amateur
Everything posted by amateur
  1. No, perhaps not, but it was standard practice in Dutch rigging around 1700. Why they did it, and when they stopped it, I never checked, but quite a lot of pic on gaff-rigged vessels show a double vang on both sides, especially on the slightly larger see-going vessels. Jan
  2. Oops, I missed the updates on this one. I made that up just now. those Halinsky's are unbelievable. Another masterpiece! I promise: I will follow the next one more closely Jan
  3. Today my amiration for the 1:350 PE builders increased by another huge amount. I deceded to build some 'gunlike' things, in order to replace the kit-provided parts. In the end, I have some partial results (paint still to be done), but it took me far more time than expected. In the previous post I showed how it could have looked like. So here is what I made of it. sides and pedestals added together with some barrel-like things. Actually the forward part was round (watertank), and the back end square, but that proved beyond my capabilities. Making correct sized barrels, too, by the way. They are made of tightly rolled 80 grams paper, but a strip of 4 mm wide proved to much, a strip of 3 mm didn't roll as I wanted.... placed on the conning tower, I noticed two things: the struture is a tad small (it should have reached just above the railing. Second: it does need some kind of chair. The chair I made. The size remains at it is. No-one willever know, as long as you guys don't tell the whole thing is so small that my cellphone camera doesn't focus properly. Will be fun painting. All wheels and other small stuff remains unmodelled. Jan
  4. Do those marines wear a kilt? Jan
  5. I don't think that in a real ship you can hitch a shroud to a rail, without the use of any clamps of pins. So, I guess there is no 'real' answer to your question. You can check how these lines were belayed (most probably) bijy looking at the way it is done in Mediterranean ships, like Tartanes and Chebeques. Those ships have a toggle set in the line just below the lower block on which the line is belayed. (like the one you have above the blocks). (in your case I would go for a half hitch (with the hitch actually between the rail and the ships hull.) Nice model btw Jan
  6. The funny thing is... there are no pics of these small gun-platforms. the drawings suggest double anti-aircraft guns, but the descriptions of the armament do not mention them. No way that the small cardboard pieces come togethet to something like this (G16, an old WWI torpedoboat) It is tempting to scratchbuild., at least simplified: pedestal, side, two watercooled .50 brownings. Jan
  7. This afternoon I finished the searchlights. I experimented with larger strips, but eventually, I decided not the thicken the cilinders: i left them as they are. and the next fiddly bits. No idea what they might represent. Gun -mounts?? They are gping to be placed in the angled platforms on the conning tower. Might be gunmounts, but at scale 1:250 they are strangely high.... ideas welcome Jan
  8. Ah, missed this thread, I just asked you a question on the config you are going to build. You already answered it Jan
  9. Graf Z never made it to the sea. (Only to be destroyed by the Russians). What configuration are you going to build: a 'what if'-version: weathered, battle damaged, or the 'as-build', unfinished, nicely painted, and without planes? Jan
  10. Think: panelling and weathering all the individual planes, placed in a neat starting row on the deck. If someone is up to that job..... Jan
  11. Put on your optivisor; it's there to see for everyone. Although the builder himself claims to have lost interest in this one, he delivered a little gem (again) Jan
  12. But then pops up the next question: how did they get the hawser off the windlass? Get the whole hawser out of the hold, or get the hawser off the anchor-ring? Both seem a lot of dirty work to me. Jan
  13. The V108 is doable (especially when you have ccoyles easy to follow instructions at hand) there are some free downloads at papershipwright, but they are a bit fiddly (more tha v108), but there is Dan cerberus-build, you can refer to in case of emergency (don't tey to match his quality, that is beyond our possibilities ) Jan
  14. Or a decision to start over anew :) ? Mine is still gathering dust. Need stronger optivisors to continue :) Jan
  15. Actually, yellow painted clogs are not that uncommon
  16. I thought so: she will carrying a relatively large number of guns, and the captains quarters are rather undutch in their lavishness. But perhaps I jumped too quickly to conclusions, and she will be some other type of ship (although: yacht?? mortar could be, but her deck-layout is a bit atypical for a mortar, and she is not watertight enough for a sub, although she might qualify otherwise ). Jan
  17. Just a question: dutch flatbottoms always have leeboards. Will this be the first ship-of-the-line carryimg leeboards? And if not, how wil she ever be able NOT to break the line?? Jan
  18. Yup, I was going to type more or less the same. No evidence what so ever that she will float. Jan
  19. Today I did some small parts (actually: nothing left but small parts) first I did an air-inlet. The kit show a very high one, the original drawings a low one, and both appear in pictures of the real ship. I think the low one looks more convincing (as it does not block the guns) the stairs are a bit weird: the kit shows them as flat on the deck. I choose to do some surgery: shortening the "stairs" and making a small grey strip from spare stock to cover the white area. Not very convincing stairs, but better than a grey square flat on the deck. next the small stuff on the deck: bollards and a capstan. The capstan is not designed very well: the white area on the deck is too large, or the capstan too small. Again the spare grey comes to the rescue: a made a base for the capstan, to cover the ugly white. The remainder is standard, and fits reasonably well. finally, I started the searchlights: four of them, all equal. and that was when I decided to stop: sun down, getting darker, and again the need for surgery: or a redo: the front of the lights is too large, or the housing too small. Next job will be cutting new grey strips to thicken the lights somewhat, to get rid of the ugly overhang... Jan
  20. In thecapstan perhaps? As far as I can remember, early capstans did not have removable bars. Jan
  21. Ja, die voelde je op je klompen aankomen (sorry guys, dutch, and not translatable, but very to the point in this thread)
