Posts posted by Chuck
Thank You very much
I basically use a lot of simple square knots. I try not to complicate things. Half the battle is using the right sized line. As soon as time allows I will try and put something together.
Chuck
- mtaylor, Engelmann, Ryland Craze and 3 others
6
Here you go....if you can find an 8 1/2 x 11 sheet of self adhesive label paper I recommend using that. It makes things a lot easier. I know you only need one sheet but for future projects it worth the investment. You can buy self adhesive paper that is micro thin on ebay.....25 sheets per pack.
I am about to make the two yards for Cheerful and the center of each is eight sided. So I am going to start with a square stick and then turn it into an Octagon. I will round off the ends and taper them afterwards. I am using the 7/10/7 template to mark the stick so I can create the eight sided shape.
When I was preparing my square stock I thought that everyone would probably benefit from the template I am using and created. It will save you time so you dont have to make one. Attached is a PDF template that is prepared with the correct ratios. I have been using it all along to make the masts and other spars. Its a very handy template to have.
Chuck
Its really not a fair question. It depends on what you will be satisfied with in the end result. The old motto is true...."you get what you pay for".
You can spend 5 bucks for a chisel or you can spend $150 for a better one. My guess is you will not be happy with the $5 chisel and will end up throwing it away. You can spend $30 for a bandsaw blade or $225. Etc. Etc....
You get what you pay for. This hobby is certainly not going to allow you to build models like this one below for $200 - $300. Its an expensive hobby once it grabs hold of you. It just depends on what you will be satisfied with in the end. Again its not really a fair question because some folks are willing to invest much money (if they can) and much time tobuild a model like this....but many are just as satisfied with a less ambitious result.
If you are going to spend $1000 bucks on something that will take you maybe three years to complete I would say that is a very reasonable and inexpensive hobby. How many people spend just $335 dollars a year on a hobby for decent results. Especially if its something that will give you years of pleasure and enjoyment. I know guys that drop 100's every month bowling on a league......for me its just not worth it. I think that kind of money is better spent on ship modeling is.....so again....its not really a fair question. It more about how much do you really want it. You spend money on what you are passionate about and everyone is different.....I spent 200 dollars on a cheap saw once because I couldnt afford a good one. It was a terrible decision. Finally I saved enough to buy a Byrnes saw and it makes the hobby much more enjoyable. And that saw will last me a lifetime while the cheaper one was good for nothing out of the box.
Its pretty straight forward....I am sure you could find either someone who has done that to this kit or even look at the NMM site. They have sailplans listed. But maybe someone who has done this already will share their templates. I never made any because it was not called for at the time when in development.
see this topic
http://modelshipworld.com/index.php/topic/13442-sail-design-for-18th-century-longboat/
Chuck
Its really a VERY simple answer. Dont Use the Ancre plans at all. Dont use the Ancre drawings at all . You can learn a great deal from those books as a reference and source of inspiration but rather than replicate them and adding more to them....simply pick a 74 gun ship other than those from a plan by La Charpente....get the original drafts of a similar 74 and draft your model plans from them, using the knowledge you have gleaned from the Ancre books and other sources while avoiding any copying/duplication at all. Thus you will have created an original Kishmul set of plans that are entirely your own.
Otherwise you would be really walking a thin line ....If you have the knowledge and skill to fill in the blanks that are missing from someone elses efforts....then certainly you would also have the chops to not use someone elses efforts as a starting point, and instead...simply flush out a whole new project from A thru Z ......rather than take A thru M from someone else and then supplement with your own N thru Z.
Chuck
- Matrim, CaptainSteve, -Dallen and 7 others
10
Maybe...but as you can see by the photos it really isnt needed...they cleaned up real nice and look even better in person...
- Canute, mtaylor and thibaultron
3
Thanks Allan
Yes the traveler ring is not made from wire that is usually the case. It is made from 1mm brass tube. Its easier to use and looks better. You cut the rings like you would if you were using wire. Just wrap around a dowel and then cut with a saw. Then a small length of 24 gauge wire is inserted into the tube to close it up...you can push it pretty far into the tube so no solder is even required. But first you should slide your shackle and hook onto it and then close it up....those are also made from 24 gauge wire.
Al
Unfortunately I cant add to an order already submitted. Its protection for you and your CC's are deleted immediately after the order is finalized.
This is how the traveler ring looks after rigging it. The jibsail and foresail rigging is now completed. All that remains to rig are the two yards....once I make them. That will complete the rigging and then its the final stretch with a few additional details....anchors....flag....boarding ropes......and she is officially done.
That can be corrected easily....I wouldnt worry too much about it. Just start cutting planks slightly wider over the next few strakes. But dont correct it all in the next strake. Spread the correction over the next two or so and it wont be noticeable. Before you know it.....you will be back on your tick marks.
Chuck
- Erik W, Dubz, Ryland Craze and 10 others
13
The club is meeting on the 14th at my place but anytime will work...we can work on those shrouds while I do some rigging on my Cheerful too!!! I set aside a traveler ring for you.
- Stuntflyer, Canute, mtaylor and 1 other
4
Mike
You will have to show me when you drop by the shop. Today I am preparing to start the running rigging. The first thing I did was make all of the hooks and also prepare the traveler ring for the jib rigging. The traveler ring has both a shackle and a hook. A simple version is shown on the plans but I will be using the traveler ring available "ready made" at Syren Ship Model Company. It is ready to use right out of the package. It has a 3/8" inside diameter. They can be finicky things to make.
Now if I only remembered to slip one of these on the bowsprit before I finished the standing rigging!!!! No worry though. I will be able to assemble one in place.
Chuck
- Mirabell61, albert, Erik W and 24 others
27
His site is no longer active and we never created a downloadable document. I do have all of the info however and its one of those things still on the "to-do" list.
Chuck
Just a suggestion....sand off the laser char entirely from the keel pieces. Before you ad anymore frames. It will be much more difficult as you move forward. I know it will b epainted but it will be a muddy color if you dont.
- jablackwell, Canute, RichardG and 4 others
7
The hull is also NOT broken into two or three bands like some do.....this is also true of the Bellona model that shows contemporary plates on a model. I believe that is a much later application and if you are building a 1770-1790ish model one belt like this is more appropriate. The plates more or less follow the run of planking.......beautiful....insnt it? I plan to plate Winchelsea. I had a flood a few years ago that wrecked the planking. After fixing it I am not real happy with it so the plating of the hull should fix that. The alert was the first ship plated and it would be great to show this sister ship with plates.......I will be replicating the plates on this contemporary model as best I can.
- dafi, J11, CaptainSteve and 5 others
8
HM Cutter Cheerful 1806 by Erik W - 1:48 scale
in - Build logs for subjects built 1801 - 1850
Really nice planking job....I think you found the sweet spot and wont have difficulty planking anything in the future. Well done!!!
