Chuck
Administrators
Posts posted by Chuck
  1. Thanks guys...
    Yes Erik it is tough to photograph.   My simple point and shoot digital really distorts the images.   It gives that slight "fish bowl" effect around the perimeter and bends the image.   I am going to see if one of the guys in my club has a better camera.  I will take some photos with it to see if it improves.  I do like Mikes pictures and will ask him to bring his camera to the next workshop session at my shop.  We meet every month at my place to work on models together.  Its really great fun.
  2. What you are looking at here are photos of a contemporary model (Minerva).  A rare example of copper plates made for a model and its contemporary.  If I remember correctly these plates were put on the hull with actual small nails....thousands of them.   Wish I had better pictures but these are the best I have close up of the plates.
  3. Today I finished the standing rigging.
    Once the ratlines were done I only had to rig the topmast shrouds and the topmast stay.
    Even though I have shown the topmast backstay on the plans,  I did not rig them.  I just wanted to show what they would look like.  Only under rare conditions were they used.  I have never seen a contemporary model with them rigged and the straps on the side of the hull are always left empty.  So I decided to follow suit.  I think it ruins the look of the model a bit as well and this is more in keeping with what everyone is used to seeing.
    Next up I will start the running rigging.   Its getting close!!!!
  4. I added the sheer pole.  It is lashed to the outside of the shrouds above the deadeyes.  I painted it black but it could have been left natural also.  It is just a 1/32" x 1/32" strip with the edges rounded off a bit.
    Then I started the ratlines with .012 rope.  You dont want to go heavy with these. The outside shrouds are simple square knots.  But I used clove hitches on each inside shrouds.  I urge folks to use them rather than simply tie a knot on all four shrouds.  The lines hang much better.  Its easy to do.
    I used a card with both horizontal lines and lines to show the shrouds.  Its not enough to just use horizontal lines.   Having the shrouds drawn on the card will make it easier to watch your progress.  You dont want to gradually pull the shrouds in.  That hourglass shape for shrouds on a model is the kiss of death.  This helps you keep them straight and not pull them in as you progress.  I found it better to leave the ratlines a little loose rather than pull them tight and I try to shape them after its done.
    Only some watered down white glue was applied on the knots of the outer shrouds only.   The two inner shrouds have no glue at all.  I waited until a series of rows were complete so I could adjust them before adding the glue.  You can also see that I finally cut off all the loose ends at the belaying points after re-tensioning the lines and I added rope coils to the belaying points.
    Now its time to start the ratlines on the starboard side.  Yay for me.  Merry Christmas everyone!!! :P
    Chuck
  5. The Alaskan Yellow Cedar barge has been planked.  Still lots to do on this one.  I havent even faired the hull inboard yet.  But before the molding and red paint is added I thought this would give you guys a nice idea of how the yellow cedar looks.  I have just applied some wipe on poly.  You can see the cherry version behind it.   They are actually the exact same size but digital cameras do these funny things....
    I would like to get the cedar version to the same point as the cherry version so I can progress with both simultaneously.
    All the cedar is wood project source
    Chuck
  6. I just finished laser cutting the Yellow cedar he dropped off yesterday.  The Alaskan Yellow Cedar is such a wonderful wood to laser cut.  The parts are for a second barge I am building which will be made entirely out of the yellow cedar.  I hope to have pictures real soon but I am really enjoying working with it.
    If you are looking for a light golden/yellow wood that is easy to work with I do recommend you give the yellow cedar a try.   The top board has some Wipe on Poly on the end.    It makes teh color come out nicely. I should have the planking done this weekend so you guys could have a better look at teh stuff as part of a model.  :)
    Chuck
  7. Thank you for the kind words guys.
    The lower backstays are completed so next up was to make the sling and then add the mainstay.
    The sling for the lower yard is served its entire length.  I used .035 dark brown rope.  It has a thimble seized to it with a hook made of 22 gauge wire and eyes formed on each loose end.  After determining the length for the loose ends I formed the eyes and you can see how the eyes close up the sling by being inter-twined.  I originally thought it would be easier to make the sling off the model.   Which it was.  BUT there were trade-offs.  This meant that I had to unhook all of the blocks on the mast to get it in position.  That wasnt too bad BUT afterwards I discovered that the sling wasnt long enough to get around the forward spreader.
    This was bad.  I either had to cut the sling off and make another one...rigging it in place.....OR, try to carefully remove the forward spreader.  I ended up removing the spreader without any damage.  BUT I wouldnt recommend this to all the Cheerful builders out there.  Best to rig it in place.
    The main stay was rigged from .054 dark brown rope.  It was served around the masthead only down to about 1/2" below the splice.  Thats right....a splice rather than a mouse.   This was very common on cutters of the period and appears much more often on contemporary examples than the one or two found with a mouse.
    The other end of the stay had the 5-hole deadeye turned into it.  The lanyard was rove through it as usual but the loose end was taken up around the stay once and then finally seized to the stay as shown.  I used very fine fly-tie thread for this.  It finished it off nicely.
    Now that the main stay is completed I can go back to all these loose ends at the belaying points and re-tension the lines.   After that I will cut off the excess and add rope coils....
    Next up....ratlines!!!!!
