michael mott
Everything posted by michael mott
  1. Dear Bitao for you kindness, and inquiry. I am well and staying safe with my wife Judy, here in a rather cold chilly winter season. My hand has recovered from the surgery, and I am close to finishing an old project that I have been fiddling with since 2004, I am looking forward to getting back to work on my Skipjack Launch within the coming month[s]. There is a lot of interesting detail to sort out on the launch. One of the things that I am contemplating is to complete the launch in a similar way to the way that some of the classic ship models are presented. One side showing the construction of the internal elements and the other showing the external finishes. Michael
  2. Bitao, I have just been catching up with your new build! The work that you do leaves me basically speechless, your ability to solve complex constructions using non traditional methods with creative ways is a great contribution that adds to our collective knowledge. Your strive for continually improving your skills is inspiring. I admire your willingness to start over with work that you are not happy with, in order to reach the desired result that seek. All the best in the new year and thank you so much for sharing a greater level of detail in your methods and tooling, How we work is often as valuable for learning as seeing the end results. Humbly Michael
  3. You have done an outstanding job with the planking, I also like the detail on the corners of the cut out to show the framing, a nice touch. Michael
  4. Hakan First I am glad to hear that you are healing well and that your injury to your hand minimal. Second the push stick on the right is the only kind that I will use, I do not however add the piece with the screws at the back. I cut them out of MDF in a few different thicknesses from 1/8th (3mm) to 1/2 (12mm) and as they wear I make new ones or re-cut the bottom edges. I have never used the type on the left as I think they are dangerous. My saw is a 10 inch Unisaw that was 3HP and has been down powered to a 1/2 HP with mostly 8 inch hollow ground plywood blades. I like the large surface and solid cast iron top that the rigid Unisaw has. I also use zero clearance inserts cut from 3/8 (10mm) MDF I add the leveling screws which are 10x24 grub screws. Michael .
  5. Just catching up Maury, nice progress, she is looking well in her colour coats. Michael
  6. Yes you are correct Roger, the fins were for doing exactly what you are suggesting.. There were even attempts to use some preheating of the air with some of the developments of the air locos. Albeit a bit counter productive in some cases as it negated the reason for using air in the first place, to avoid explosions in mines. Michael
  7. Thanks Roger, it was charged with neither, but with air. Michael
  8. There is room But I am a complete Luddite when it comes to electronics. Locoremote has a number of different set ups including built in speakers and for adding ones own speakers. Perhaps once I have the current unit up and running with a bog standard 6-12 volt unit I would be able to swap it out for the other unit. As it is the battery and electronics will slide out on a tray through the opening hatch on the front. the large clamp has two bolts that are long and capped at the inside end, by undoing them the plate that is behind the oval opening and the clamp can be rotated through 90 degrees to be removed to access the inside of the tank which is 3 inches in diameter. Then the rechargeable batteries can slid out on their tray. Michael
  9. Thanks Mark, the scale is 30mm to the foot which is 10.16 : 1 I chose that scale originally because 45mm =18 inches so 30mm =12 inches. A little smaller scale than the cutter. Michael
  10. Ah Ken sorry to disappoint but this one is Electric. The Real ones had very short operational time between fills up to 900psi. The model will run on 2 9v batteries in parallel and be controlled by Locoremote, which allows me to use my I phone. Michael
  11. First a merry Christmas to everyone A watercolour after Walter phillips I feel this captures the current Christmas feel. As it is evident T have not been working on the model boat stuff lately, after the surgery an a spell of doing nothing model related, once the healing had progressed enough That I could do some work it was confined to using the lathe and mill. I had an old project that I had started in 2004 and was inspired to do a bit of work on it. This picture will give you an idea of where this is going. Around 2009 I had it set up with a plastic frame this was worked around an Aristocraft 0-4-0 chassis, but the plastic was sagging so i recently opted to rework it all. The little fiddly parts were slowly worked on, and although the loco model is compromised regarding the proper gauge etc I decided to press on and try to complete it. As much as possible things work. The next picture shows the forward reverse lever and the brake lever. all the nuts and bolts are made by me except the 00x90 ones. Rivets are 1/16th. A couple of week were spent sorting out how to make these wire handle valves . The wire shape was a tricky bit of folding. They are not exact but I am ok with that. The back of the loco has a fair bit of fiddly bits and the sequencing of assembling the parts is a challenging. This odd looking bit of brass is the main valve to let air out of the tank. and fitted to the back of the loco, along with the pressure relief valve. on each side of the loco are sand boxes with a bunch of piping and odds and ends of unions and elbows. the copper pipe is 1/16th diameter, an early Christmas present was a Badger sand blasting kit. The current state of the loco minus the buffer beams at the moment. The brakes actually do work here is a short video of them earlier Happy new year everyone. Michael
  12. Looking at the last photograph the 7th bulkhead from the bow looks a little bit low as the line seems to dip a little there. it is funny how some things show up in just one view. Michael
  13. Lovely work as ever Keith. I like the way you have the quick tool holders set up at the back of the lathe, slotting them onto the wood holders makes good sense. Michael
  14. Kevin that bench is Very Nice, the bench vice fits well. Michael
  15. I too received the Christmas Catalogue in the mail the other day, made for an enjoyable read, The "magpie" in me "wanted" the whole lot of those miniature tools. They do look wonderful and are really well made, I do use one of the older miniature wooden planes that they had a while back. O am with Bob on this one regarding the versatility and use of the older larger stable cast iron tools and tops. I recently cut a load of 1mm x 4 mm yellow cedar planks for Walrus Guy using my old 10 inch unisaw with a narrow kerf 200 tooth 8 inch blade and My old second hand 20 inch band saw with a 1/2 inch blade. That said I realize that I am very lucky to have those tools, and I have had the table saw for 45 years and the band saw for 20 years. My old workbench I have had for 45 years as well. In My view the low angle block planes by Veritas are the best value for money that you can buy for much of the work we do. with regards preparing wood to thickness for our models. Also a good sharpening system for keeping them razor sharp. I am not trying to persuade anyone from purchasing some beautiful Model tools, But do think about the reality of what they are intended for. And if anyone is thinking of sending me a Christmas present I would like the tiny chisels. cheers Michael
  16. Thanks for the kind words and it looks like you have made a great start. Michael
  17. At David Antscherl's prompting, I have just finished transferring all my notes and pictures in this thread along with the relevant questions and answers. to a word Document. Although this thread was chronological I can now sort out the various areas into their subject groups and properly organize them into a potential Monograph about this restoration, which might be of use as a book type document it will take a bit of time because there are 26,000+ words and lots of pictures. I do have high resolution images of pretty much all of the images, which were reduced in size for the forum. Just one more project to add to the many that are waiting. A couple more weeks and I should be back pushing a chisel into a keel for Skipjack the open launch. Happy Thanksgiving to all the Canadian folk out there. Michael
  18. Very Nice looking work there, It pay to take your time and as you can see the rewards are worth it. Michael
  19. Dear Kortes , I am not sure how I missed the rest of your build from about page 6 onwards, But have just spent some very enjoyable time catching up., What a treasure of not only beautiful workmanship and skill, but your step by step sequences are most valuable. It is amazing what can be done with simple common materials. That anchor is a testament to your skill and tenacity. The final display Cabinetry sets of the model very well. Congratulations again on a fantastic model. Michael
  20. The post op appointment went well stitches removed, looks a bit ugly at the moment will be able to get it wet again in a couple more days. Doc was pleased with the progress and my feedback regarding the lack of pain. There is a little bruising that will subside over time. I told him that i was using my fingers and he was pleased told me to keep doing it, I confided that I would lay of the WWF boxing for a while yet though, Made him laugh during these stressful days for the medical profession. Cheers Michael
