Everything posted by amateur
And yes, making rope although the kit alteady provided it sounds silly, but it was like this: I have a corel-kit, providing 3!sizes. That didn’t eork out: too little variation, so I decided to take the plunge, took the aforemdntioned table, bought a number of sizes (amati, as that was what the shop sold), and started. I missed however the largest size, and made that one myself, usung an improvised rope walk build from lego-parts. You can make your life as simple or complicated in this hobby. That is the fun of it. (My private problem: the complicated route takes more time than I have available ) Jan
Suppose this is a silly question, but doesn't amati provide you with rigging thread? That would be a nice guess for the amount you need...... Using amati-thread, I didn't stretch it. Had no problems whatsoever. I did stretch the rope I made myself (using the amati-thread as basis). Jan
Nice! Can I have a grandfather like you? Jan (ps. I guess one of the moderators will shift this buildlog to somewhere else - no idea where they will place this one. It doesn't quite match the sorting system.)
- 14 replies
- Mississippi Lady
- Matches 21
Stitching sails with sewing machine
amateur replied to Jorge Hedges's topic in Masting, rigging and sails
Hi Nils, is it just me, or does the link not function? Jan -
Help with keel layout .
amateur replied to LEGION 12's topic in Building, Framing, Planking and plating a ships hull and deck
Looking at what I can see from the drawings, my guess woud be: the basswood strips run to the sides of the stuffing box, the strip K4 is glued on top of the basswoodstrips, thus connecting the two (the grey area that is indicated on the drawing) K7 is glued to the inside of the keel. The part of the keel that is not coveredby K4 at the underside is to be sanded away when all is dry and removed from the building board. What I can’t make out: drawing and sketch do show the keel left-right changed... Jan -
I can’t help you, but adding a more ‘informative title’ to your post will probably attract a more knowledgeable builder to you question. Jan -
How did I miss the end ofthis journey? Congatulations on a very, very impressive model. Following your log has been a pleasure. Jan
Those birds are as good as your ships. I especially like the second one: just before getting the fish out of the water. Jan
Prins Willem 1650 by mhkash
amateur replied to mhkash's topic in - Build logs for subjects built 1501 - 1750
The size an number of the gratings is based on the contemporaneous model. So, why should you change? Gratings were used for all ships with a lower gundeck. Real warships had even gratings over the full length of the ship.Or do you mean the number of strips used for the gartings (the size of the holes. Than you should try to follow the rul that the size of the holws is slightly smaller than the with of a foot (ie around 10 cm). The museum-model has holes slightly wider than that, but not as wide as yours. Jan -
Nothing wrong with the gratings: rather like the usual standard in 17th century dutch shipbuilding..... Jan -
Looking for plans or possible models of Magellan's ships.
amateur replied to J11's topic in Nautical/Naval History
Quite a lot of the nao-recontructions are influenced by models like this one, the Mataro-model (on display in the maritime museum in Rotterdam), supposed to represent a spanish nao of around 1450. (Pic from the museum website) (own pic) Jan -
Matthew ofBristol is perhaps more in the correcttime frame, or San Salvador (diego maritime): bit later than Magelhaes, but nice ship... Jan -
You are asking for something almost impossible: in thta period ships were not built accordi g to plans, butbased on main dimensions, experience and rules of thumb. There are some (but ot many) artists impressions ofships around that period, but those drawings, however interesting, are hardly usefull to reconstruct the ships of that period. No ships survived, and acheological evidence isvery scarce. In other words: historically accurate plans are not available. Your best line will be search for reconstructions ofspanish/portugese ships of that period. Quite a number of reconstructions of Columbus ships exist, there is a reconstruction of a Portugeseship (the pepper wreck) that can provide a starting point for your model, but that one is a bit too late. (1600 in stead of 1500) Jan -
The printing is superb. (Although I am still undecided whether I like the slighlymore clunky looks of the PE more than this almost perfect plastics) Question: what do you use for your rigging? it looks as if you have multiple sizes. Jan
Btw: in some of his vids, the robot shows up. Guess this black robot is also doing his ratling down
This guy is fantastic: both his modelling and his filming. He also does wonders with plastic: Jan
No, just too many things at the same time..... And as that is more or less a structural 'problem' these projects all go very, very slowly. All projects (card) that got some attention this summer: only the birds got finished 'in one go'. All others are extended projects Jan
- 139 replies
- corel
- prins willem
If there is more to follow, I'll keep waiting Jan
No, that can'tbe correct. The mast should have and angle somewhere between the rake of the aft mast, and the main mast.i The masts are kind of fanning out: the forward mast vertical, or slightly raking forward, the main mast vertical or slightly backward, the mizzen masts raking aft, the rake increasing from main mast to aft mast. Jan
- 165 replies
- english galleon
- revell
The rivetting of the secondary guns is somewhat too pronounced as far as I'm concerned. Less is more when it comes to these rows of rivets.... Jan
The last "official price" before Mamoli went out of business coupleof years ago was around €450,- Jan
