Everything posted by amateur
Schade, schade. Ich dachte du hat endlich etwas neues gebastelt. Aber du bist nicht einmal zu hause. Und wie sollen wir wissen am welchem Huegel du sitzt mit fanta und ein Stein!?? Jan
I checked again onValkenisse, valkenisse has slightly more space between the halfdeck and the mast, so that the knights can be placed on the halfdeck. Not an option for you, thouogh (unless you decide for major surgery). You need that heavy knight behind the mast though. So yes, placing it on the halfdedk would be an option. Don't forget: it should not be on the heartline of the deck, but slightly ro the right (or perhaps the left, I'm not going to decide that for you ) You also need a place to attacht the lanyards of the stays (the ones for the topmasts, that is) For my Prins Willem, I find the belaying plan of the Pinas by Hoving very helpful, although some improvisation is needed, as that ship has for sails less than Prins Willem. Jan
Hi Piet, I don't know whether you can disregard the boordknecjten (napier translates it as kevels, in his book on Valkenisse). Even Valkenisse (large VOC ship, 1717) and the famous Dutch twodecker (ship of war, 1670) have a number of them. Also Witsen (may be Van IJK) describes these things, also for latger ships. You need a number of those heavy kruishouten, mainly for the lines of the main sail. Also a fair number of belaying points around the foor of the mast (I have too f ew of them ,even though I don't install sails). Those belayingpoints on the mast are for the parrels. Alsmost all others are belayed to knights of abelaying rack etween the knights. All knights at the foor of the mast have sheaves in them. You need largerknights with sheaves for The halliards, but smaller ones left and right behind of the mast for more heavy stuff. It's a pity that Rob Napier didn't include a belayingplan to his book. You could have used that. Jan
Hi Sandor, The pic you show is not 'just an other modl'. It is the model (or a very good copy of it) that is owned by the naval Museum in Den Helder (Netherlands). It is a model build by the original builder of these ships, and shows the ship 'as build'. In your case i would believe the planking pattern of this model. Jan
- 15 replies
- cannoniera olandese
- mantua
Ah, that's why your hair looks so gorgeous @Chuck. I bend the planking using a iron, using the model itself as a guideline. I find it alomost impossible to get the correct bend in one go. So I make a bend, try it on the ship, and repeat, until the desired curve is there (or, in my case almost equally likely, I have to start over again, as the wood splitted) Jan
Hi Kees, I wouldn't label that as schematic.... Quite nicely detailed on this scale. Jan
- 434 replies
- pelikaan
- beamtrawler
But as long as those still look way better than my own best efforst, I wouldn't mind looking at your glitches (Not interested in buying, though ) Jan
- 191 replies
- young america
- clipper
And dont forget that most mast are sllightly thicker above deck than at decklevel. Also, the taper isn't straight, but 'circular' Jan
She's looking gorgeous! I like her profile in the last pic. You're not going to complete this one, then? Jan
- 191 replies
- young america
- clipper
I have read very mixed reports on those pins. I used very simple push-pins for the job (the ones with a plastic head). Did quite well.... Jan
- 652 replies
- royal william
- euromodel
Sovereign of the Seas kit (was there ever more than one)
amateur replied to mtdoramike's topic in Wood ship model kits
Sorry, not old enough to answer your question..... Jan -
Hi Mark, Thanks for the link. missed that one. Jan
- 434 replies
- pelikaan
- beamtrawler
Hello Kees, Can you give some details on that tool you have attached to your table. It looks like a very usefull one for making windows. Did you buy t, or is it completely selfmaed? Jan
- 434 replies
- pelikaan
- beamtrawler
You're ageing very fast Crackers! (two days ago you looked quite young, although a bit tired) Perhaps you should see your GP.... Jan
- 434 replies
- pelikaan
- beamtrawler
Continental Frigate Hancock by wyz
amateur replied to wyz's topic in - Build logs for subjects built 1751 - 1800
Interesting restart! (I have a couple of unfinished ones as well, but I don't think they can be brought back into life.....) Jan
