Everything posted by dgbot
Rookie Question About Finish
dgbot replied to rhephner's topic in Painting, finishing and weathering products and techniques
Try to find a flat wipe on poly if you can. David B -
Nicely done I would like to see that model at Manitowoc this year. It looks great. I will be looking over your log when I get to it. David B
- 39 replies
- new bedford whaleboat
- model shipways
I just finished your log. I wish I found it earlier. I have seen this vessels before on Lake Michigan and have always been fascinated by there loading and loading facilities and equipment. You are doing a great job. I think you should take your wife out to dinner more often to say thank you for letting me build this model in the house instead of the garage. David B
- 382 replies
- stadacona
- sylvan scale models
Proxxon MF70 opinions and accessories
dgbot replied to Keith_W's topic in Modeling tools and Workshop Equipment
When milling freehand one of the first rules that I learned is to take light cuts. A little at a time. This way you have more control and less of a chance for getting hurt. Also I must stress this wear eye protection at all times. I lost and optivisor years ago when a mini end mill snapped and hit the lens. Better a new optivisor ot safety glasses than a new eye. David B -
What is your rationale? I do not see much of a distance but my eyesite is not what it used to be. David B
- 4,152 replies
- cutty sark
- tehnodidakta
There are several tutorials on casting out there. The principal will be the same whether using resin or brittania. The mold can be a 2 part rubber mold or from modeling clay. Alumilite is one of the main suppliers. I also believe there is a tutorial MSW that will help you get started. The great thing about resin is it will show everything that is on the master including the fingerprints. David B
- 366 replies
Nice boats what kind of resin did you use? David B
- 222 replies
- gorch fock
- barque
I sincerely doubt it. I have found that these removable tabs come in handy when clamping or bracing. David B
- 625 replies
- bounty launch
- model shipways
CA glue and metal fittings
dgbot replied to cdogg's topic in Metal Work, Soldering and Metal Fittings
When using 2 part epoxy I will generally try to mix up just enough to do the job. Usually just a few dabs of each If there is a little to much so be it. You have to play around a little to learn how much you are going to need at any one moment. David B -
The next item was the deck gun and the the rest of the superstructure. Is this model perfect no. But considerering it is my first attemp at a new medium I am satisifed. The next time I do this kit I will apply what I have learned and will use different materials as well. The antennas will be replaced with wire and the tower will be attached in such away as to insure a square fit. I have done some research and have found a lot of little things that can be done behing the scenes. I had a good time and had fun and learned to techniques. To me that is what made this kit fun. David B
- 50 replies
- kingston class mcvd
- finished
Next came the tower assembly and the placement. Here I was a little off but I have learned what I need to correct this error the next time
- 50 replies
- finished
- 50 replies
- finished
After completing the hull I had to make a decision about using the parts for the superstructure. The basic pieces did not look good and were very crude so I used the advanced parts. This involved folding and bending and a exoeriemnting to get the right shape. I started out with the tower. Once this was assembled I cut out the antennas andglued them up. Needless to say I had to print out a few pages before I got anything decent. David B
- 50 replies
- finished
Once you have mastered casting you will never look back David B
- 366 replies
Congratulations Toni The sad thing is as you go further all that beautiful work will be hidden from site. David B
- 1,449 replies
Congtrats on a job well done. your fingers are more dainty and gentle than mine. David B
- 1,449 replies
Fantastic work Ed. Your planking is superb. David B
- 3,618 replies
- young america
- clipper
