Trussben
Everything posted by Trussben
  1. Work on the bulwark planking underway - then I have to decide if I’m going to paint it and add the fancy laser cut panels for the main cabins or not. I’m not a great painter but I’m leaning towards it for this model and trying to improve that skill set too. ben
  2. Typical spacing is 1/3 the width or height of the timber, so on a 9" timber you would place the treenails 3" from either edge, same deal with the chock - if its a 12" chock then they should be 4" from the ends. See TFFM Vol1 page 88 as it describes this perfectly.
  3. Work on completing the upper deck framing is coming along nicely.
  4. Looking great, just DONT forget that you need to sand the outside of the outermost frames thinner, back to the dotted line on the plan/template after you add the QG support framing.
  5. I use a Worksharp 3000 system for my full size chisels and stones for my really small ones.
  6. What I meant was the shape of your counter was too much, see your blue vs green line, use the shape of the frieze to improve that - I had the same issue and had to fix it some just like JJ - its easy to over sand that area when fairing the hull. My frieze didnt fit perfectly either,
  7. It appears to me that you have sanded the bottom of the lower counter too much, it’s easy to check - look at the plans at the stern section or print out the frieze for that area and hold it to the counter to see if you need to make adjustments, better now than when you come to plank and find it’s wrong.
  8. Work on Pegasus starts again. First on the list was to tie the upper deck into the wing transom.
  9. Chapter 4 work has begun. The 6 false deck parts have been installed, then the filler pieces for the hawse holes were put in.
  10. I did use the fruitwood gel stain that Chuck recommended, i just used a paintbrush to apply it not too thick, left for 5 minutes, wiped off with a clean rag and then used a dry brush to get it out of all the nooks and crannies and allowed to fully dry. Then I held them up to my hull planking to see if it matched and reapplied it as needed to get the right tone.
  11. A little more work at the stern gets me closer to finishing it up. There was a little bit of clean up needed around the lower counter and then the frieze and moldings below it were added. Also the rest of the cove pieces were installed and outer fish/dolphin figures added.
  12. 1:48 would definitely be my preference in scale and size as any bigger it will take up a lot of room when fully rigged, and I think it’s the perfect choice for a full rig. And obviously the matching scale with Winchelsea means you could display them next to each other.
  13. I’m certainly interested if you go ahead with this project in POF @ 1:48, with a full rig.
