michael mott
Posts posted by michael mott
  1. Druxey I have to draw the line __________________________________________ Not that I didn't try though;>))
    Andy I thought you would approve.
    Mark, I shall think on it for sure.
    Greg Thanks,have you seen the film Grumpy Old Men, the sardine would make my wife a grumpy person:>D
    Geoff, Thanks, I have not seen the book you mention I shall have a look for it, I am familiar with the Pilot Cutter Marguerite though.
    Michael
  2. Thank you everyone for the positive comments and for the likes.
    I was hoping he'd do a couple of robertsons.... just for badness
    Well as it turned out Andy, Walter was short on a couple of screws so rummaging around the odd screw bin he found a couple of 0ld Robertsons  for all the Canadians in the crowd
    These were really hard to make, I used some Sig copper rivets and swedged the square hole with a ground punch made from a broken 1/8th shank number 73 drill.
    The scrap metal bin just gained a few oz.
    Michael
  3.
    I suppose the screws for the hinges will be scale slot-headed ones as well?
    Druxey There ya go
    Kieth I am glad that you can use the saw blade trick.
    Mark Thanks
    And than you all for the likes.
    I was not very happy actually with the set of four new hinges so today I began a third set, this time I did not anneal the brass but bent it cold, and scaled up just a little by using a 1/16th end mill. The picture shows a steel rod acting as a bit of a drill to clean up the holes after the milling
    The next picture shows the new hinge made today next to the slightly smaller earlier one. the new one looks a lot tidier to me
    Set up in the companionway.
    I added some small bevels to the door frame. tomorrow I will finish the second set for the other door.
    Michael
  4. Denis thanks.
    S.os the diameter is 2 scale inches at the moment but is still need a little refining I will bring it down to about 1 5/8th or 13/64 actual.
    Worked on the set of 4 hinges today, The blade in the jewelers saw was purposely set at about half length to keep it flatter.
    The hinge on the left is the original test hinge
    Drilling and countersinking the fixing holes, the holes are .033 or a number 66 drill and i had to make the countersink from a bit of drill rod
    At first I used some hard maple as a backing support but I needed a harder surface so used a piece of 1/2 inch square Duraluminium bar
    The hinge pin is 1/32 or 1/4 inch scale
    Michael
  5. Had a great day today, family time I got some nice gifts some small metal toolmakers clamps from lee valley plus a mitre box for the razor saw, the first commercially made one I have ever owned,  and some boat building time.
    Gluing up the doors using some wedges and bicycle inner tube bands
    Making a test hinge first some 1/64 thick brass strip was annealed and folded over some .015 steel rod the the excess was cut off with the jewelers saw
    next the half was slotted, again with the saw
    the second half was made in the same manner
    next the sides were filed up square and even
    checking the size on the side of the door
    next the relief needs to be filed into the doors and the sides of the companionway before the doors are mounted.
    Oh yes and now I need to make a set of four hinges that are the same size.
    Michael
  6. Yes it looks like Pine to me, however there are quite a few different types of pine, and without a clear image of the grain and pore structure it is difficult to tell which one, there is a website, the name eludes me right at the moment where there are images of the structure of different woods that you could match to find out exactly which species of Pine if in fact it is pine.
    Michael
  7.
     In my many moves I lost my drafting machine. It was big and cumbersome so I'm back to T square and triangles.
    The thing about using a T square and Triangles is that it is a universal language that many of us me included used to learn how to draw. I now do use Cad a lot but it is amazing how many times I use my drawing knowledge to do things in Cad that are ingrained in the pen/pencil and paper mindset.  The practical geometry that my drafting teacher imparted gets used on a daily basis, I thank him all the time.
    I like your sketch.
    Michael
  8. Dave I have a whole load of true Black American Walnut that a friend gave me from his kitchen renovation all is 3/8 x 2 1/2 inches and a few varying lengths from 12 inches to 24, all neatly stacked and waiting for the right job. I have always liked the look and workability of the real stuff.
    True Mahogany, Swietenia macrophylla is also very nice to work with.
    The local Lee valley has some wood they are calling Yellowheart ,Are you familiar with this wood I just noticed it the other day and looked at it but I was in a bit of a hurry (never a good thing) and did not inquire?
    Michael
  9. Thanks Mark, perhaps I will do a bit of careful editing at the first few pages over the next while and see about adding in some of the earlier pictures.
    I did not get much time in the shop today, I had to go get water and also dealt with some more computer configuring.
    Here are a few pictures of the progress on the doors for the companionway, They are still quite rough regarding the shape, but I am happy with the overall design I still need to shorten the panel and make the curved top rail the bottom rails are tennoned into the stiles.
    I thought I would see how things look in Black and white.
    I was doing some searching for images of Genesta and some of the early black and white photographs that were taken while some of the big yachts were racing are really stunning. they are sharp and well posed a true testament to the photographers and cameras of the time.
    Michael
