Everything posted by amateur
Hi Piet, thanks! Card looks an easy medium, but it has its own peculiarities. learning curve is rather steep de beste wensen voor 2019 voor jou en Gwen! jan
Hi Cog, not so strange when you realize where the bends in the hull-surface are. Although I did never realize that the strip where lthe screws are is almost flat. I found it an surprisingly easy hull to plank: rahter boxy, and the curves in only one direction. (My first hull was the statenjacht, that one has curves in every direction ) jan
Hi Marcus, for tips and tricks you should turn to the buildlog of chris (ccoyle). He did an excelent one for starters in card (torpedoship V108). Danny's buildlogs of large battleships also contain lots of usefull tips and tricks. Jan
Hi Adrie, thanks for the suggestion. Does require some practice and trial. my first folds where far off the folding line (and did you start closing revenges hull without showing in your buildlog?) Today I did the first guntower (of a total of four). The Ruyter was a bit undergunned: she had a total of 7 guns, of a 15 cm caliber. Three towers with two, and one with only one gun. The standard practice of three guns per tower was discussed, but deemed to expensive. The guntowers can be turned and the guns can be elevated. Why you should want to do, I don't know, but I succeeded in realizing the mechanism. pics are self-explaining. aThe guns look tiny, but to be honest: at this scale they even should be slightly thinner. Rolling card is not the easiest way to get the thickness right: only after the whole thing is glued, you can see the thickness.... Jan
Sometimes thinking results in a solution.... I removed both ends of the catapult (wich were glued using tabes, and therefore stood a bit outside the box, and replaced them with a small rectangle of the spare grey cardboard that is included. This resulted in 1. A more crisp looking end, and 2. Slightly more clearance. both pucs show the result. Tehy show also smething else: the scaldis card does not like 90-degree folds and too much handling: in both cases the coloured top-layer either breaks or comes loose at the corners... Jan
Small update. today I did the catapult. I had some issues: the thing is a long box-like structure, and the folds were not completely parallel. It needed some persuasion to become straight.... Scaldis made the thing turnaboe (like the gun turrets), using a system of rings and circles to be glued togethet. It works, but I wonder how often I will turn this thing finally, it turned out that it did not fit as it should. I can't get it in its own position: you can see s light ring of white aft of the base. Problem is the deck that sticks slightly too much forward (1.5 mm....). I have to think: paint the deck, or turn it sideways and stick it in the right position, or try to remove the deck.... See...? It touches, while there shoul be a space.... Jan
Hi Kortes, nicely done. your decision to make a stained glass appearance is good: these ships showed the standing of its owner. Just plain glass would not do The other part is called mastkoker. (Not mast in mastkoker). A heavy piece. Attached to the ships bottom, as it is the connection between hull and mast. Jan
And when you all thnk you deserve an update after the second day of christmas, I have to disappoint you. I have a third one running in the background, and that one got slightly more attention this day. (Almost finished, apart from the railings and some nasty little bollards) Jan
- 64 replies
- v108
- digital navy
How many will there be in this display? I think the Maya die Biene version should be included....;) Jan
Hi Kortes, I guess you have seen the original bars on Sperwer? that pattern is very distinctive, more than the rather basic pattern you have used. Did you simplify on purpose? jan
Yep, that is a typhoon. But nice example of how enormous these subs are. Jan
- 31 replies
- ethan allen
- submarine
I use the guterman stuff for bindings an seizings etc. Nice colors, but it needs ca-glue or some kind of paint to fixate the knots. Pva will not hold. Is the unraveling the result of how the thread itself is laid (left in stead of right), or is it the result of the material itself? I ask because when using it as serving-material the direction of the winding mattered. Jan
I thought there was slightly moreyellow ochre in her new colour, but this isreally'hello kitty' rosa jan
I warned you: the size of the parts is getting smaller and smaller. So here is the update of two afternoons of cutting, rolling (ugly words because of the carpet monster), and glueing. Using a flash when taking pictures at close distance with a cellphone, makes the not-so-good even worse All in all I am not too unhappy. Some miscellaneous goodies awiting a bit of grey paint to cover the white. some really small stuff (winches and the bearing ring for the torpedotubes) and when youthink life can't get worse, you encounter this: which turned into this (took me the better part of an hour) again, some grey needed to do some covering up. Not now, as the card is still a bit unstable due to the water in the glue. (No, I am not going to use CA for this: far too small too handle for me. I need safe glue) and some present state pics. Fore deck with whinch and water breaker Cabin with stearing gear, lights and support struts. And the last one: all the little stuff installed (except for that range finder) flash highlights the white sides, even when they are harly visible to the eye in normal daylight circumstances. And now my eyes need something easy Jan
- 64 replies
- v108
- digital navy
Hi Greg, every time, I am amazed by the optical illusion you create with your paintgun.... I would easily beleive that those ribs are really there. Jan
