Everything posted by amateur
fairing technique
amateur replied to michael101's topic in Building, Framing, Planking and plating a ships hull and deck
It seems that they are off both in breadth as well as in height. That's tough.... Question: are the frames properly centered (left/right the same distance from the keel, or were the pre-cut slots off-center? Does the kit have a drawing on which the frames are depicted? If so, can you not check against those drawings which frames are more or less) correct, and which ones are off? Jan -
Hello Kees, Like NIls, I'm very interested in how you go from here: you started detailing the hull, but I understood that this hull is the master, you are going to use to fabricate a negative mould. But how are you going to get all this fine detail in your final hull? Casting, vacuum? Jan
- 434 replies
- pelikaan
- beamtrawler
The easiest way is just go by Corels instructions. They are relatively easy to follow, as they give eachblock and belayingpint a number, and the rigging instruction says which order you have to follow fromblock to block. They also follow the standard practice: first the shrouds, next the stays, than the backstays, and finally the running rigging. Standing rigging was treated with stockholm tar, a dark brown oily substance, which acted as a preservative. running rigging wasnt treated. For the ratlines: draw a template, and keep that behind the srhouds to get your lines evenly, and prevent the outer shrouds to be pulled inward, as a resukt of too much tension in the ratlines. alternatively, you can try to come somewhat closer to the original practice, and buy a larkger range of blocksizes and rope diameters. In that case don'tmake my mistake..I did not make a complete overview of what should go where, so i had to redo quite a number of my blocks and lines, as I discovered too late that iput thewrong size in the wrong place .... Jan
- 139 replies
- corel
- prins willem
If this is your weekly wage for restoration activities, you'll get pretty drunk after finishing the Norske Lowe Jan
- 14 replies
- yacht
- restoration
We won't follow the rigging plan, although I'm pretty sure that it is better than what the Asian factory did a couple of years ago Jan
- 14 replies
- yacht
- restoration
That's one of the logs I referred to, yes. The other one is this one: http://modelshipworld.com/index.php/topic/5431-vasa-by-karleop-–-billing-boats-–-reviving-a-poorly-built-model/page-1 Don't misunderstand me. Wasa is indeed not an easy one. And there are more projects of this size that end somewhere long before the finish line (not alway sthe large, sometimes also the smaller ons that end their lives unfinished in a cupboard) The only thing I wanted to stress is that Billings Vasa has Always been the one closest to the real thing. And no, a ship like Vasa isn't the easiest start in modelling. Jan
My two cents. Start with a not too diggicult plank on bulkhead kit, to get the feel of planking. For the wasa kit, try the lime/baswood. It is easy to work with (far easier than dries out abachi), it is easy to shape, easy to bend, and quite tolerant to overbending (hardwood like walnut (european kitmakers favorite) snaps at toomuch bending. Also, by more than you need: easier to replace a not so well placed strip when you have enough of them. Btw: -although billings is not the best in drawings, manuals or materials, their research is quite good. billings wasa isbetter than themore expensive versions of corel or sergal (although the 70-ies version micgt be less, as they redesigned a couple of times as research on the wreck showed new There is a billings build log somewhere here on msw that shows what you can achieve from the kit. Jan
It might also be something that was rather popular inEurope: called Uhu-hart. No ca, no pva. As far as i know only to remove mechanically (and some problems in regluing with normal PVA). But i agree:riping of and starting over is the only option. Reconditioning old wood isn't the easiest way. You might try to get some basswood: not too expensive, far easier to work with than the Abachi billings provides. Jan
The designer of this kit (Chris Watton) has shown us the development of this kit. He has tried to design the kit in such a way that it does give a stunning model if build out of the box, but has also plenty of opportunities to go even further. The results is therefore a model that is very detailed at all (deck)levels. So, the choice to go for planking an dnot for lasered parts is a deliberate one. (as far as I understood the presentation of the kit) Jan
- 133 replies
btw, will you follow the newest insights on her colour at Trafalgar, or will yours be Vic as all people born before the year 2000 will remeber her? Jan
I hope there willbe an official fotoshoot of the finished product in the gallery? Would love to see some overviews and deckdetaios. Jan
Hi danny, Looks like a lot of work. Are you ging to replace those famous plastic blocks with better looking ones, or did you decide they fit in with the general appearance of the model? Jan
- 59 replies
- norske lowe
- billing boats
No, it is a temporary replacement of a wheel. (To be nailed over the gun ale, in case the wheel iis damaged through enemy fire) Your. 1:100 version has no way to nail it as shown in the book the only thing I wonder: assume a wheel is shot away during battle, how on earth do you nail such a thing under a gun truck, while a heated 3tons heavy gun is on that truck, and enemy fire is all around? And the bok is very nice (its a pity that google does not scan the fold-out pages properly...) reading those books you can not but conclude that re-using pictures of other people was very common in earlier days. Quite a lit of pictures from this book are very familiar fromother books.... Jan
Give me some time, reading three such volumes, without knowing what to lookfor, may cost some time Jan
Rather cryptic I see two sailors, one sitting on a chest (with those two halve wheels behind his back), looking in his open chest, holding something on which a hook is attached. Or is the hookthingy held by the standing sailor? Also: I don't recognise the traylike thing the sitting sailor has on his lap. And: I don' know neither Wimmel nor Röding.... Jan
Hello Dan, Congatulations on another very well executed build!! one question (perhaps you already explained somewhere): how did you actually form those hanging rope coils (esp the loop it hangs on)? Jan
OK, two half wheels that arde not really to become wheels (how inattentive of me: they never could be: they have a square hole in the middle ) second guess: something to prevent a running heavy cable to do any harm? Jan
