Posts posted by RGL
I've got large paws Cog, if I can do it anyone can.
- cog, popeye the sailor, Canute and 1 other
4
Good to see you here Mike, Jan, OC, thanks for visiting
Some more pics. Pontos PE (Keith, got this set from Australia)
pontos.1.jpg pontos.2.jpg pontos.3.jpg pontos.4.jpg pontos.5.jpg pontos.6.jpg pontos.7.jpg
Some reference material
And the underside of the turret. At first I thought it were etched lines, looking more closely ... it's a mesh!!!
Cheers
Next nomination for most complicated i the ships crane. The tower was removed before the final mission so it is a bit easier.
As you can see there is one fret and a few bits of brass rod.
Comes together quite nicely, but I I had to do it again, I would use the individual wheels and rig it later as it would go together a lot easier.
I have placed it in an elevated position as I ant to sling a float plane from it eventually.
- BANYAN, GrantGoodale, GuntherMT and 21 others
24
So much easier than the grease proof paper I used to trace the things to make my templates!!
- popeye the sailor, BANYAN and mtaylor
3
Cog, hardly mastery, just slow and steady and lots of study, as the instructions are poor and I would like Pontos to buy a decent camera to show their assemblies. It's beautifully designed but poorly explained. I think their primary engineer is now at Infinty Models which might explain why their after sales service has dropped off.
Mike, I pretty much built my entire Endeavour with CA, it's just applying the principal of less is more and using the adage of never bring the bottle to the model.
Like a wooden ship, just keep making up jigs to hold stuff.
The Pontos ones are mini kits in themselves,with etch and brass rod, not easy to put together, but neither is it impossible. Comes together beautifully, and I have left the lid off for the moment for ease of painting. It just requires soft hands.
Next will be the crane, sans the Arial which was taken off before the final mission.
I'm putting off buying an airbrush until the bulk of the sub assemblies are done. As each piece takes days and days, there is no rush
- BANYAN, Captain Slog, Canute and 18 others
21
- Kevin, Canute, Captain Slog and 9 others
12
- Canute, popeye the sailor, mtaylor and 8 others
11
My God, not in this lifetime, I have the AOTS for a UBoat, to to it properly you would need to be a marine engineer. At this scale you could build a working model! Back in the 80's my father bought me a B-17 in this scale that was transparent and it was huge, and way too hard for me, and I'd find this way too hard 40 years later.
I've never entered a competition but I reckon it would do my head in as I can only see the flaws!
- cog, Old Collingwood, mtaylor and 1 other
4
IJN Yamato by RGL - FINISHED - Tamiya - 1/350 - PLASTIC
Next is the 25mm single(portable) guns. Thanks goodness I only have to do 6 of them. They are tiny, and whilst not perfect, will do and I expect they are a little too big.
As you can see from the Pontos instructions, you need to be a bit of a mind reader, but keep referring back to the reference materiel. About a full day's work.
The brass pedestals have four 1mm support struts each, and a base which the pedestal penetrates through which will go into the deck.
Then lots of folding (some of the bends are <1mm). then throw it together.
