Everything posted by amateur
And welcome from just around the corner (well, almost) Jan
Kingfisher by amateur - FINISHED - 1:1 - CARD
amateur replied to amateur's topic in Non-ship/categorised builds
Ah, well....it took some time, but he is finally on his legs. finished. Not completely happy with the stand, but it will do. pics are cellphone, no flash, so the quality is not superb Jan -
Hi Kevin, he only takes three days to tell us that he went to an exhibition...... Dafi just likes a bit of drama. Jan
My wooden builds are gathering dust today I did some small stuff. The larger building blocks are done, detailing does cost a bit more time. The first parts for the firecontrol (or whatever, used for the anti aircraft guns) second thought: no tabs (There is an error here, but I am not inclined to correct it ) the aircraft platform: (with some weight to keep it in pl-ace while the glue sets) two skylight. Looks OK from this distance, but don' go anywhere near And finally: the last page that wasn't used till now. these are the gun-towers. Lots of tabs (needed this time), and a rather complex way glued rings to get the towers movable) you get the point of the ship being undergunned when looking at these towers: this is all there is with respect to guns. Jan
And this is what Adrie means for the Zwarte Zee: rather fiddly stuff in there. the main parts page for the zwarte zee (1:250, grey version). The ruler is 30 centimeters long. Jan
No, starting twice is not what I want to do. I'll check to see what can be used, and do not use the remainder. I do not quite lije this type of laser cut, the HMV version, far more fragile, looks better. Jan
I had the camouflage in my hands today. That one is compeltely redesigned compared to the grey one: other parts (more, actually), and other constructions. Iguess the issues with the camouflage version are others than with the grey version. with respect to the railings: I have the laser cut set, but that one is made for the camouflage version, so the numbering is a bit of a puzzle..... Jan
Today, I made a serious mistake..... I went to see a model exhibition. (No pics, forgot the camera) they had also some sales over there. In my current building speed this will get me almost till my retirement Jan
No, you didn't miss anything. It is just that parents take their beloved children with them on their holidays Jan
Hi Remco, Are you still building, or have other things got between you and the workshop? Jan
- 1,215 replies
- sloop
- kingfisher
Hi Ed, can I ask a question on the stays? they seem to have a spliced eye at the masthead, but thay are also fixed at the lower end. How did they set up these stays, is such a way that there is enough tension? Jan
- 3,618 replies
- young america
- clipper
Do I know this tutorial ? I should have saved it last time, but this is even better Jan
- 65 replies
- fish hooker
- fishing
Gluedfingers? Jan
However, that proces is far more difficult in a bluff-bowed ship. I don’t know how it is wirhbthis ship, but in my PW the distance between keel and deck was largest somewhere in the feont part: the frame length is comarable, but the sheer is quitestrong, i needed an additional plank there. With second planking. I choose to let the planks run slightly lower, and added a stealer as top plank (hope you understand....) Jan
Hi Adrie, Question: where is your build-log of the Ruyter to be found ? (some way or other I'm interested ) Jan
And greetings from the other half of the low countries Jan
The problem is: the plywood needs predrilling (otherwise the splitting risk is large, and becomes larger by using a heavier hammer). On the other hand: predrilling will give unsightly holes in your planking that will not close without using filler. You may try sharp, thin pins in stead of nails. Usually works better than nails. I liked using clamps, like shown here: Jan
Using violence is usually not a good idea. using clamps is sometimes a much better idea. Second question: which parts do need pins while the glue dries? Most of the time, parts should hold their place without pinning them. Jan
