Everything posted by Ian_Grant
Sorry to hear that ...... the usual sequence would be stays first since they're along the centreline and soon become less accessible, then backstays. When rigging each stay, I attach a temporary backstay to the next mast behind, or something convenient, so I can tighten the stay and the backstay to ensure the mast is straight when I fix the stay. For this stage I work from stern forwards.
- 89 replies
- Cutty Sark
- Revell
Bill, if that is "S2" coloured in green in your pic, yes it is the mainstay, hooked at the shoulder in the stem below the bowsprit. You'd need to slide it down the bowsprit before adding the gammoning (will it go past your sprit-topmast?) if you want to tie the loop off-ship. It might be too late for you. 😒
- 1,508 replies
- Le Soleil Royal
- Heller
As long as I don't go past the point at which the grip on water requires too high a continuous torque from the sweep servo....🤔
- 536 replies
- Quadrireme
- radio
I think mine is perhaps more overweight than underpowered; I had to put in several pounds of lead to load to waterline. On the other hand it still lacks the second mechanism and the entire deck etc. When I guesstimated the ultimate weight of the wood hull I was conservatively heavy - better to turn out lighter and need ballast than heavier and sit too deep. You may recall I weighed my old battle-cruiser empty to see what its wood etc weighed; I'm wondering now if maybe I placed some ballast in the inaccessible areas in her bow and stern as I built her, 40 years ago....... I'm thinking of replacing the oar blades with blades 1/2" longer to catch more water, since the loom length was increased by 1/2" when I changed the geometry of the outrigger. It would be a bit painful but perhaps helpful.
- 536 replies
- Quadrireme
- radio
An abortive first water test has been conducted!!!!!! The port side mechanism is installed but only with the lower oars; upper oars need to be longer but I haven't made any yet. Here are a few pics. "Giant" scale sweep servo in port bow and linkage to mechanism. The standard size lift servo is just seen at left, along with the lift linkage at this end of the beam. Arduino electronics at centre. Still powering from a lantern battery for now. Lift linkage at the aft end of the beam. Shot from the bow. It was a nice, though sweltering, evening at suppertime. While I was putting lead shot into ziploc bags a storm started to blow in. By the time I got the ballast right there was a gusty wind blowing. Between that and the pool's circulating current it was hard for the galley to react to its oars, but I can see it will be pretty weak. I conclude that Richard Braithwaite was correct when he commented these models are for calm days only. Does it work well enough to bother continuing? Test is inconclusive for now, bearing in mind that it only has half the oars on one side. Might have to drive oars unrealistically quickly to get tolerable boat speed. Still, it was good to see it function without its umbilical USB connection to the laptop. Will try again tomorrow if it's calmer. ps My daughter watched and recommended adding a "cheat" propeller. 😭
- 536 replies
- Quadrireme
- radio
What indeed? Storing and transporting will be a chore. It will be 54" long and 22" wide with the oars thus very difficult to pick up in and out of water. I drilled holes in two bulkheads straddling the amidships point; plan is to add two metal supports, bolted in, with holes to attach some sort of handle when needed. Or maybe even have a permament handle rising to just below deck level. In the longer term I'll probably get bored with it once the novelty wears off and try to sell it. Assuming it works at all. As for our cat, he "settles" on our laps every time we sit down. 😉 My vet wife says orange tabbies are usually quite cuddly.
- 536 replies
- Quadrireme
- radio
Beautiful job! Sadly, I couldn't find a commission pennant for mine at the time; might add one someday.
- 527 replies
- caldercraft
- victory
HaHa! 😃 I read quite a bit of Polybius at the cottage on the weekend. Haven't yet reached the attack on Syracuse in the 2nd Punic war, but there was an interesting story about a battle between two of the restive Greek states between the Punic wars, not involving Rome. One side lashed their ships together in fours and put many marines on board. They then allowed them to go broadside on to tempt the enemy fleet. When the enemy ships rammed the outer ships of the lashed sets and became stuck in them, they were overwhelmed by marines boarding while the inner ships of the lashed sets held all afloat. Many quinquiremes were captured. Polybius has a good opinion of himself. He considered himself a "serious" historian and did research (and was actually present at some engagements) but he decries some other historians who recorded, in today's parlance, misinformation. Reporting on previous "historians'" discussions of a Roman senate meeting, he says, "All of this is as implausible as it is untrue - unless, of course, one of the gifts with which Fortune has blessed the Romans is that every one of them is born wise. But I need say no more about the work of writers such as Chaereas and Sosylus. Their work seems to me to have the status and importance of the common gossip of the barber's shop. It is not history." ...... LOL
- 290 replies
- Quinquereme
- Finished
To carry on a little more with this distraction: My wife really wanted to see the marine iguanas; she is a vet who looks after exotic animals (birds, reptiles, and plain old cats and dogs too) and this species is unique. I on the other hand really wanted to see blue-footed boobies, which we did, literally walking right by them. In fact, you are only allowed to walk on a designated path but some of the boobies, which nest on the ground, were sitting on their eggs in the middle of the path and you had to tip-toe around them as they stared at you. I can now say, to quote Dr. Maturin, "I have beheld the blue-footed boobie!". Mike, did you leave a postcard at Post Office Bay? Background for the uninitiated: in the 19th century whalers had a mail barrel on the beach here hence the name. Newly arrived whalers from Nantucket would bring mail for all the crews already in the Pacific and drop it in the barrel. When a whaler watered in the islands, they dropped mail for home into the barrel and picked up any incoming mail for them. When a whaler was leaving for home, they picked up all the mail for home and took it with them. Nowadays you buy a postcard, address it to yourself, and leave it unstamped in the barrel. While there you search through all the postcards to see if you can find one addressed to somewhere very close to your house. If so, you are to take it home and go to the peoples' house, knock on their door, and hand it over "special delivery". I was amazed to find a card from people a few streets over. We've been over a couple of times but they weren't home. Unfortunately, we recently received OUR postcard in the mail; someone brought it back to somewhere in Canada, stamped it, and mailed it to us. 😒 Idiots. It would have been a great surprise and pleasure to have someone come to our door with it instead, someday.
- 290 replies
- Quinquereme
- Finished
Glen, the hull looks great, and amazing job drilling so many tiny holes consistently! I wondered how you were getting the angles right; bending the brass oars is another great idea. I'm certain this will end up being my favourite among your builds so far. 👍
- 290 replies
- Quinquereme
- Finished
As I read it, after 1650 (and probably before) the deadeyes were stropped in iron, "probably" (he says) with iron "puttocks"/"futtocks" hooked into them (much the usual way for topmast futtocks) and the bottom ends of the puttocks bolted near the bottom of the bowsprit. The first way with deadeyes stropped in rope and puttocks above the bowsprit seems to me like a mechanically inept way of doing it, with all the sprit topmast strain taken by the knee of the top instead of the bowsprit; probably why Mr. Andersen is unsure of the scheme.
- 1,508 replies
- Le Soleil Royal
- Heller
HaHa!! Well, at least our cat is easier to move!
- 536 replies
- Quadrireme
- radio
Thanks! The blades are from cherry cutoff I had around; looking forward to them getting redder and darker over time. Thanks Marc! All due to jigs...😉
- 536 replies
- Quadrireme
- radio
Speaking of penguins ... 🫢... here are a couple of crappy pictures I took of a Galapagos penguin during one of our snorkels on our recent trip. My camera was one of those cheap "rentals" made of a roll of Fuji film encased in a plastic enclosure. I'm quite proud I managed to capture this little torpedo while peering through the tiny viewfinder with a snorkel mask on. Not too impressed with the film though; back in the day I used ASA400 for u/w shots. Not sure what this was. Should have bought a go-pro for this once-in-a-lifetime trip. I did get some better pics, a couple of which I added below. A couple of marine iguanas (the only iguanas in the world that swim and eat underwater), and a nice one of a sea turtle which shows improved quality when camera is pointing more horizontal as opposed to towards the bottom. By the way these iguanas get rid of excess salt intake by sneezing it out when lying in the sun on black volcanic rock on land to warm up again. On one of our walks we passed by hundreds/thousands of them with someone sneezing out white salt particles every few seconds. Oh, and my wife shot about 1800 pics on land with her digital SLR. Trip of a lifetime!!!! If you are at all interested in wildlife, I highly recommend the Galapagos. Glen, sorry to hijack your log! Carry on.....
- 290 replies
- Quinquereme
- Finished
Got the oars covered with three coats of Varathane exterior satin "Diamond Finish". Cured to a nice soft satin, surprising me with how nice the shafts look - the dowels were very pale. Here's a shot of the oars drying; just the 44 lower oars, I still have to make and finish 42 upper oars. Also went to the shooting range and bought a bag of #6 lead shot. Was interesting watching people skeet shoot while I was there. What is it with cats wanting to lie on all your stuff?
- 536 replies
- Quadrireme
- radio
Interesting discussion. It prompted me to dig out my old CS instructions from the 70's, and look at the (sad state) of my CS. I see I rigged mine according to the instructions. I'll just say a few things, noting that I have no CS-specific books either. Revell shows a kink in the backstays where they meet the spreaders which is utter nonsense. As far as I've read, the spreaders should not disturb the straight run of the backstays; there should not be a bend in them at the spreaders. Revell's instructions are quite clear that the mizzen topmast has no backstays at all. This is surprising to me, unless just maybe it gives the driver gaff more space to pivot? I see I rigged mine faithful to this. Revell's "backstay #3" to the topmasts is very vague as to what happens to it at the topmast. As George says they should loop around the topmast immediately above the crosstrees but it doesn't look like that on the drawing. I see I did topmast backstays two different ways on my CS; what did the teenaged me know? Underhill shows that iron lower masts often had a pair of backstays attached to eyes welded to the lower mast's cap. Revell's "backstay #2" could be a lazy way to rig them.
- 89 replies
- Cutty Sark
- Revell
Bill, those aren't supports for gammoning, they are a series of sheaves for future rigging threads which pass through them on the way to the fore rail. Make sure you have the openings through the assemblies clear of glue etc. To attach them? I would lash them, along with a little bit of CA to hold them while lashing.
- 1,508 replies
- Le Soleil Royal
- Heller
The main mast is the only one that goes to the keel, for some reason, in this kit.
- 1,508 replies
- Le Soleil Royal
- Heller
Thanks Steven, you mentioned this near the start of this log 😄 but it was so long ago now I guess you forgot........ 🙄 I saw that video before too. Interesting that the oars have that little pause; makes me think they aren't motor-driven. Wonder if he has a servo scheme too? Don't worry, my oars won't be going near as high as that. In fact, my galley will be calm water only, or the oars might be striking wavetops on the return stroke. I'm sure there will be a lot of software tuning once this boat is operational. Thanks, Ian
- 536 replies
- Quadrireme
- radio
Thanks! That's a good idea.....will look into it. Don't know how big these balls of shot are......
- 536 replies
- Quadrireme
- radio
Problem solved. Port side mechanism mounted in the hull. Checking the new oar geometry will work in the hull cavity without hitting deck beams etc when blades are in the water (pic). Upper oars will be 1/2" longer than lower oars, will need to make 42 of them. Existing 44 oars will be the lowers. Found out I can buy lead shot at a nearby shooting range. Planning to buy plastic film-roll canisters to fill with shot as opposed to pouring loose shot into the hull. Snag is I must buy 25 lbs of shot 🤨, will sell the remainder on. Pic shows extra blades taped to upper oars to depict their new length. Need to sand and varnish at least 22 oars; complete the mechanism install; install the 1/4 scale sweep servo; get the shot and ballast hull; try it in the pool with just lower oars on one side to see if they get traction. If so I will spend the money and time to mechanize the starboard side and complete hull decoration and painting. Not sure if I will get the deck built this year - our summers are short and should be enjoyed.
- 536 replies
- Quadrireme
- radio
By the way Glen, I think standard tile grout may be better as your wall mortar than caulk. The caulk will be hard to smooth out when dry, but grout is always just wiped smooth once partially set. No muss, no fuss.
- 290 replies
- Quinquereme
- Finished
