Canute
Everything posted by Canute
  1. OW-OW-OW. When I was about 9, I had a kid throw a stickball bat at me on my bike. I went over the handlebars and landed on my right shoulder. Ended up as a green stick break of my right collar bone, 6 weeks in a sling. Back in the days when our bones were semi-flexible. It was the next to last week of school, so the first month of summer vacation I wore that sling. I hope your sling/plate doesn't cramp your build, but between the break and the meds, I'd be surprised. Take care.
  2. Superb work. Thanks for sharing.
  3. Couldn't have been too lazy if you've figured out the differences in colors for these French cavalry types.
  4. Your diorama has turned quite nicely, Alan. Well done.
  5. That's a relatively recent term. I think the time period of most of Gary's builds precede the tagging era of anything not moving getting marked. I have a few friends who are masters of the art. They model the 80s and later. As a modeler of the post WW2 to approximately 1960 time frame, I don't have that issue to play with. Chalk marks from switching is about it.
  6. The Baron's letter stated he couldn't confirm if the turrets were ever yellow.
  7. I'll go along with using both in different parts of your diorama, The third floe definitely looks like the real ones.
  8. Gary, great technique doing up the Hydrocal walls. All too easy to end up with the splotchy looking walls. Really enjoying this build. 👍
  9. It all depends on how thick the decals are. Some are very thin and need 1-2 coatings of SOL; others are very thick. I have a bottle of something called Solvaset. Its the last setting solution to use and only on very stubborn, thick decals. There were a few model railroad companies that printed very thick decals and the Solvaset was the only thing that worked. Like OC says, put down a coating and walk away. Let it dry before reapplying more solution. 😉
  10. Wasn't that bottom color duck egg green? My RAF camo books are packed away in the archives, so I'm dredging up 40 year old memories.. I'm in on the build, Andy. Battle of Britain colors would be apropos, I think. The Hurris chased the bombers and the Spits duked it out with the Messerschmidts.
  11. One idea is to take a dead flat piece of glass, glue down a sheet of 80 to 120 grit sandpaper and start working the conning tower resin in a circular pattern. Check frequently to ensure you are staying even. Do it outside and wear a dust mask. Slow and steady. Hacking off an irregular sliver of resin with a razor saw is not for the faint of heart. How could you hold it to cut? I've done this sanding on some limited run resin kits. The parts are made in open molds and the backsides of parts can be uneven.
  12. Well, the front section is just a tad newer, so the paint would be more intact. I think this is progressing nicely. I look forward to your next installment.
  13. Sign me up for this one, too. And it's in HO scale.
  14. Happy New Year to you and the Admiral, OC. Hope it's a healthier and happier one for us all.
  15. Arizona would be a welcome build, in a pre December 7, fit. On some forums, the paint job (gray versus blue) fires up flame wars as to who is correct. I have no oar in the water on that. I just love a well documented build and finishing log. Your work, whatever the build, will do your subject proud. 😄
  16. I was in St Louis in'75 picking up an Imperial Iranian Air Force F-4E to ferry to the Shah. We got a tour of the facilities and saw that mocked up Super Harrier (I presume), tucked in among the Phantoms and Eagles MickyD was cranking out. The jet I picked up had one hour on it. That was the Functional Check Flight they did before shipping it out. Whatever writeups they may have had were insignificant. The jet smelled like a new car. The forms were clean, no carry overs.
  17. What did you think? He's really good for aircraft, but does a decent job on naval colors.
  18. Check out the Cybermodeler site. This is the USS Essex and shows Viet Nam era colors: https://www.cybermodeler.com/naval/essex/essex_all.shtml For paint selections look here: https://www.cybermodeler.com/resource6.shtml Look at the bottom box in his right column for Modern USN colors. He has comparisons for a number of hobby paint lines. Good hunting!
  19. Got the miniature work table last year. Been handy for several projects. My Northwest Shortline Choppers ( for cutting wood and plastic strips) have standard angles of 30, 45 and 60 degrees that are as small as the Veritas units. This will work out nicely, Jack. 👍
  20. Your Corsair is a superb build. 👍 Thanks for sharing this blog.
