Posts posted by Baker
Great model
Much, much better dan 70% 😉
As always
Great work.👍
- mtaylor, Knocklouder, robert952 and 2 others
5
a good investment.
i have this book too.- catopower, Old Collingwood, GrandpaPhil and 1 other
3
1
Thanks Mike.
Next... Mary Rose, Mary Rose, Mary Rose 😉
5 hours ago, Tigersteve said:
Congrats on the finished model. Very nice work.
SteveThank you
- mtaylor, Edwardkenway, ccoyle and 7 others
10
Good luck
I also had the idea to build this (later...)
Some useful linkshttps://maritiemmuseum.nl/en/stories/masterpieces/mataro-nodell
- bruce d, mtaylor and Ferrus Manus
3
1 hour ago, petervisser said:
Hi Patrick. I just ran across your completed Pelican. An outstanding accomplishment and a beautiful model. Congratulations!
Cheers,
Peter
Thank you very much 👍
- Knocklouder and mtaylor
2
That is not good. 😲
Maybe best to remove the black lines first (fine sandpaper?) then you have more space to adjust the pieces -
Take good care of your thumb.
He is important to us. A healthy thumb gives us a good model 👍- mtaylor, GrandpaPhil and Glen McGuire
2
1
2 hours ago, Lee J H said:
The space between the ribs was stuffed with balsa wood.
A very good idea, nice work.
- BETAQDAVE and Knocklouder
2
The stem (problem)
So now I know why the water lines from MRNS were not correct. The rason was "a wrong" start with the stem. So this problem will be solved first.
The stem on this drawing is enlarged.
The difference is clearly visible.
The new piece
Oops...
Adjusting the front bulkheads and repositioning. (Mister Bosch is a very handy little thing for this).
And my assistant is also there (on the right between 11 and 12)
All bulkheads are bolted to the buildslip. And the water lines from MRNS are pretty accurate now.
Thanks for following
Part of the bulkheads are adjusted and ready. An opening is made in the middle.
Start aligning and attaching the bulkheads to the buildslip. The buildslip is first leveled flat
Aligning the bulkheads with the laser
Making sure that the screws remain accessible
The rear part is ready
The plywood keel has been sawn through (a mistake was made at the front). The final keel will be installed at a later stage.
Supervisor Felix has full confidence in this project 😼
- mtaylor, Ondras71, Roger Pellett and 10 others
13
Hello from the Antipodes
in New member Introductions
