Everything posted by G.L.
I also use mainly white wood glue for modeling. After applying the glue I remove stains with a wet rag. I works well in my opinion. On the other hand I do not have experience with epoxy. Don't you have to mix two components in an exact ratio an aren't there temperature restrictions to use it?
19.14. The spars. The topgallant and the spreader A lot of smacks had two topgallants, a long one for use in summer (approx 10.30m long) and a shorter one for the winter (approx 8m long). I will place a summer topgallant on the mast. To make the topgallant I move from the kitchen back to the workshop. The making process is almost identical of that of the mast. First I saw and plane a pine stick in a squared shape. I scrape it to an octagonal shape. And finally I sand it round. At the frontside of the mast, the spreader is attached on top of the trestletrees. I make the spreader of apiece of oak. The backside of the spreader narrows towards the outsides. The two holes of the mounting bolts in the middle are reinforced with a square brass plate and in the two ends there is a groove for the backstay. The two mounting bolts fit into the holes in the trestletree. gluing the spreader into place. The mast with spreader and topgallant. The total height of my cross section is now 135cm (4ft 5in) and there is still a wind vane to be added. The wind vane is made of brass. The parts: Everything soldered together: The vane itself is made of a piece of cotton. I color it with red ink and afterwards I rub it in with textile glue so that it doesn't start to fray. Then I cut out the vane and attach it to the arrow. The wind vane on the mast. Another 2.5cm added to the model height.
- 219 replies
- smack
- cross-section
Well Carl, I do my best to make it look as much as possible like a smack. Thanks for the reaction. G.L.
- 219 replies
- smack
- cross-section
Very detailed! Nice work Patrick. Your next gun doesn't look very easy to build.
- 756 replies
- galleon
- golden hind
This week, the only thing to report is that the port shrouds are also provided with ratlines and staves.
- 219 replies
- smack
- cross-section
Thank you very much for your encouraging words, Carl, Gary and Pat.
- 219 replies
- smack
- cross-section
As you show it in your images, it looks all so easy. But is surely isn't. Beautiful craftmanship. Congratulations.
Practice makes perfect. Slowly I find my way in making the ratlines and at the end of the week the whole starboard side is done. For the upper three steps the spacing between the shrouds becomes too narrow, I replace them by staves.
- 219 replies
- smack
- cross-section
Now the rat-lines have to be tied to the shrouds. Seems a very boring activity to me, but it has to be done. At the bottom, just above the upper dead eyes comes a stave. On smaller boats it was often a wooden bar, but on a smack it was an iron stave, served with rope. I served a 1,5 mm brass bar. The stave held into position for rigging. The port stave rigged. Both staves rigged. I clamp now a card with the rat-line intervals against the backside of the shrouds. A ratline is a piece of cord with a loop at both sides. It is parallel attached to the shrouds at equal distances. It is tied to the middle shroud with a clove hitch. And the loops are attached to the outer shrouds with seizings. I am not very handy with rope work. Here is my progress after a whole afternoon.
- 219 replies
- smack
- cross-section
Looks nice with the light on. You're not the only one working in the garden it is the same situation here. This week I spend more time in the garden than in the workshop but it is as pleasant.
- 756 replies
- galleon
- golden hind
Thank you Carl and Patrick, This week I continued with the shrouds. Now I can connect the lower dead eyes with the upper ones with the lanyards. A knot at the end of the lanyard at the backside of the first hole in the upper dead eye prevents it from slipping out of the dead eye. The lanyard is going down and up through the deadeyes like shown on the pictures. The end of the lanyard is tied up like described by zu Mondfeld in his book 'Historic ship models' The following order of rigging the dead eyes is first the starboard forward shroud, followed by the port forward shroud. Then the starboard middle shroud. The port middle shroud. Then the starboard after shroud And finally the port after shroud.
- 219 replies
- smack
- cross-section
Thank you, Mark. This week I went on with the mast. 19.3. The spars. Rigging the mast The rigging job starts with making rope for the shrouds. Three strings of four black yarn. Serve the shrouds for the eye seizing with my self-made serving machine. It is inspired by the Syren serving machine, but surely not as good. The first shroud is a single one for the starboard side. With the shrouds placed, the mast will be finally into position, so I may not forget to place the roll of the jib boom roller. The forward starboard shroud laid around the mast. On top of it comes the forward port shroud. Then it is the turn of the next starboard shroud which is a twin shroud. The very last one is the twin port shroud. I will now attach the dead eyes to the shrouds. To place them at a parallel line with the lower dead eyes I pin the top dead eyes on a wooden board on which the level is marked. Making the eye seizing. Then the end seizing. And finally the middle seizing and cutting the surplus of the rope. The three starboard dead eyes are rigged. The loose end of the shrouds are at the aft side of the shrouds. After some time the three port dead eyes are also rigged. Here the loose ends are at the forward side.
- 219 replies
- smack
- cross-section
Good solution. Je moet er maar aan denken!
- 756 replies
- galleon
- golden hind
That's what I call eye for historic detail.
- 756 replies
- galleon
- golden hind
I have no words to describe my admiration.
- 3,607 replies
- young america
- clipper
Patrick, looks great. I don't see any error in your hull. Why is one gun carriage stained in brown and the other three in red?
- 756 replies
- galleon
- golden hind
GIGINO by mhkash - FINISHED - brigantine
G.L. replied to mhkash's topic in - Build logs for subjects built 1901 - Present Day
It is indeed a very nice winch.- 26 replies
- gigino
- brigantine
