Everything posted by Cathead
Kurt or Roger may correct me, but as I recall, in the steamboat era, steamboats started towing extra rafts or other simple vessels behind them to carry more goods. This was very unwieldy and difficult to control, so as riverboat designs evolved, the extra barges shifted to the front of the vessels, but the phrase "tow" and "towboat" stuck around. In other words, there was a slow evolution from the powered river vessel being the primary means of carrying cargo (classical steamboat) to the powered vessel towing some of the cargo in independent loads, to the powered vessel being adapted to push those separate loads (the beginning of the modern towboat), to the powered vessel becoming nothing BUT the power source (more like a railroad locomotive) for independent barges. But the original terminology never changed. Just like how we still "dial" phones.
Who you callin' elderly? I'm 42! Jokes aside, so glad this was useful to you, and good luck with the project!
- 29 replies
- ships lifeboat
- model shipways
Mark, I agree. It’s long befuddled me why kit makers almost completely ignore river craft. A towboat or steamboat isn’t any more obscure than some of the centuries-old sailing vessels that get churned out. Canoeing on the Missouri River last year, we passed a rare tow and it was cool to see it up close and experience just how powerful those engines are; the effects of its wake lasted a long way downriver as they reverberated from bank to bank. Anyway, rambling way to cheer on this choice of model by someone who will do it justice.
That's as good a motto for this hobby as any! Nice progress.
- 86 replies
- king of the mississippi
- artesania latina
Next up, the ridgepole. This is an elevated beam that runs the length of the hurricane deck, supported on thin posts. At this model's scale, the posts are 1/32" square and the beam is 1/32x1/16". Tiny. The instructions tell you to glue the posts to the deck, then to glue the beam on top. Making a series of 90º 1/32-1/32 joints in mid-air 3/4" above a delicate model while holding the entire assembly straight and steady struck me as darn-near impossible, and not something I was going to attempt. So I made the assembly on the workbench. I couldn't find any piece of wood that matched the 1/32x1/16 dimension called for in the instructions (not necessarily blaming the kit, I could well have misplaced it), so I pulled something close out of my scrap pile. It's a little wider/taller than called for, but that also makes it stronger, and I care more about that. I used dividers to measure the distance between each post on the hurricane deck (they're marked by tiny divots in the laser-cut piece), then end-glued the posts onto the beam with an extra dab of glue over the joint to soak in. I still didn't trust these joints, and decided they simply had to be reinforced. At that point I went back to look at @mbp521's build, which gave me a lovely excuse to do this. Notice that his build included metal brackets making the connection between beam and post (logically, really). Look at the wood-colored beam running down the center of the model: So I simulated the same with small scraps of wood, first gluing all one side and then the other: Here I'm test-fitting the assembly onto the deck, and it lines up great. It's also strong enough to be handled. I just can't imagine trying to keep those joints solid without reinforcement. And here are a few pictures painted and installed. It actually adds a lot to the model, visually, especially with the grey-black brackets. Here's another case where I diverged from the instructions, which tell you to paint this on the model. No way I'm doing that and risking any paint spills onto the deck from trying to get a brush down a 1/32" square pole right to a ridged deck surface. I can't imagine why the kit doesn't call for doing it this way, it's so easy and adds so much strength and accuracy. If you look really closely, you'll see that I had to adjust for another of my own mistakes. I'd intentionally cut the posts long, but when I trimmed them to length, I did it too shot, so the beam rested on the paddle wheel housing. So I had to file a gentle curved notch into the underside to make everything fit. It's barely visible, but the beam should be a bit higher. Mea culpa. We're actually sort of getting there. I think adding the cannons will be next. What could go wrong?
- 113 replies
- Cairo
- BlueJacket Shipcrafters
Sure, there'll be a lot of touch-up at the end. In the case of the post tops, I'll just use the same black paint the rest of the assembly used.
- 113 replies
- Cairo
Another day, another detail, another dammit! Last night I was working on what the instructions call Torque Rods, what I would call hog chains on a normal riverboat but I don't know if different terminology was used for these vessels. Following instructions, I bend some thin brass rod to match the plans: Then cut some support posts. The instructions tell you to glue the support posts onto the deck and then install the rods over them, with the rod ends fitting into drilled holes on either side. This made me suspicious, as a tiny post glued end-on to a deck is going to be a very weak joint on its own. So I pre-made these assemblies on the work bench, filing slots in the top of the posts to help hold the rods in place: Installing these was absolutely maddening. The joints between the posts and rods kept breaking (I used CA), and getting things to line up straight was really hard. Even the tiniest bit of torque (ironically) broke or deformed the assembly and created a cascade of trying to fix that and causing other problems. I eventually gave up in frustration and went to bed, then got back at it this morning, when I finally got a version of this installed. You can see that things don't like up well, and a glob of glue on top some posts where I had to keep re-gluing joints. I don't care. I also pre-blackened the rod and pre-painted the posts. The instructions tell you to paint all this AFTER installation, which seems crazy to me. Much harder to do without getting anything on the deck, and if you do, you'll never get it off again. They'll need another coat since I wore some off with all the handling, but pre-painting still made sense to me. You'll also notice that a bump from my finger rubbed some paint off the central skylight; that's going to be a major pain to fix. I'm using Vallejo primer and paint, but it just doesn't like to hold on the brass even though it's supposed to. Now I'm working on the ridge pole that runs down the center of the whole vessel, over the deck, which is already being super-fiddly as it's incredibly small and delicate.
- 113 replies
- Cairo
Yeah, I'm planning on doing some final weathering, but I've learned my lesson and won't do it until the very end. I've already had to paint over one weathering job when further work damaged it.
- 113 replies
- Cairo
On the damaged deck, you could consider hiding those areas under some detail, like a crate, a bench, a rope coil, or even a figure, depending on the exact setting. On the warped piece, you could try soaking it, then sandwiching it between hard layers (like glass or metal) and weighting it down until it dries (hopefully flatter).
- 132 replies
- King of the Mississippi
- Artesania Latina
The rudders were another adventure, this time entirely of my own making. These come as laser-cut pieces that you're supposed to simply glue to the back of the model. I had sanded and painted these when I decided to clean up my workspace. Somehow I managed to throw out the rudders. At least that's the only explanation I have since they had vanished when I'd finished straightening up. Luckily, shaping new pieces from wood is a skill I do have. I didn't have any scrap left from the kit that was the proper thickness and size to make new rudders. So I used some thinner pieces of wood and glued them in pairs of approximately the right size: I then traced the outline of the rudders onto these sandwiches and carved/sanded them to final shape: Painting was simple. I didn't trust the kit's instructions to just glue these to the back of the mode. That seemed highly delicate and likely to be knocked off. So I drilled holes and inserted two pins (made of small brass nails) to give more structural integrity. And here are the finished rudders mounted on the stern. I also installed the absolutely tiny brass tillers and deck protectors (or whatever they're called). These were pretty hard to work with, they bend super-easily and I lost a couple in the carpet for a few minutes when I dropped them. Even trying to glue these down was hard without leaving any glue trace on the wooden deck. But the final appearance is close enough. This also shows why I reinforced the rudders. Once you connect them to the fragile brass tillers, having them get knocked off would be disastrous since it would probably bend the tiller and you can't replace it. Actually, I see in the photo that the paint has chipped off the tillers in a few places that I need to touch up. Sigh. My version of this model doesn't hold up to close scrutiny! The instructions want you to simulate hinges by cutting .020" strips of paper and gluing them to the rudders. I decided there was no way I was going to be able to do that in a way that would look better than just leaving them off. At this point it's obvious that I left the whole hull black, as the instructions tell you to do. I know that others have argued for the lower hull being a dull red, and that's the sort of upgrade I'd initially intended to do, but I gave up on it as I started to get discouraged and annoyed with the kit. Simple hull color it is. I'll never make a claim that this is anything but a loose representation of the Cairo. Now we move toward final assembly and detailing.
- 113 replies
- Cairo
Welcome back! Glad to see you haven't given up. Love me some cats.
- 86 replies
- artesania latina
The chipped paint might be realistic, but the shiny brass glinting out from underneath it...less so! I don't know what to say regarding a recommendation. On one hand, I do think the kit has many flaws in both design and instructions. On the other hand, many modelers could probably make a pretty good go of it. I don't think it was a good choice for me at this time, it wasn't what I expected or wanted right now, but that doesn't mean it wouldn't be a good choice for someone else. I'll write more about this in a final review when I'm done. Thanks for reading, I'll have another update this weekend.
- 113 replies
- Cairo
A certain amount is my fault, too, and I'll end up writing a recap/review of the whole process and kit eventually. I'm not blameless. But I do think this kit has serious flaws. Anyway, here's the process of building the wheel. It's just a fraction of the total wheel, meant to show the part that sticks down below the main deck, between the two halves of the hull. The kit provides a jig to assemble this, basically a piece of wood with four laser-cut slots that are meant to hold the wheel parts while you glue up the assembly. Makes sense in theory. Except that the slots in the jig are much wider than the very thin pieces of brass, so they aren't held in place, but wobble all over the place. I had a devil of a time assembling this because nothing stayed put and I found it impossible to keep all four pieces lined up. You're supposed to feed five strips of wood through the wheels and glue them in place. Here's the best I could do: Doing this was a royal pain in the butt, with every brass piece sliding all over the place as I tried to slide the first piece of wood in there, while trying not to get glue everywhere. Even once the first one was dry, the assembly wobbled and deformed as I tried to get the next one in. That jig is nowhere near enough to hold this steady. If I were designing the kit, the jib would be a piece of wood the full footprint of the wheel, with guides slots the actual thickness of the brass cut the full length of the brass pieces, so they could be slid snugly in and held tightly in place during assembly. If you look closely, you see that the one at far right is oddly spaced; it's at the opposite side of the struts as the rest. That's because it wouldn't fit in the smallest space provided, where it's supposed to go. It's a measure of how disgusted I was after doing the first four, that when I discovered this, I didn't even bother just thinning it down a bit to fit, but slid it in the other darned side and glued it up. This gets hidden under/inside the hull anyway and I'll just put that toward the back where no one will ever see it. The good news is that paint hides many sins, and this is getting hidden under the model (I almost didn't bother making it): One more step on the road to completion!
- 113 replies
- Cairo
Next step is to install the hammock nettings. This is an area where I initially thought I'd consider some nice upgrades, but I'm now very much in "just get it done out of the box" mode. The instructions for this stage were, as elsewhere, both confusing and in my opinion oddly structured. These are made by sandwiching a piece of styrene (the hammocks) in between two pieces of etched brass (the stanchions and nettings). This is the order of operations in the instructions: Round off the top of the styrene to look like rolled-up hammocks Glue the styrene onto the deck. Glue the brass netting strips onto the styrene. Glue various tiny pieces of .020x.020" styrene onto the nettings to fill out the stanchions. Paint in place on the model. In retrospect this order makes no sense, and I should have seen that coming. It's insanely fiddly to do all that detail work when the basic structure is already glued to the model, and in the process of trying to handle and tilt it so I could do this work, paint started chipping off the armor. Plus, I found it impossible to paint parts after they were already installed and got into a nasty cycle of leaking paint onto the deck/armor, then trying to correct it, then trying to cover those leaks, and so on. This was a super maddening stage and I came close to binning the whole thing. Here's what my attempts looked like: I pre-painted the top of the styrene in an attempt to head off the "painting on the model" problem, then glued the strips on: I also prepainted the brass netting/stanchions for the same reason, and glued those on. What I did not do, and should have, is prepaint all the styrene detail strips (though these are so tiny, this would have been awkward). I also should have assembled the styrene details on the brass strips BEFORE adding them to the model, as I found it nearly impossible to glue them on straight. You can also see the paint chipping that developed as I attempted to maneuver these microscopic pieces into place. Next you're supposed to cut a bunch of tiny styrene strips and fit them horizontally between these stanchions. I found this nearly impossible to do well on the model. I wish I'd done this all on the workbench as one assembly. And look, more paint chipping! You can also see how I'm building up too many layers of paint in attempts to correct past mistakes and damage, such that the surface is looking ever less realistic. So the problem here was that, despite my pre-painting of the main parts, I found it impossible to paint these styrene details without getting black paint on the styrene hammocks. So then I had to try and touch up the hammocks, and doing that in place on the tiny model meant some brown paint got on the stanchions, so I had to touch those up...and you see where this is going. I'm not done trying to correct each round of mistakes yet and the paint layers are getting thicker than they should. Here's two shots after I just gave up and painted the whole darn thing black before trying to reapply a solid layer of brown (which didn't work well but I haven't taken photos): You're also supposed to glue a thin styrene strip all the way along the inside of these assemblies, after they're on the model. I decided to skip this step. I didn't think I could maneuver a 10" long .020"x.020" strip into place behind those tall stanchions, with glue drying on it, without making a giant mess, and it's such a small detail it won't even be seen. If I could do this over again, I'd build each hammock assembly on the workbench, paint it, then install it. That would make it so much easier to install all the tiny bits when the assembly is flat, when there's no risk of damaging the model while fussing with it, and where I could correct mistakes without making anything else worse. I just don't understand why the instructions think you should do all of this ON the model, raw, and THEN paint it all while somehow keeping the hammock color separate from the surrounding netting and stanchions, much less off the inner deck, at this scale. Like this: Round off the top of the styrene to look like rolled-up hammocks Lay out the brass strips and install all styrene details flat on the workbench. Pre-paint the styrene hammocks and the brass/styrene assemblies. Glue finished/painted brass assemblies onto styrene hammocks at the workbench. Install finished assemblies on the model. I've also started on the paddle wheel, which was just as frustrating and oddly designed, but I'll recap that separately once I'm done (in multiple sense of the word). Can you tell I'm not having fun? Thanks to a kind member for contacting me privately and offering support for just binning the whole thing. I really appreciate the logic behind that advice, but I want something for my hundreds of dollars and many hours, even if it lives in a darker corner of the display cabinet. Thanks for putting up with my whining!
- 113 replies
- Cairo
Nice progress! I was curious about the bull rail question so did some sleuthing (since I haven't built this myself though I've followed many builds of it). Photos on @mbp521's build log show the bull rails mounted, as you suggest, on the second and third posts. See here: And so does photo 12 from p. 8 of the online M-E instructions (which may well differ from what you got in the box): So whatever your instructions say, you seem to have made the right choice.
- 157 replies
- chaperon
- Model Shipways
Ken, that's exactly what I used, I went back to our Christmas stash and grabbed some white paper. I took a few outdoor shots today in better light. The smaller structures aren't attached, just placed loosely for the photos. This shows the softer color on the wood, vs. the darker armor, better. I think I like the subtle contrast, even though I still don't like the texture of the plain wood.
- 113 replies
- Cairo
Yeah. It's small. Don't think I really appreciated just how small when I bought it! Been working on some more details. First I decided I really didn't like the plywood roofs on the rest of the wheelhouse either, so used an old trick and glued some tissue paper over them to simulate the texture of tarpaper or canvas. I then mixed up some black with a little brown, to emphasize the subtle change in texture. It really doesn't come through in photos but it's visible in good light. I liked the effect so much I used the same mix to repaint all the wooden parts of the main casement, again giving a subtle difference in appearance from the metal armor. Whether or not it's prototypical, I think it adds to the visual effect. Maybe I'll get some outdoor shots at some point and you can see it then. Next I made the chimneys. These are brass tubes slid down over metal fittings. Actually straightforward for once. As directed, I drilled one hole in each for the support rod that'll go there later. I roughed up the tubes with sandpaper, then I primed and painted them. Had a bit of a disaster when I masked the upper chimneys to add the grey stripe that was Cairo's distinctive visual marker; the tape stuck to the paint below and peeled it off down to the brass. So I repainted and freehanded the stripe. It's not great but it'll work at distance, like the rest of the model. Next I worked in the bulkwarks around the bow and stern, which are made of a square styrene strip. I prepainted this so I wouldn't get paint on the weathered deck. At the bow, I made two strips, shaped one end of each to match the casement, then glued a small section in place. Once that was firm, I bent the rest, cut it carefully to fit against the prow, and glued the rest. I used the same procedure at the stern. Next the instructions have you cut the fairleads through which cables and anchor chains run. These are ridiculously small at this scale but it'd look odd to leave them out. Following directions, I drilled a small hole through the bulwark in each location. But instead of using a knife as directed, I used small jewelers files to widen and round a notch. I used my lit-up magnifier for this because it was so darned tiny. Once I painted over these I'm not sure you can even tell there's anything there. So here's a photo of the current progress that might maybe show the subtle color differences in the wheelhouse and casement, as well as the finished stern bulwarks. Meh, it's progress. Next the instructions have you make the hammock nettings, which look really fiddly. Some other time, I'm burned out for now.
- 113 replies
- Cairo
Quick update on the wheelhouse. I decided to upgrade the curved roof slightly by scribing "planking" on a new piece of 1/64" plywood and adding that. Here it is in raw form: And here's the wheelhouse after painting and a first light round of weathering.
- 113 replies
- Cairo
Thanks, Brian. I hear you on the medication and related issues. It's interesting that your photos (and I believe your model) show a gently curved roof on the structure aft of the wheel, while both the BlueJacket plans and the more detailed digital plans you sent me show that to be flat. I went with flat because it's how the kit was designed and it was easier. You probably covered this in your log but I was lazy and didn't go looking for it. I think I have the roof angle on the little side structures too steep, but oh well. Not the first inaccuracy this model will have. I suppose I could try "planking" the curved area over the wheel with very thin strips to see if I can achieve the effect you're describing.
- 113 replies
- Cairo
As you might have expected from my style on this project, I ended up just plowing ahead because I had time today. Just made executive decisions about that I thought would work, with loose consultation of the kit plans and the better digital plans I also have. The kit's 1/64" plywood worked fine for roofs, it bends easily and holds it shape. So here's the whole assembly put together and mostly primed (I forgot to add the ladders until after the first layer of primer. It's not too shabby. Paint will tie it nicely together, I think.
- 113 replies
- Cairo
So next up is the paddle wheel house, which is assembled from various (mostly laser cut) blocks of wood. Seems pretty straightforward. Here's the only illustration in the instructions ("Sketch 9"), and here's what it looks like mocked up (the long piece gets cut to fit). My problem is that two key steps have no clear guidance or illustration that I can find. First, the instructions say "cut the roof sections from the 1/64" plywood sheet and glue them in place". OK...but nowhere in the instructions or plans are any roofs shown clearly. Sketch 9 shown above certain doesn't, and this is the closest the plans come: How much overhang? You can sort of guess from this, but it's a pretty rough drawing and doesn't show the other dimension. Does the curved part get a roof panel too? Second, and related, the little side buildings aren't supposed to have flat roofs, but angled ones. The instructions say "sand the pitch into their roofs". OK, what's the pitch? You get a 3D hint from Sketch 9 and a loose sense from the plans above, but for someone actually interested in accuracy it would be nice to have a clearer idea. The little piece of basswood you cut to length also needs to have an angle put on it, and again no clear guidance is given for this. Wouldn't be hard to include a quick plan view with an actual template for doing this. Maybe I'm complaining too much because you can more or less figure out a workable approximation from these drawings. But it's just so sloppy, and again the kind of thing that will befuddle a beginner and annoy a perfectionist. The most specific question I have, and it's the one least answered by the kit, is whether I'm bending a plywood roof over the curved part of the wheelhouse. No drawing shows this one way or another. I think it would make sense for visual consistency, but I'm curious what Brian and others think.
- 113 replies
- Cairo
