Posts posted by Chuck
we just added a field to the profile. If you wouldnt mind editing your profile to select and enter the info.
Basically it allows you to select if you are a full NRG member or an MSW member only. If you are a full member of the NRG, you can enter your membership #. Your membership number can be found on the label of your Nautical research journal. It is usually four digits.
Just click on account setting under your name and then select edit profile. If you scroll down to the bottom you will see the selection area. This will be important later should you be a full member of the guild....
It will display your choice under the location in each post....you can see how to the left under my location it says NRG Member. Your NRG number will not be visible except to the staff and to you...
What is an activity stream? It is a fancy word for the custom search of the content on this site, which at the click of a link you can view precisely what you want. Currently there are only the default streams set up. You can view these by hovering over "Activity" in the menu as shown below. Note the "MY ACTIVITY STREAMS"
Click on "MY ACTIVITY STREAMS" and you will see the default streams. They are pretty good but I know you will want a more targeted stream of content you are interested in. For example you can set up a custom stream that will show you only unread activity in build logs for three people you specifically want to check out regularly. And you can filter other restrictions. Just click on "Create new Stream as circled below.
You will get to a filter screen where you can name your new customized search....see below
Then select the other customized features you want. Below you can see I selected individual forums and even made it specific to just two members.....and content that I havent read since my last visit. You can set it up any way you want....
After you save your customized stream (lower right is saved button) it will now appear in the drop down as shown below....this is the test stream I just set up.....
If you click on it....it will show you only what you asked it to show you. See below for my custom activity stream. There is no content because I made it very narrow with only two members as you see. Read the description of my custom stream below the red circle. Also note that the icons in the red circle let you select this as your default stream or you can edit it or delete it. It will remember your selections and now all you have to do is click on it whenever you want to see this particular stuff.
Even more awesome is that you can set up as many custom activity streams that you want.........
- CaptainSteve, James H, MEDDO and 13 others
16
There are a half dozen ways to do this actually. But first you must be willing to try some of them. Play around a bit. For example. What Chuck mentioned is a great way. You customize a "stream" It can show you a list of only what you want to see. Every time you click on it. And you can set it as the default stream to make it easier to access if its the only one you use all the time.
-go to the activity drop down
-click on "my Activity Streams"
-at the bottom you will see "create new stream"
-here you can call a new stream...."unread build logs I follow"
-then just set up the filters including what forums like "build logs for kits" or both kit and scratch logs. Then filter so it only shows the logs you follow and unread content since you last visited. Or whatever other criteria you prefer. Its really a wonderful feature
-It will show you only what you want to see every time you click on that activity stream. AND you can make it the default. Then you can just click My activity streams and it will show you only what you set up.
-AND you can create as many personalized streams as you want. Think of the word "stream" as a fancy word for "automated search based on your own criteria"
OR....you could get grumpy that stuff has changed.
But the new "activity streams function" gives you the opportunity to personalize any search for content whenever you want it and with the exact criteria you are looking for. Its a thing of beauty. And yes a new FEATURE thanks to the upgrade.
I will make a new topic with this info.
- Cathead, CaptainSteve, bhermann and 3 others
6
The stuff is back......scale hardware was bought out by model motorcars
https://model-motorcars.myshopify.com/collections/small-parts-hardware/bolts
Greg you can take a deep breath now!!!!
- Archi, Ryland Craze, mtaylor and 6 others
9
Yes indeed......trust me we now understand..........
OK....to delete a post you made (NOT A TOPIC). click the options dropdown on the lower right of your post. You will see delete......it will NOT be gone forever. It goes to a holding bin for one month and then it goes away forever. It will ask you if you are really really sure......
Most important...when you want to delete a WHOLE TOPIC you started. See the four buttons above each topic .....at the top of your topic, these control your whole topic and NOT just a post. You can ignore a topic etc. But if you select Moderation Actions, you will see "delete, be very careful". This will delete your entire topic, including anyone elses posts that were made in it. You will see a pop up that ask you if you are really really sure about this....
If even after all of that, you deleted it by mistake, the topic can be restored within a short period of time if you contact an admin. Be sure to tell them the name of the topic and what forum area it was originally in so they can put it back there. But after one month if you dont contact us it will be gone forever.
OK....as you guys know, we turned off the ability for members that allowed you to delete your own content. We did this because two or three members deleted their build logs by accident. They were not recoverable. However, by turning off this feature, it also disabled a members ability to delete the last post they made if they made it in error. Whether on their topic or someone elses. These two features are not separate in the software.
So to be clear, either you can delete both topics and the last post you made or nothing at all. I understand how this can be a pain in the butt. If you post something and want to delete it, you cant right now. You can only edit your last post and remove the content. Leaving a blank post. Then you would have to contact a moderator or staff member to have us delete it. Or we would have many posts that are blank or that you write..."removed content". This is not ideal and quite sloppy
Why am I repeating all of this here? We may have a solution. We have mitigated this somewhat. We have created up a feature currently only available to mods and admin. When we delete a whole topic, it doesnt actually get deleted any longer. It will be moved to a new "trash can" topic hidden from view. Only a moderator or and admin can delete topics that end up in this trash can. Until we do delete it forever it can always be moved back to the forum it came from. I guess you can call it a restore feature.
BUT...this feature only applies to complete topics. NOT individual posts. So when a post (like one you had second thoughts about making on a topic is deleted) it will be gone forever. This also applies to us mods and admin. When we delete an individual post....its gone forever.
SO.....what I am saying is.....we can now turn the feature back on that will allow you delete your own topics that you started and posts you have made. But remember....individual posts are gone forever. Only complete topics are sent to this "recoverable trash can"
Should I turn this feature on for members?????
Pros.
You wont have to worry about deleting a complete topic or your build log and it will be gone forever......
you wont have to bombard the staff with requests to delete topics or individual posts....which judging from past activity happens very often.
When you dont tell us to remove a post you made in error we will have useless posts emptied by each member hanging out on the site. This prevents that.
Cons.....if you do mistakenly delete one of your topics, you must recognize soon that you did delete it by accident and tell a staff member to restore it.....we wont leave topics in this trash can forever. We will empty it from time to time. So you cant ask us 2 months later to restore a topic.
Once again......posts are gone forever....but a staff member will be able to restore your accidentally deleted topic.
Do you guys feel comfortable with this. If so I can turn it back on for a trial run. And I will post some screen shots of where you can go on a post to delete it vs. deleting a full topic. But I fear even with instructions some of you will mistakenly delete something.....
and once again....posts are gone for good. BUt a complete topic you delete will now be restorable. this is something we set up as a direct fix after several members mistakenly deleting their build logs with no easy way to recover them. Now they will be recoverable.
We are actually fortunate to have many planking expansions for royal navy ships. The original drafts of such inboard and outboard expansions are available and have much of the info you need. For Cheerful in particular, both the inboard and outboard expansions exist showing the width, thickness and length of every strake. The plans I developed for Cheerful are an exact match using that info. Its one of the reasons I chose Cheerful, the original documentation is so complete.
Here is the outboard hull beneath the wales for Cheerful as an example. Finding the measurements is a snap. The length varies from 23 - 25 feet mid ship. There are however a few when needed that are longer but its an exception.
Very nice WORK. Fantastic progress.
- Nirvana and Tigersteve
2
Just an FYI, This tutorial was about making simple one piece molds for flat-ish small decorations on ship models. Like gun port wreaths etc. There are also more complex two and three part molds for making fully round parts like cannon or a figurehead. When time permits I will make a similar tutorial based on my experiences. I will also continue to try new material and brands. For example, as soon as my gold dust gets here I will try and make a gilded example of the monogram used in this experiment. I am just waiting for it to arrive in the mail.
But everyone should add there experiences here for simple one piece molds so we can start compiling more content and info for everyone.
We will try to bring everyone more tutorials like this for other things.....maybe soldering, or blackening, or very soon I will be sculpting additional decorations for the barge kit prototype from Sculpey and will create a similar topic about that.
Chuck
Thank you. The resin gets pretty rigid in larger pieces. The thin pieces are fairly rigid but have some flex if you want it to. For a day or so after de-molding....certainly for a few hours after they are somewhat flexible and can be bent to conform to some bend. But they will firm up. There are so many different kinds of resin that you can buy some that is extra rigid and some that are extra flexible. This stuff I used is just the regular stuff though.
Chuck
Prepare your mold for pouring
There are many ways to do this but let me write about how I was taught. Before you pour the resin in the mold, I usually dust it with talc or in this case baby powder. This gives the cast part a nice finish and prevents bubbles from forming along the molds surface. The bubbles will slide away to the surface or the back of the casting. I will brush off the excess talk and make sure there isnt any clumping in the detailed areas of the mold.
The photo above shows the baby powder after I prepared the mold. Next to it is some Alumilite casting resin. There are many different types. This is their regular stuff. It has an open time after mixing it of 90 seconds and cures in about 15 minutes....usually....I will explain this more later.
I also made some castings using the Micro-Mark resin which has an open time of 3 minutes but cures in 40 minutes after pouring it....normally.
Both are the same as far as being a two part mixture 1 to 1. Equal parts of A and B. The Alumilite cures tan while the Micromark cures white. There are many other colors and many other open and cure times available. Just pick one that you are comfortable with and like after giving it a try. I will say that short open times before pouring are tough.....you do feel rushed. But then you will have to wait less time while it cures.
In the photo below below you will see that I have poured equal parts into disposable plastic shot glasses. They are just 2 oz. Our parts are very thin and tiny and using larger containers is problematic and wasteful. I have a wood scrap strip to stir it up after mixing the two parts together.
A few points or tips worth mentioning. Make sure it isnt very cold where you are working on this stuff. The resin should be room temperature. This is true of the mold you are pouring it into. Good at room temperature or even better yet....warmed up a little. It cuts down on the cure and demold time. If its winter and cold I might sit the mold on the radiator for a minute or two.
I do gently stir both parts before pouring them into their sep. containers. Make sure you dont agitate them to form air bubbles.
Pouring the resin
Next I pour one part into the other shot glass. Stir it up well but again be careful not to form bubbles. Remember that I only have 90 seconds before it starts to really harden up. So you must work quickly and stir for 20 seconds and then pour into your mold.
Pour is not the correct word....these decorations are just 1/32" thick or deep in the mold. The design has small thin 1/32" wide elements. You just cant pour it on top of the mold. You have to carefully drip it into the mold as best you can. You will no doubt over fill the mold. But then take a wooden scrap stick and squeegee the excess to one side so it is mot a huge puddle. The parts would be too thick otherwise and require lots of sanding and cleaning. The photo shows the resin poured.....note how I squeegeed the excess to the bottom. Also note the dark color in the mold. It will cure to a light tan.
Also note in that same photo how the shot glass has already cured lighter and is hard. This is less than 2 minutes after mixing both parts together. You will also notice that the resin in the mold is not cured yet. You see, thinner parts like this will take substantially longer to cure than the larger volume in the shot glass. In fact, it took a full 40 minutes for these thin fragile castings to cure in the mold. This is true even though the resin is sold as a 15 minute cure. As ship model parts are so small and thin they will take much much longer than they advertise. The resin heats up when it cures and that is why warming the mold up before pouring will speed the process up somewhat. It is also why a cold mold and a cold resin will take a very very long time to cure.
So you have less time to pour knowing this but will need to wait longer to de-mold small parts. Keep this mind when you are selecting which resin to buy.
After 40 minutes.....see below
Ready to remove the casting
The resin is very hard to the touch with a toothpick....ready to de-mold. Forty minutes later. Flex the mold a bit and carefully pry and work the casting out.
Now when the casting is released it will look messy because unless you are pouring a huge part, these little ones will over flow a bit.
So looking at the photo below, you can see the two tan castings on the bottom row (Alumilite) and the two white ones above those (Micro-Mark)
The first of each pair show how they look right out of the mold. The flashing and excess should be removed. I usually rub them on a flat surface over some medium fine sandpaper. This will at least take the majority away. It doesnt take long to do but imagine if I didnt squeegee the excess away after I initially poured the resin into the mold. The example next to those in each pair is after I cleaned it up.
Above them both you will see the master which was painted gold leaf next to a dime to show the thickness and size.
The ones shown below are the MicroMark resin along with the master.....
Both brands of resin show great detail.....even fingerprints. I cant say that either is better than the other except that I enjoyed the longer open time of the Micro-Mark resin. But Alumilite has different resins with more open time as well. So does Smooth-on mentioned earlier in this topic by some members. Like the mold rubber, this resin will not keep long. It doesnt have a long shelf life so after 6-9 months test it in your mixing shot glasses without pouring it into a mold....just to see if it still cures. Keep it in a cool and dry place. Moisture is bad for resin.....put the caps on tight.
Thanks Ken
I am very familiar with smooth-on products. They are very good as well. The tutorials are really good to.
- Nirvana, Canute, thibaultron and 1 other
4
Beautifully done!!! I cant see any issues at all. I love the color and the photography is top notch.
- Stuntflyer, druxey, JesseLee and 4 others
7
With regard to the lifts....you will often see a cutter rigged with the lifts going through the shrouds. Here is a contemporary model with original rigging.....
Note that the lifts pass between both shrouds. Others do in-fact have them in front of the shrouds also but this is NOT always the case as you can see here.
- mtaylor and CaptainSteve
2
Thank you very much.
- mtaylor and thibaultron
2
I am not really sure as I havent built them all but those I have worked on were OK. Its just that all MFGs of commercial blocks in kits come from Europe. They are metric so the sizes are off from the start when looking at an MS kit. So when you build an American ship or an English one where the plans show the blocks the correct size...you get whatever the closest MM metric block made in Europe. So if it calls for 3/32" you will get a 2.5 mm block. Which was made slightly bigger as well and not even 2.5mm.
If a block called for should be 1/8" long on the plans you will get a 3.5mm European made block which is too large....etc. Its not intentional when they are placed in kits but there is only two suppliers of those square blocks from europe (as I was told) and all of the kit MFG's buy from them. So they have to use the closest equivalent metric size no matter what the plans call for.
- thibaultron, Jack12477, Nirvana and 1 other
4
That actually works quite well Greg. The finishes can vary however but yes I have used that technique. Its actually easier than using the dies that you mix with the resin before pouring. BUT for cannon and black items there are better alternatives. Several black resin and plastic products are available that cure black.
http://www.reynoldsam.com/product/smooth-cast-onyx/
and
http://www.alumilite.com/store/p/928-Alumilite-Regular-Black.aspx
These work great for casting and afterwards you can use some weathering powders to really make them look like black metal.
Here is a link with something like Greg was referring to about making parts look like metal...its a powder rather than a spray or liquid application. I have used these and it works well. For example...if you use the pewter powder with black resin it looks pretty awesome on a cannon casting. But you have to experiment. I prefer the powders.
http://www.alumilite.com/store/p/1082-Alumidust-clone.aspx
http://www.alumilite.com/store/p/953-Alumilite-Metallic-Powder.aspx
The monogram for example which is usually shown on a barge gold leafed...would look rather nice with the casting made using the gold powder. Just for giggles I will order some so you guys can see how it works and looks on these cast carvings for the barge. They come out much cleaner than painting them. the downside is they remain on your mold somewhat and you have to have a dedicated mold for that finish....more mold prep before casting subsequent copies is needed to make sure the mold is free from left over powder that might clog small details and textures the next go-around.
- Canute, dvm27, thibaultron and 8 others
11
For something like that it might work out OK....its hard to say. But for sure, the traditional route would work. But give it a try. Oh and feel free to openly discus this topic here....lets present all of the info we can. I think thats always better.
- mtaylor, thibaultron, Nirvana and 4 others
7
Are you an NRG Member???
in Using the MSW forum - **NO MODELING CONTENT IN THIS SUB-FORUM**
Thank you very much in advance.....the Journal is a wonderful Magazine.
Chuck
