amateur
Posts posted by amateur
  1. Chuck explains it here. (In his log of Cheerful) Printing on very thin paper. Sounds easy. But I guess some trial and error is needed before it works.
    On 4/25/2017 at 5:12 PM, Chuck said:
    Thanks guys.
    The flag was made from the tissue paper you use to pack a gift with.  Its white....you can buy this stuff anywhere but this particular stuff is very thin.   I dont have a brand because I literally went into some old boxes we use to wrap up Christmas presents and took some out of the box.  But you should experiment with different brands and thicknesses.
    I basically use a jpg. image of the flag which has been sized in Microsoft word.  You could skew your flag ahead of time in the program to make it easier to shape but I didnt do that.  I just printed out the standard rectangle.
    First you print out the flag on normal paper so you can see where on the paper the flag will print.  Then you carefully tape the tissue paper over that image on all four sides...the tissue paper being slightly larger than the flag.  Then print the flag again after placing the paper in your printer again.
    Cut the flag free from the tissue paper after it dries.  Cut it right along the edges with no white space showing.   This next step is important.  The tissue paper is so thin that the ink will soak through to the other side but NOT entirely.  So the first thing you need to do is flip the flag over and spray the REVERSE side with some Krylon Matt fixative.  Dont be afraid to spray too much.   This will facilitate the ink soaking through to the back side further and it will look like it is literally printed on both sides.   Then after it dries flip it over and spray the front side.
    Shape it to suit with various size dowels.  You can also spray the fixative more to really soak it because this makes it easier to shape...you can do this several times if need be.  Once dry it holds its shape.
    Then I poke a hole with a sharp awl in the two corners so I can lash it to the flag halliard.  Done!!!:)
    Hope that explains it well.
  2. On 10/4/2020 at 8:52 PM, silverman834 said:
    Thank you Roger and Bolin, it sounds as if I don't have to worry about a parrel and maybe just add a trozza if I see the need. Thank you!
    I havn't seen any signs of oars in these wrecks and imagine the ships running with a minimal crew and probably waiting for favorable winds, or maybe finding a farmer with oxen to drag them?
    Which is not compatible with the location of the wreck. The zuiderzee was a rather shallow, relatively large open water, with in some locations a bogland between water and coast. No way vessels could be drawn.
    same holds for 'favorable wind': winds can be from the same direction for weeks. Waiting for favorable winds can take some time.
    Interesting to see a mast like this. Never saw one in the context of Dutch shipbuilding.  But then, medieval ships never my main interest :)
    Jan
  3. Ah well, didn't see that on the pic.
    All the same, I am a bit puzzled by the fact that it seems tha although the important information is on the 'land-part', more ink has been spent on the ships.
    But on most maritime charts, the compass rose is drawn with at least 8 points, there are some bearings on landmarks etc. This is more like a landowners map, trying to find the best place for his new development....
    You say there is a copy of the map dated 1750. Does that one have the ships also?
    Jan
  4. I don't know how it was in the UK, but in the Netherlandse (and other "EU-countries") larges sheets of paper were often/always made with a watermark.
    This mark can be quite helpfull in dating the map (at least biy providing a time-fence).
    By the looks of the map itself, I would vote for late, rather than early. Also: the detail of the roads (canals?) are far better drawn than the details of the coastline. My guess would be that the printer of this map did a nice job on the street-layout, and just put a nice lithograph of the ships in the part where there were no streets to display. (in which case he would have copied the nice painting in his (grand)fathers house, and thus display ships of an aera already gone by th date of the map)
    Jan
  5. I checked the Vasa-forum, and there Fred Hocker describes that on Vasa the inhaul and outhaul tackles were actually the same tackles. Inhaul actually not very often needed, so if needed, the outhaul was released from theringbolt in the side, and attached to the ri gbolt inthe deck.
    the inhaul was probably  rigged to the ringbolt on the other side of the deck.
    Jan
  6. 8 hours ago, Keith Black said:
    Ilhan. what a wonderful album of photos and your drawings.
    In foto 39, they look like traditional deadeyes. in your drawings, S01 and S07, you have them drawn as traditional deadeyes. What has made you doubt your original thoughts?
     I ask not as criticism but out of simple curiosity.
    Thank you for posting the Loreley link, I wish you the very best in your continued efforts to realize your dream.
    probably while this doesn’t look like normal rigged deadeyes, there seems to be some strap over them.
    Besides: all other stays visible in the pics are rigged with some sort of turnbuckle-like construction.
    Jan
  7. They do not show a considerable amount of detail, but in the Dutch Rijksmuseum collection, there are a couple of pics of Loreley. I took screenshots, and copied the link
    https://www.rijksmuseum.nl/NL/collectie/RP-F-F01148-M
    https://www.rijksmuseum.nl/nl/collectie/RP-F-F01148-I
    https://www.rijksmuseum.nl/nl/zoeken/objecten?q=S.m.s.+Loreley&p=1&ps=12&st=Objects&ii=0#/RP-F-F01148-Y,0
    This one is frustrating: it shows the channels, but not the deadeyes.
    https://www.rijksmuseum.nl/nl/zoeken/objecten?q=S.m.s.+Loreley&p=1&ps=12&st=Objects&ii=4#/RP-F-F01148-J,4
    Holidaypics from a distant period....
  8. And in your second picture they look more like "normal deadeyes".
    I have once seen (and I blame myself for not remembering where) a nice illustration of the systems that have been invented in the rather short period between the mid-1850's when wooden deadeyes were standard, and the early 1900's, when steel turnbuckles were the standard. I thought it was on segelschiffsmodellbau, but the man I thought that posted denied doing so....
    Still thinking and searching …..
    Jan
  9. That is really a close call. Both look great.
    As you say: choice depends on the actual part you are looking at. I prefer the Eduards-version because of the breachlock does look a bot more detailed. But taking the handwheels as your main part, the other one is (marginally) better, at least in the pics. I guess that placed on the model both will be looking fantastic.....
    Jan
  10. Sounds like you have a nice organ. I try to find my way on a small, not so nice, early 20th century one. Bach doens't quite fit to something like that, and Mendelsohn is above my league :(
     I like the 'Psalmbewerkingen in Noord-Duitse stijl' van Sietze de Vries (also not fit for my instrument, but at least I can play them :) )
    I'll folow your upcoming build. Not quite a plastic/small scale myself (actually, almost no modelbuilding left in my sparese time) but I am surprised at the precision of those smale-scale models.
    Jan
  11. Hi Doris,
    Your rigging looks absolutely wonderful. (do you make the rope yourself, or do you have a source for that?)
    The only thing I do not quite understand is the rigging of your top-rope: you used a sheeve rather high in foot of the topmast, I would have expected a sheeve somewhere further down the heel of the topmast (like in Andersons book pages 176/177). Rigging it through a lower sheeve would enable lifting the mast above the level of the cross trees.
    [edit, 10 sept].
    And looking again, I realized that the set-up is exactly as in Anderson, but not with a single, but a double top-rope. I should have seen the other rope going down.
    Did take me some time to understand that what I expected to see, is on the other side of the masttop. (And thus not visible in your pics as all pics show the same side of the model)
    I should have seen it at once yesterday. As one of my teachers said: please think before you are going to ask silly questions.... ;)
    Jan
  12. You could (when you have loads of time) go through the danish navy archive, whether or not there are any usefull drawings. (Nosearch available, no sorting in the archive, so random clicking needed....)
    I found some that may be helpfull:
     https://www.sa.dk/ao-soegesider/billedviser?epid=17149179#208161,39521644
    same here: https://www.sa.dk/ao-soegesider/billedviser?epid=17149179#208163,39521646
    the decks have been marked in red, in this ship, the poop-rail is even lower (ie non-existent), and no deck-openings.
    the other one on the rig:
    https://www.sa.dk/ao-soegesider/billedviser?epid=17149179#208164,39521647
    gaf-rigged, but having a full length lateen yard.
    Jan
