Everything posted by gjdale
Hey, great news Danny! Best wishes for a pain-free move.
- 268 replies
Removing Blacken-It from Brass
gjdale replied to mtaylor's topic in Metal Work, Soldering and Metal Fittings
Mark, Have you tried cleaning with a wire brush in your favourite rotary tool? I find this the best way to get a clean bright finish on the brass prior to pickling in vinegar. I used this also on the refurbishment job I'm doing at the moment, and it worked really well. -
Wait til you see the Syren line - you won't believe the difference!
- 164 replies
- model shipways
- armed virginia sloop
Cutter Cheerful 1806 by rafine - FINISHED
gjdale replied to rafine's topic in - Build logs for subjects built 1801 - 1850
Rigging is looking top notch there Bob.- 525 replies
- cheerful
- Syren Ship Model Company
Just fantastic work Nils!
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
Glad to hear you're back on speaking terms! Changing your rigging line is one upgrade you will definitely not regret. It will save you a lot of heartache and your model will look better for it. I can't recommend Chuck's Syren line highly enough.
- 164 replies
- model shipways
Phill, Bad luck on the breakage - we've all been there. Take your time and sneak up on it. Sometimes it takes two or three "cycles" of soaking, bending, drying, to achieve the aim. When you've painted the cabin, just try to scrape off a little paint where you glue things. It doesn't have to be an exact science, but if you can get a wood to wood bond, it will be a lot stronger.
I think we've all experienced what you have just described, so don't feel bad. Take a break if you need to - the model will still be there waiting patiently for you to return (even if you CAN see it sneering at you!)
- 164 replies
- model shipways
Water and Heat are your friends when it comes to bending wood Phill. Everyone has their own preferred method for this, but mine is to soak the wood and the apply heat from an old steam iron. Sometimes, just soaking the wood and then clamping in place on the hull while it dries, is sufficient. Bend to shape and allow to dry BEFORE applying glue.
Sorry to hear you've been feeling poorly Jesse. Clearly though, you've had a cat scan! :P
- 1,306 replies
- syren
- model shipways
Looking good, Bob.- 525 replies
- cheerful
Likewise, John. Best wishes to Pam for a speedy recovery and to you for a "nuisance-free" existence.
- 745 replies
- francis pritt
- mission ship
