Hubac's Historian
Everything posted by Hubac's Historian
  1. A remarkable build, and a well deserved victory lap! Congrats, Michael!
  2. Last week, I had a very informative correspondence with Carol Wedlake of Alumilite customer service. When I explained to her what I had in mind - to make multiple impressions of my master in earthen clay, and then cast with Alumilite resin - she explained that the moisture in clay may react poorly with the exothermic reaction of the resin, and that I may end up with a bubbly mess that bears no resemblance to my intended carving. If I wanted to go that route, she explained, I would need to use a compatable silicone release agent, in the form of a spray, but even then, my best result would adopt the surface texture of the clay. In short, she convinced me that - while it would be nice to make as many impressions as I wanted and cast the bulk of my requirement all at once - the best results would be obtained by using Alumilite’s 2-part mould putty. I looked at a few vids on YouTube, and sure enough nothing could be simpler! I was so very close to making my first castings. I had everything ready to go. I mounted my masters to a small plywood block with cyano, so it was permanent; I was committed to making these carvings work. Then I went to Michael’s craft store - a huge one on the Upper West Side. They had everything, the mould putty and the Alumilite white resin. I was completely psyched. Until I got to the register. They wouldn’t sell me the resin because, apparently, that lot of resin was recalled for whatever reason. I went back to the shelves and pulled every box they had left; all recalls. I was disappointed, but I figured I’d buy the mould putty and source the resin elsewhere. Well, that was a bust as well. Davinci’s Art Supply on the Lower East Side did not have it, although they had a similar white resin. For $26, though, I wasn’t taking any chances. Nothing at Jan’s hobby either. Tomorrow, if I have time, I may go to Davinci’s Chelsea location where I know they will have it. So, just as a refresher, the ornaments I am adapting here can be found surrounding the arched main deck ports in the following closeup of Berain’s drawing: While waiting for my next opportunity to go shopping, I got busy making a series of moulds. Including the bow chasers, there are 30 port openings on the main deck level. I figured that, if I make five moulds, then I can cast my whole lot in six pours. I won’t need all of the lower port enhancements because the position of the channels sometimes interferes. I plan to bisect these smaller, extra scrolls and place one to each side of the stern chase ports. Mixing the mould putty was as simple as the instructions say, however, you really only have about three minutes to form your mould before the putty begins to stiffen and cure. It was interesting to me that, despite what I thought was a thorough effort to press the master into the putty, I was still left with small air pockets toward the ends of the lower port enhancement. Evidence of this can be found in the lower left scroll of the lower port enhancement, which diminishes with each successive mould pressing, as I perfect my technique (moulds 1,2,3 L-R): I suppose that over-manipulation of the putty, around the carvings, before pressing down on a flat surface may introduce small air pockets. With such a shallow ornament, it seemed better to simply press the master down into the mould putty. I will still use the other moulds; it will just necessitate a little extra cleanup with a sharp gouge. The final two moulds continue to show a diminishing of this air pocket, until by the fifth mould, I have a perfect pressing (moulds 3,4,5): The other things I have been occupying myself with, when there’s nothing else I am equiped to deal with, is to begin the hateful and laborious scraping away of the kit’s original upper bulwark frieze, along with most of the thin sheer strakes: I begin with a Dremel drum sanding attachment to remove most of the waste. Then it’s onto a medium spherical burr, which is followed with a bottom cutting cylindrical burr to level the work as closely as I dare. Following that, I double stick 150 grit paper to the bevel of an 1/8” chisel and I sand away the raised detail until there is no shadow evidence of it left. There’s still more to remove; I must clean up around the round port openings, and cut neat end stops for where the sheer strakes will remain - sourrounding sheer railings. I will scribe back in the plank lines where they were covered by ornament before, and I will center new plank lines on the location of where the sheer strakes had previously been. I’m not too concerned about the sanded texture of the plastic not matching the moulded wood grain because the new ornamental frieze will be fairly dense and this background will be painted blue. For good measure, though, I will probably hit all exposed areas with a fairly coarse paper, like 80 grit. In preparation for the newly casted port accents, I also busied myself with cutting out and attaching these small ear drops, at the top of each domed port side. I have installed them overlong, and will scribe the top port accent to fit: Now I’m off to Davinci’s in Chelsea to buy me some casting resin. Sometime later this week, I’ll have an update with at least a few ports complete! Thank you to all who stop by - your comments and your likes are always welcome here.
  3. I just linked to that Veritas page. Those chisels are made by Beebe, and I own a pair of chip carving knives from them. The one I use the most is a curved, double beveled blade that enables me to do a wide variety of carving with very few conventional sweeps. The quality of these tools is second to none.
  4. I still have my Marple Blue Chips, and I still love them. They keep an edge for a reasonable time, and with compound/strop re-touching they can stay razor sharp for quite a while. The steel is of a decent hardness, but not so hard that total re-sharpening is a hateful chore. I think that the line is now under the Irwin name. I have an 1/8" Irwin that I find to have the same properties as the Marples chisels. I always meant to buy a really special set of chisels, but then I stopped professional woodworking and find that the blue chips more than satisfy my needs. I would, however, like a set of quality micro chisels, so I will have to look into that Veritas set.
  5. Hi Chris, 1/4” can be difficult to gauge for perpendicular. It may seem and look right until you try and mate it to the adjoining piece, that was also squared by eye - only to find that one face of the joint is tight and the other face seems wide open. When it’s critical that I have two perfectly mating surfaces, I will sometimes do the following: Surface a piece of stock (1” thick) on two sides, so that the piece is perfectly flat (no bow, or cup), and be sure to make the piece large/long enough to clamp to your work surface, while still leaving enough hand room to work comfortably. Square at least one straight edge to both faces. If you don’t own a good try-square, it is always a sound investment; IMO, Starrett still makes the best rules and squares. Place a loose piece of 1/4” stock that exactly matches your part thickness, and is large enough to support your paring guide-board above, onto a flat surface with enough overhang that you can align your joint layout with the square, straight edge. Clamp down tight. If there is a thousandth, or so, difference in thickness between your part and the spacer board - and the part is still loose after clamping the guide board - then a strip of blue painters tape on the backside of your part will close that gap. If your rough cut is already within 1/32” of your line, it isn’t even necessary or desireable to make chopping cuts with a mallet; there is too much force involved with chopping, so that the likelihood of shifting your guide block or un-intentionally undercutting the joint is significantly greater. As long as your chisel is razor sharp, you can make shallow, paring cuts until the flat back of your chisel is right up against your guide block. Repeat for the mating surface, and you should end up with a perfectly mating joint and an assembly that stays closed on a flat surface.
  6. They really are basic, aren’t they? Everything else is so magnificent that they are easy to overlook, but then there they are. Ha!
  7. Sorry you are not feeling well, Doris. Take your time and feel better. I’ll be here when you get back.
  8. I think that when you get to constructing the upper finishing of the quarter gallery - with its domed top and coved central recess for the statuary - that the complex shapes would make an excellent topic for an instructional video. That is, if you intend to build them up in the same way as the rest of the QG. Perhaps not, if you are going to carve the upper finishing from a solid block, instead. I also admire your courage in cutting down the sheer, although I agree that it is right to do so. All the best, Marc
  9. The directive from the Crown, across Europe as the 18th C. developed was to trend towards a reduction of unnecessary ornament. However, that the great yards in England and France, in particular, where there were deeply entrenched familial traditions of ship ornamentation, which continued to ignore the directives of the crown for as long as they could get away with it, speaks more to a class of artists/artisens who were trying to hold onto their livelihood. This is my opinion. Pride of state is a hallmark of the 17th century, but by the 18th century - I agree with Siggi that it is the pride of the yards that keeps the tradition alive, until eventually, the yards just wouldn’t pay what the work was really worth.
  10. I love your ingenuity, HJX. Your approach opens my mind to what is possible
  11. You’re a star, Doris! Thank you for taking the time to illustrate your process, here. You have really de-mystified something that seems complicated; that is, in fact, quite difficult to achieve; and explained it in a way that makes it possible for someone else to achieve it. Thank you, again, Doris! Also, I like your alteration to the window heights. This makes more sense, and the change is a good example of where the modeler, sometimes, has to parse through the intent of the artist - even a really good marine artist like Vale.
  12. I would love to see a photo essay of that process, Doris, but your description gives me a pretty solid idea of it. it seems that steam is the key to getting the card to conform to compound curves. The difficulty must be, first cutting a bit oversized, but close to openning size. Then, once you have the shape you want, trimming edges to land, on-center, on the framing members; more art and intuition than science, I would imagine. By all means, though, post pics if you have the time. Your method, here, is of particular interest, as I consider how I will construct the convoluted surfaces of Soleil Royal’s QGs. I very much appreciate the explanations.
  13. Ahhh, I see. Another question: how do you get the (card?) panels of the quarter galleries - within these framing members - to follow, so neatly, the compound curves that the underlying framework dictates? Because they are painted black, it is hard to read these surfaces for their shape, but they appear to follow these forms perfectly.
  14. Well, you’re a quick study on the tools! Great beginning!
  15. Hi Doris - Marvelous progress! What is the material you are using for the thin moulded strakes that frame the quarter gallery panels; wood, plastic or card?
  16. My prefered carving school of technique - Praying Mantis/Tingling Fingers - has slowed my progress in recent weeks. I’ve been experimenting with an assortment of elbow and wrist braces, in the hopes of relieving the cubital and carpal tunnel symptoms I am experiencing lately. Wearing the wrist brace while carving, tonight, made the work more challenging, but less uncomfortable. So, that’s an occupational work in progress. But, at least now I have a castable pair of port accents, and I have satisfied my curiosity as to whether carving styrene would produce results I like. I think that if I were carving in boxwood or pear, the lines would be a little more crisp; I carve the styrene with shaving cuts, but much of the shaping is done by scraping micro bevels that the eye reads as a domed surface. However, you can also scrape a hard crease. The surface just isn’t as cleanly cut as it would be with wood. For my purposes here, though, it is more than adequate. With paint, it will show light and shadow, and that will give the carvings shape and dimension. So, next I just need to buy some casting clay and resin, and we’ll see if my next experiment works.
  17. Big score on Pinterest, this morning! I had never seen this before today, although I recognized the vessel right away: This is the Foudroyant of 1723, as painted by the Austrian genre painter August Mayer in 1834, and which is definitively based on the original ornamental sketch by Antoine Francoise Vasse. The overall sense of the composition is quite faithful to the original. It is interesting to me that this painting was done at the same time as Admiral Paris's stewardship of the Musee de la Marine, and Tanneron's work, there, as a model maker. This is just further evidence of a resurgence of interest in the ships of the Second Marine, and a sincere effort of these men to preserve what was known about them. It is interesting to me that the QGs of this Foudroyant (above, left) are quite similar to those employed on what I believe to be SR2 (below, right), which was initially intended to be the Foudroyant of 1693, but was renamed and re-decorated as SR2 What I really love about this Mayer painting, though, are the colors. Although this ship is 34 years after the re-fit of SR1, the ornamental style, by Vasse, captures the best characteristics of Berain and Puget's influence. And it is this use of red on the stern counter, and Ultra Marine blue on the tafferal that I intend to use on my version of the ship. Also interesting to note that what I had previously thought might be a scrolling banner, on the lower transom of SR, as depicted by Ludolf Bakhuizen in his Battle of Barfleur, must simply be the rudder chains that you see here, on Foudroyant. That likelihood, notwithstanding, I probably will still do an ornamental banner, below the chase ports, with "Nec Pluribus Impar" inscribed; not unequal to the illumination of many (suns).
  18. Great work, as always, Doris! I’m really excited to see your method for framing out the Quarter Galleries.
  19. Thank you very much, Marc! How goes it with your Royal Balsa - have you had much shop time, lately? I am eager to see an update.
  20. Welcome aboard Kevin, and thank you for taking an interest in what I am doing - albeit verrrry slooowly. Why bother with popcorn when scotch is more fortifying Will you be bringing some of that?
  21. Here is the lower port enhancement carved to shape, with the un-carved upper enhancement for comparison: Carving styrene is interesting. I was a little apprehensive because the black styrene of the kit is comparitively hard and difficult to scrape and work. This white stuff cuts easily. There’s so little material to remove, and yet it takes just as long as it does to carve wood - I think because there is so little margin for error, so consequently, every cut is measured very deliberately. But this one was comparitively small, so the upper carving should be easier. The volutes of the scrolls aren’t carved so much as suggested.
  22. This is just going to be a great one to watch develop. Crispy clean work!
