Posts posted by RGL
Now, a few months off perhaps, school holidays and a garden to tend.
Next will be the HMS Victory of Battleships. I've done a bit of internet shopping for a few upgrades as well.
I bough a cheap first version off ebay for a bit of practice months ago, and you can see the hull sizes differ somewhat to the Dreadnought.
Thanks for all the likes and follows.
Greg
- ccoyle, Mirabell61, shipcarpenter and 29 others
- 32
Here in Australia we also have lawyers who specialise in "Family law", (divorce), who will clean you out and have you paying for multiple cats that you will never see until you die.
It's gets very busy up there when the rigging begins, making up a little jig with two pins, then three layers of battens will help you get them uniform is shape and size, and helps with alignment and getting those little bends at the end. I always make an extra for the inevitable breakage or loss.
In my signature block
In an exercise of supreme pointlessness, I have completed the starboard side torpedo nets.
Attaching the nets is somewhat of a nightmare, as the nets do not align to the boom, so I slung them under the booms, which is technically correct anyway. I used some helping hands to align then together and tied them up.
Then the rigging, all those brails finally have some balance and use.
Finally parked up for a while beside her sisters until I get a few more days off to finish the Port side. Then just add some flags and pull the plastic off the base and consign her to the digital graveyard.
Now for the next nerve racking adventure, the torpedo net booms. They have 1mm hooks which need to be glued into the hull points, then rigged up. I have only done the starboard side so far and it appears to have gone to plan, but I will have to add the gangways before I can add the net itself which I am still experimenting with for colour. There are brails which also need to be run but I done think I will as they will not be that visible, or maybe I will. It will get very fragile from here on in.
- Canute, Farbror Fartyg, clearway and 15 others
- 18
The colours on the deck are amazing, that is no easy task.
- Farbror Fartyg, cog, Canute and 3 others
- 6
- WackoWolf, Keith_W, Captain Slog and 16 others
- 19
Really nice work, lovely clean lines.
I reckon there will be a lot of other builds around. Generally where I get my inspiration from, Russia & Poland seem to have a huge community, use google translate for the words, cut and paste in a search engine and go to images. Probably telling you how to suck eggs tho!
I reckon if you've spent the $ on the upgrades you should. Not a biggie, and run an LED through the baseboard up through the supports (use some hollow brass rod) into the hull. There is a lot of imagination you could use there, even if you make the flight deck removable.
HMS Dreadnought 1907 by RGL - FINISHED - Zvezda - 1/350- PLASTIC
Mike, I constantly have to clean up around myself and put a little tea towel near my lap. I seem to look up and see myself surrounded by "things" as my workspace gets smaller and smaller. This was a very simple kit after the Varyag and the very bashed Emden. Everything went together very simply. I am in the process of research for the Yamato at the moment and it is daunting as it is a very non linear kit.
