Chuck
Administrators
Posts posted by Chuck
  1. Thanks guys.
    The flag was made from the tissue paper you use to pack a gift with.  Its white....you can buy this stuff anywhere but this particular stuff is very thin.   I dont have a brand because I literally went into some old boxes we use to wrap up Christmas presents and took some out of the box.  But you should experiment with different brands and thicknesses.
    I basically use a jpg. image of the flag which has been sized in Microsoft word.  You could skew your flag ahead of time in the program to make it easier to shape but I didnt do that.  I just printed out the standard rectangle.
    First you print out the flag on normal paper so you can see where on the paper the flag will print.  Then you carefully tape the tissue paper over that image on all four sides...the tissue paper being slightly larger than the flag.  Then print the flag again after placing the paper in your printer again.
    Cut the flag free from the tissue paper after it dries.  Cut it right along the edges with no white space showing.   This next step is important.  The tissue paper is so thin that the ink will soak through to the other side but NOT entirely.  So the first thing you need to do is flip the flag over and spray the REVERSE side with some Krylon Matt fixative.  Dont be afraid to spray too much.   This will facilitate the ink soaking through to the back side further and it will look like it is literally printed on both sides.   Then after it dries flip it over and spray the front side.
    Shape it to suit with various size dowels.  You can also spray the fixative more to really soak it because this makes it easier to shape...you can do this several times if need be.  Once dry it holds its shape.
    Then I poke a hole with a sharp awl in the two corners so I can lash it to the flag halliard.  Done!!!:)
    Hope that explains it well.
  2. I know I am going a bit in reverse here, but I managed to rig the yards and complete all of the rigging today.  I will have more detailed photos as I sort them out but since I havent posted in a while I thought I would show the model as it stands now.   All that remain to be done are the anchors and buoys and the entry way stanchions.  Plus a little clean up.  But I still try to sneak in some model time even though it has been crazy nuts lately.
    The yards were made from square stock....taken to octagon and then the outsides tapered and rounded off.   Once painted black the blocks and stirrups and horses were added along with the other half of the sling.
    The same was done to the topsail yard.  I will have plenty of more detailed images of the rigging once Mike drops by with his camera.   He doesnt know this yet but I plan on asking him to help me photograph this stuff.  Photographing rigging with a point and shoot is impossible.
    Anyway here are the photos.  The flag is just a test and I am living with it for now as I try new things.   I like it but I dont know how much.   Its printed on tissue paper for wrapping gifts with my inkjet.   Then its sprayed thoroughly with flat clear fixative.   It is soaked pretty good and molded before it completely dries.  This stiff may be too thin though...but lets see what others think once they see it in person.  It does shape nicely with various size paint brush handles.
  3. I mostly see Swiss pear and pear sold as slabs.  It isnt impossible to get 8/4 or even 12/4 stock but its not easy.
     Try calling Gilmer.  They have great stuff and if you dont see it on their site they probably still have more on the premises.
    https://www.gilmerwood.com/categories/38-boards-and-blanks/products?utf8=✓&filter=Pearwood&category=
    Chuck
  4. I would do exactly that but time is precious lately.  That mention to send a PM for help was meant for any other folks in the future.  It would be easier to for me to just ask  specifically what a member wants and then tell them what to click off.  I just think posting all that here would clog things up in this topic.   I am trying hard to help everyone I can, and make the site enjoyable for them.
    Chuck
  5. Eric....for example I just created a new default stream for what I think you want.....I have the same selections available as you do and it seams to be working fine.   I think you were clicking the wrong filter setting options when setting yours up.  But check it out under activity.....is this what you were trying to do??   If it is...just make it your default.  NOW I cant set up a million default streams because everyone uses the site differently.....
    So rather than post a very specific issue here while getting frustrated.......just send me a PM and tell me what you want your current stream to do and i will tell you what boxes to check etc.   It all works very well if the correct selections are made.
  6. You are selecting all the wrong settings for what you expect to acheive.   When creating a custom stream make sure you select the correct "content type".  This should have only the "topics"selected.   Under "show me"   make sure its just "content" that is clicked.  I could go on...
    Then when viewing it.....you can make it the default version which will display on the top right of the screen and it wont be buried.  It will be there right on the top.  Other than that you will just have to adjust.  Also as mentioned.....the condensed version after viewing makes a huge difference.
    I can also set up a new default stream for content that you posted to.   If that is something more than just one or two people use.
  7. As I mentioned.....an electronic version is coming at some point soon   But as it stands currently, no.  Think about the membership numbers if we were to just save the journal as a PDF and send it out without any protections.   One guy becomes a member and gets a PDF and then emails it to all the folks he knows in his local club or here on MSW for free.   Membership in the NRG would take a big hit.  So they are working on a more traditional and official electronic magazine subscription type thingy.  Its coming!!!  But I dont know too much about the details and Kurt or Toni can probably elaborate when they get more info together and closer to enacting.   But that is for another topic and another day.
  8. Well done....excellent reference for casting cannon.   I also find that sometimes air gets trapped int the trunnion pin of the molds even when vented.  But a good solution I found was to make the trunnion much longer as the air seems to be trapped on the extremities of the pin mostly.  Making the pin about 1/8" longer on each side does the trick.   Then you can just cut them off to the proper length before you use them.
    Chuck
  9. You are welcome...an FYI also.  I have reduced the number of default streams to just four for simplicity.   But I can create more default streams for everyone.  There is one hitch....I cant select individual forums like you can for creating your own.   So I CANT for example create one for you to just see the unread build logs.  But you can create those as well as any other.   I can however create other simplified default streams like the three already there.   So let me know if you guys would like that.
    But keep in mind that too many would clutter up that drop down and might be confusing to some.   However with careful naming it may be helpful.  So let me know.  :piratetongueor4:
  10. I also adjusted the number of default activity streams under the "activity" drop down so its less cluttered.  I removed the streams that we wouldnt use.   So now you just see the Unread content stream which is improved and the Content I follow.
    Plus you can create your own under "my Content streams"
    The more I get familiar with the options I will tweak whats showing for better usability.
  11. Also
    As an admin, I am able to adjust the filter settings for the default activity streams under "activity".   So I just adjusted those to be more specific to our needs.  Now when you click on the default stream of Content I follow it should be much better.  It will show you only the topics you follow.....both read and unread.    Same is true for "Unread content".   This stream will now show you the same, but only unread topics since your last visit.   Before I adjusted them they included too much and it was confusing.
    So please try it again since my adjustments and remembver to hit the condensed display because its easier to read.
