer than the brass. Check hobby shops with model railroad parts. -
Harbor barge hull planking
Canute replied to Canute's topic in Building, Framing, Planking and plating a ships hull and deck
Kurt and Patrick, thank you. I planned to have the bow planks overlap the side planks. Your info validates my plan. The kit is more into the pile driver appearance versus a built up hull. -
Greg, did you have issues getting the torpedo net drilling template to lay out on the hull? I plan to cut it out of the instruction sheet and tape it onto the hull. Glad I have that little Ryobi drill and chuck for all the holes. The drill turns slow enough that I had no issues with plastic gumming up the drill flutes.
A question about the hull planking of harbor barges. They are basically rectangular, slab sided vessels with some sloping of the bow (?) and stern areas from the deck to the waterline and down to a keel. Would the planking across the slanting bow/stern areas overlap the boards of the sides or would they be interleaved? The 2" x 6" scale boards (planking) are glued onto a plywood former. I ask as I have an old Sheepscot Scale Products kit of a pile driver on a barge. Pictures are too small or grainy, even with extra light and using my Optivisor, to tell what the configuration is. Just gathering info for a future build.
I was in a flight of Phantoms, years ago. doing something pretty similar during hunting season in central Pennsylvania. We were in a low fly area and crested a ridge at very low altitude, spooking some whitetails away from some poor guy who'd probably spent all morning maneuvering to get a shot. As we rounded into a turn I glanced back and saw he wasn't exactly waving goodbye. I could see a bright orange jump suit in the tree line.
Here's another website with a short article about making homemade acrylic thinner: https://www.cybermodeler.com/tips/thinner.shtml He has a longer blurb here about painting aircraft, but since we seem to have merged builds of plastic ships many techniques will work for us, too. He also addresses airbrushes in the article. The link: https://www.cybermodeler.com/tips/painting.shtml
A lot of us are using acrylic paints in our modeling. I felt we needed a central location where our various tips and techniques could go, instead of being buried in one of our build logs. One area I see time and again is the proper thinning for airbrushing. Coming from a model railroad and aircraft background, I've seen a few different ways to deal with this. I can't reproduce this pamphlet on our site, but you can get it here. It doesn't cost you anything to log onto the site, but you do need to log in. Sorry about that. https://model-railroad-hobbyist.com/subscribers-only/painting/acrylics The whole pamphlet is excellent, but chapters 3 Mixing and Storage & 4 Formulas for Thinners apply here. They address Modelmaster, Badger and Vallejo paints. Like a lot of hobbyists, model railroaders were put out by Testor's when they dropped the Floquil/PollyScale lines. This pamphlet was done to help folks move into acrylics. And many have adopted the Badger and Vallejo paints. Hence the extensive charts for converting the old paints into these newer acrylics. I'd like to see more on the Tamiya paint, since the big box craft stores seem to stock them around here. I've been on another site that also addresses home made thinners, but parts of that site are undergoing renovation and I can't find the appropriate page to link to. More to come. And please add to these tips and techniques.
