Everything posted by Chuck
I spent the last 3 days working on and refining the parts that make up the qdeck rail. It was quite a journey. The parts were tweaked to allow a bit of wiggle room when assembling. This is a very intricate rail but is another major element of the model. So I took my time and completed the port side without taking many pictures. I wanted to power through it to establish a good method for building it. When I repeat the process on the starboard side I will take many more pictures and describe how I did it. I found the best approach for me was to build the rail in sections or groups which I will explain. Hopefully I will start the other side by the end f the week. But here are some final pictures of the completed rail on the port side. It really does give the ship its elegant shape so typical of these 5th rates in the Royal Navy. I cant wait to finish the other side to see how it will look. The rail starts to lean in toward the deck more and more as you approach the stern to match the angle of that last stern frame. The uprights which become the sides of the ports and the timberheads are extensions of the frames. You will need to lean these inboard as you work from mid-ship towards the stern....finally adding the top rail which is in two sections. BUT at the same time these uprights are straight and vertical when viewing the ship from the side profile. A tricky but rewarding experience. Note the fixed block at the stern against the transom. The middle rail sits on this.
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Merry Christmas to all of you…and yes it is full steam ahead on Speedwell in 1:48 Drafting in progress…an hour or two each night while my wife watches her shows. This is in no way finished but enough to show you what I am shooting for.
- 1,784 replies
- winchelsea
Lookin good…and Merry Christmas.
- 399 replies
- winchelsea
The breastrail.... Its pretty straight forward. All parts are laser cut for you. But you will still need to prepare them and shape them. You must do so in the same way you did for the various laser cut columns during this project. Sand off all the laser char carefully if you dont plan on painting the uprights. I left them natural which meant they had to be pretty clean. Use some files, sandpaper and small chisels...or even a #11 blade in my case. Duplicate the overall shape on the fore and aft sides which was laser cut for you. Remember to get these clean, although you can paint them black if you wanted to. I have basically just laser cut and etched the general shape of these uprights and its up to you to finish them with care. Take you time as the breastrail is a feature element on the model and your eye will be distracted at one that looks sloppy. The lower rail is a 3/64" thick piece of laser cut boxwood. It slides onto each upright. Keep in mind that the angle on the top and bottom of each upright changes as it the rail moves outward from the center. This is to accommodate for the roundup of the qdeck. Make sure you position them accordingly. The more severe angles are toward the outside of the rail. The center pair of uprights has the least amount of angle. Then glue the lower rail onto all six uprights. Slide it down from the top...Make sure its seated properly and do a test fit before gluing. The top rail is actually made in two layers (top of the first photo). There is a very thin 1/64" thick boxwood layer with square holes cut out of it. Glue this onto the solid rail. You will notice its slightly smaller so it leaves a nice lip all around the bottom edge. Paint both rails black before doing a test fit of all pieces. You should be able to align the top rail in position by inserting the tops of the uprights into the square holes on the underside of the top rail. This should also force all of the uprights to be perfectly vertical as the laser cut holes are all lined up. Then test it on the model....it is very very important to center this rail port to starboard. You can peg each upright into the margin plank at the edge of the qdeck if you like. Make sure its straight in all directions. Meaning its vertical when viewed from the side of the hull....and along the edge of the qdeck when viewing it from overhead. You can see how it looks with the uprights left natural. You can paint the entire rail black if you prefer. Also note that I constructed the railings around the companionway and made the ladder leading down to the gun deck....just like the one on the gundeck you already made a few chapters back. I created the stanchions using 1/16" x 1/16" boxwood strips. I created what I though was a nice fancy profile. I kept them square in profile except for the center portion and the little ball on top. They were painted black. They were chocked in my Dremel and turned to create the rounded areas. The horizontal rails were cut from 1/32" x 1/32" boxwood strips. You can also choose not to add this railing at all. Many contemporary models including the one for Winchelsea dont show such a rail. But I think it adds a nice detail. Any Questions or comments? Next up the fancy rails along the shear caprail!!
- 1,784 replies
- winchelsea
Nice progress. She is coming along.
- 840 replies
- winchelsea
Lovely work. The small belaying pins from crafty sailor work great as quoins should you want to cut down on the time spent on assembly. They are also pearwood which is perfect for you.
- 642 replies
- winchelsea
Yes historically it is correct. Too many primary sources show it. Including this well-recognized example. It only looks wrong to many of you because you have been conditioned to see and accept so many wrong displays….done on kits mostly. But too many folks just didnt do the research and many of you (as with other aspects of a project) just adopted the ridiculously wrong occurrences of such things as accurate. Sometimes its very hard to correct fake news or misinformation! Note the size and style. Note the gradual “leaning in” of the letter towards the center. This is almost never shown correctly. The SPHYNX name is pretty close although it should be painted with more depth like the friezes.
- 857 replies
- Sphinx
- Vanguard Models
UGH!!! Brings back memories for sure.
- 642 replies
- winchelsea
I would strongly recommend going much larger with the letters....AND if you can, make them on a curve t match the curve of the counter. But yes it looks great. Let me see if I can facilitate something for you, see below.....
- 857 replies
- Sphinx
- Vanguard Models
HM Cutter Cheerful 1806 by JpR62 - 1:48 scale
Chuck replied to JpR62's topic in - Build logs for subjects built 1801 - 1850
Beautiful....looking forward to seeing some deck work made. -
Keep in mind we did moderate that that topic. And what you cant see, is that we did speak to those who treated the OP badly. There is and will be no tolerance for belittling other members. We have hundreds of members who may not be experts or they may even be beginners. To call what they have posted as a tip or suggestion "trash" is not something we want to condone at MSW. We have many new builders who are proud of what they have done. They want to share their methods and work. It may not be perfect or masterful. But they dont deserve to be treated badly. And you wonder why new folks dont stick around. Its because of people like those members who bashed the guy. I counted six. And I must say if those six experts suddenly vanished from the site...it would be less impactful then the scores of new builders alienated and poorly treated by them. These so called experts who love to pontificate (you know who they are) will not be allowed to treat other members like dirt. They have been formally warned. If they continue...they will be banned. The OP of that topic was NOT banned. Nor was the topic removed. It was being cleaned up and pruned of the nasty remarks other members were making. Such as the one below. Who would actually have the balls to to post THIS!!! ...on another persons topic no less. They should be ashamed of themselves. As if they are so perfect. Pompous posters who love to pontificate on their wealth of knowledge be warned....do not treat folks this way. There is a way to teach and educate without being a bully. You guys are certainly NOT mentor material. You get three strikes.....if the behavior continues...you are out. The bully below says the member wasted his time. You know what wasted my time...cleaning up the hate you decided to post all over someone elses topic. That was a waste of my time. Sending you a private message and issuing warnings to the folks who think they are "genius" masters who everyone should kiss up to....that was a waste of my time. found the video a total waste of time. So what's to respect in the effort to make it and why do you care whether the poster "is getting pleasure in his task?" I know I may be criticized for being "insensitive," but I don't respect the efforts people put into posting useless, let alone erroneous, "how-to-do-it" videos on the internet and I could care less whether the people who post such drivel are getting pleasure from it. They waste everybody else's time. Who has the bandwidth to waste on junk content? And here is the kicker.....non of the so -called MASTER builders in their INFINITE WISDOM of all things...posted a better method...or the correct historical reference. They made ZERO attempt to politely state that there may be a better way or a more historically accurate way. No attempt to teach or mentor. They just bashed the guy and went on long Rants...like this one I am now forced to write about how so many people dont know as much as they do and yet post on You tube and the internet all this bad wrong information.....making society more stupid. 18 posts by expert bullies were pruned from that topic leaving just two replies. All 18 had no value other than to belittle. Shameful. Talk about a waste of time reading those. The replies of the bullies had no value what so ever. Except of course maybe to allow the bullies to hear themselves claim omnipotent dominance of all things in the Universe.
No no r at this time…this one is off the drawing board for now.
- 130 replies
Looking great. That deck looks wonderful.
- 112 replies
- Cheerful
Beautiful and a real milestone. I remember how that felt to get that done. You will feel the same way after getting the guns completed.
- 642 replies
- winchelsea
