michael mott
Everything posted by michael mott
  1. Bob what an excellent job on the flare, that looks fantastic. Michael
  2. Nils thank you for all you answers to our questions and what a great way to finish. The model does look wonderful in the case. So what's next? Michael
  3. I do like these yacht hulls they are so sculptural. looks like you will have the planking done in no time at all Floyd. Michael
  4. found a chunk of cherry that looked promising. After slabbing it up, and tracing out the top curves This took a while but I am happy with the way the joint looks I like the proportions better and think this will work out. I did do another test though using Ed's suggestion of adding the glue during the initial forming. I think though for this cockpit I will be using the curved grain pieces that came from around the knot in the wood. Michael
  5. Nils I keep looking at the volume of rigging and the work on the sails, and I am sitting here shaking my head in amazement, and to think that you did all this in 1600 hours...... wow! I really like the sails, what is the line that you used for the bolt rope with the stainless core? Michael
  6. Yambo no apologies needed, regarding the cutting from the solid wood it is something that I am contemplating finding a piece of cherry with a bit of curved grain would make that decision much easier. You are correct though about the difference in appearance and it is something I need to decide on from the aesthetic point of view. Ed thanks for endorsement on the tube, and you thoughts on the gluing I will try that, it makes a lot of sense. I did just clamp up the cherry that soaked overnight, bending it cold and with a metal wrap perhaps I will go unclamp it and redo it with the glue. I am also looking at some thinner sections. Michael
  7. Beautiful work Karl, and very informative photographs of the details. Michael
  8. Ed your clean and clear pictures are very inspiring as well as educational keeping everything in line and placed around those areas to be removed must keep your mind on its toes. Beautiful workmanship as always. Michael
  9. Steve, John, Dan, Yambo, S. Coleman, thanks for the kind remarks. And again to those who pushed the like button. Yambo there will not be any butt joints only scarph joints, the cherry laying on the top of the cockpit is just that. I was looking at the proportion of the section. And on the original laminations I did vertical scarph joints, layer by layer. The cherry that soaked overnight went around the sharp corner very nicely and the first dried well. Dan thanks for the tip about the thin metal wrap, makes a great deal of sense. Michael
  10. The deed is done. The square cherry for the straight sections. The colour is closer to the mahogany but will still provide some contrast. A series of short pieces soaked for a short time and wrapped around the form. The rest of the cherry will soak overnight. Michael
  11. Ahh but better that doing it three times at my rate. Great work Mark. Michael
  12. Tony just went through your build, some great ideas and your innovative ideas for making parts are great.`I particularly liked the yoke for the cannon soldering the tube to the bent rod then fretting out the middle. Michael
  13. Thank you all for the really positive comments it really means great deal. and for all the likes. The things that we are pleased with seem to be countered sometimes by those that we are not. The fittings for the ropes through the bulwarks will be fine using copper. The cap rail of the cockpit however is a different story, I am not happy with the way this has turned out. after sanding it to profile it was treated with Tung oil. the joints are way too obvious and the contrast is much greater than I anticipated. I will see what it looks like when the oil has dried but my guess is that I will still be disappointed. In that event I will sand it off and do it over using some slightly different steps. The first thing will be to use solid material for the straight parts and re laminate some new corners. I think I will use either Maple Birch or Cherry, I will look at how each laminate up on the tight radius first. Michael
  14. With a hammer 3 x larger and heavier than anvil $%#$%&%$$ I must try to drive his bike trough deep water .... Forgiveness is the greater path "as your own behavior must have established its worth". Michael
  15. John, thanks for checking out the progress. I had a chance to make a second hawser fairing, this time I used copper, definitely a better choice of material, it is much more malleable I only needed 2 annealings. I am tired so just a sequence of pictures using exactly the same process as the 1/8th diameter one, I will make the smaller ones out of 1/8th copper tube. The most work forming was done with this tool The last picture is showing the difference between the 1/8th brass one and the 1/4 copper one. Also the four different tools for forming and some metal snips and file, the final polish was done with wire wool Michael
  16. Geoff, thanks, I have to say that I have had the same experience following along with others who show how they solve a particular task. Bob, the metal is indeed brass, I think that the colour was off because of lighting. I also think that the Flaring would be easier with copper, which I will try. The other tube that I did not flair yet is 7/32 diameter brass. The tools I used were given to me a long time ago by a jeweler, they are just shaped silver steel and hardened. Tom, thanks for your kind remark, I have been following the examples set by builders like Ed Tosti and Karl among others. S.os, thanks for the compliment, sharing what I know is the least I can do in return for the amount of knowledge that I gain from the members of this site. Druxey, thanks for your continued support and for your articulate and timely use of our language:>) Michael
  17. Piet, Great work on the boring little hinges now that is dedication. the details are a definite plus. Michael
  18. Thanks for all the likes Yes I'm definitely hooked. Not wanting to clutter up Bob's Lettie build log, and needing to deal with the same basic issues of holes through the bulwark and because Bob was waiting for me to try this, I did here are my results for the holes in the cutter at least one side of the hole. 1 cut the holes then sand the angle and tubes the tubes have had the first annealing 2 the first forming using a spoon shaped modeling tool for working with sculpy (not the best) 3 after the second annealing and using some shaped steel rods, the point was trimmed with some flush cut side cutters. 4 The wood soft poplar snapped out but the wood block was still usable for forming here the end of the seel rod is almost hemispherical 5 next a slightly narrower tip followed by a third annealing 6 an even sharper tip used on the back side to flare out the tube a little more the block under it is hard Maple 7 a little polish with some steel wool 8a check with the eye laying on the cap rail above the hole that it will serve So I will use this method for the rest of the holes both inside and out Michael
  19. Oh... as soon as the cap is glued I will take a stab at it pictures too. Michael
  20. Steve very cool, the smoke must have given you a skip of the heart beats especially after the weird noise. I will have mine on a trailer to the lake. Michael
  21. Nils Thank you for the explanation that is a very neat solution for them. Michael
  22. Bob, if you drilled a hole the same diameter as some brass tube through a small piece of hardwood, then cut it trough to the shape of the hull at the bow, you could then file the brass tube to the same shape then anneal it and seat it back in the hole only sticking out a little bit. Next you could use the end of a piece of solid rod to shape the open end into an oval type eyelet. Just a though because I have to do the same thing and I though I could watch how you get on before doing mine;~) Michael
  23. Tom very nice drape to the boat coverings, it looks natural. the big one looks pretty spiffy too. Michael
