amateur
Everything posted by amateur
  1. But a square hull would never do Although: most working ships tend to be rather box-like: the main frame of a tjalk, fluit or aak, all tend to be rather square. and it is a mis-conception that dutch calvinists did not like beautifull (and expensive) stuff. Quite a lot of expensive houses around..... jan
  2. Yes, but also the wrecks found in the Netherlands show rather artistic use of timber. Regulated building didn't exist: as long as it was watertight and floated, it was OK. Jan
  3. I thought the radius of that brass strip would be larger. The quality of your metalwork is great. question: you said the metalwork will be left visible. Does that also holdfor those casements? And if so: how are yougoing to polish them without damaging your superb hull finish? Jan
  4. Like Chris ( @ccoyle) I am going to use the papershipwright railing-template. The question is: which thread to use... too thick is probably a bit unsightly, but too thin will (At least, I think) have problems to get it glued in such a way that it becomes stable... second question too think: white, and apply glue, or go to the gutermannshop, and find something in the more-or-less correct grey..... Jan
  5. But the spacing in the deadeyes should also fit the placing of the gunporst below: you need the chains ending between the porst, not in or above..... Jan
  6. To be honest, in this stage of the build, I would ignore the error. Had I discovered it earlier, I wouldhave checked the position of the canons. Kitmakers want to overdothenumber ofguns. In the Prins Willemby Corel, thenumber ofguns is almost double theone that the ship actually had..... The most forward shrould should be almost in line with the mast, taking it far backwards is also an error, wich will attract more attention than the one you want to solve. Jan
  7. Beautiful rudder! question: you are not using black paint, but black wood instead. How are you going to apply the distinctive white striping? Jan
  8. Maritiemdigitaal is the portal used by the dutch maritime museums to their digital database. The quality of the pictures differs between the museums, and there is no way to order high quality copies of the pictures/foto's/drawings shown. But as the museums have invested in this system,they have no own database/ordering system (the fries museum being an exception, but even there is no download-option/ordering option) Jan
  9. Hi Kortes, nice tiller. When the tiller is completely to the left or right, does it stay clear from the bulkhead? Very ofthe the tiller has a very subtle curve upwwrd, just to make sure that it does not touch the bulkhead. Do you also plan to add the eyesbolts to attach the flagpole to the rudder? Jan
  10. @Marcus, the only one I am aware of is the navy-archive, that has almost all pre-wwII ships on line (in very high definition, and lots of detail drawings. next to that is maritiem-digitaal, but most of that is low-resolution, small sized (like the one of the leeboard, posted above). Apart from that, I do not know of anything..... Jan
  11. What do you mean? The foto is exactly like the drawing: the bolt is just below the mid-line of the leeboard, there is only one difference: the number of planks used: 8 in the drawing, 7 in the leeboard of the sperwer. the curvature of the leeboard is too small to be seen in the picture. Jan
  12. Btw make sure the bolt is in the correct place: it is slightly below the centerline of the leenord, not on the centerline. this image shows a drawing of a portside leeboard of a friese boeier (drawing downloaded from maritiem digitaal), newer than Sperwer, but valud for almost all boeiers, i guess) Jan
  13. Although a boeier that does not shine like a mirror is considered to be ‘a bit neglected’ . modelling standards and ship-standards clearly no not coincide are the leeboards flat, or do they have a curved profile? jan
  14. Completely in Dutch, but some mice pics of the ship https://www.ssrp.nl/stamboek/schepen/sperwer (there is a nice drawing of the rudder, with a sperwer on top) Jan
  15. Wooden hoops almost never show up in these dutch veseels. wefalk: we refferee to different things: boeiers are not build on a vertical keel, always on a flat bottom plank. but I thought you meant that the ships was build on a broad bottom board, with a protective strip in the middle of that board. that - to my knwledge - was never done with boeiers, they have a bottomplank that is thicker than the normal hull planks. the rope to secure the mainsail to the mast has two versions: one single rope, or -as is seen in one of the pics above - a series of single, diagonally placed ropes, alsays with these klootjes to minimize friction and the wear on the rope. Jan
  16. Hi Wefalck, are ypu sure on the bottom plank? It is (as far as i interpret the drawing a fairly thick planck, with a rabbet that holds the first planking strake. finny thing on these ‘keel’s is the strong tapering on both ends. jan
  17. As I wrote last time, the 'normal sized parts are done.... The stanchions for the deck: the lights (other side is red :)) skylight... all put together, and as usual, the naked eye (at least, mine) is more content with real life than with the pics. My admiration for orher card modellers goes up by the minute and now for some small fun: and put together, it looks rather OK Tonight I'll try the other side of the ship (same parts, nothing new...) Jan
  18. Does Martanek still build his models? He used to post in MSW, but has gone elsewhere..... Jan
  19. Boeiers are almost never converted to housing. Too small for that, and their price as sailing yacht issimply higher than as converted ship. Quite a lot of them survived, as this type of boeier is relatively new, and they are still build (both wood, oak, or sometimes in steel). As they never were working boats, theyhave been cared for, and have a relatively long life span. I like your model, it has the right atmosphere. Jan
  20. Wow..... just a question: was the dazzle also applied to the deckhousing between decks, or just to the hull? Jan
  21. At ScapaFlow, Sms grosse Kurfuerst (same class) ended upside down, you can see the place of the rudders quite good on these pictures. they are slightly inside the propshafts. jan
  22. “My” shop was more the oldfashioned one. Went down as no-one seems to know what a radio was. Jan
  23. And welcome from just around the corner (well, almost) Jan
