Posts posted by Beckmann
- JeffT, GrandpaPhil, Ryland Craze and 3 others
- 6
- GrandpaPhil, Ryland Craze, Saburo and 5 others
- 8
I must admitt, without all the assistance you provide chuck, people like me would probably never start such a model projekt. If I come home after work I have about 1 hour time every second or third day to go into the Workshop and make some progress. You make it all very easy, so fulltime busy people still can have some model-building fun and make some progress late in the evening.
- GrandpaPhil, Saburo and FrankWouts
- 3
- RBohlman, Matt D, Robert Sargeant and 9 others
- 12
I did transfer them. I made a cut in the surface of the bulkheads with the chisel. One can hardly see it on the photos, but they are there.
- Saburo, JeffT and FrankWouts
- 3
There might be a problem to get it planked. MDF has a good surface, but if you cut it, the surface is a bit fibrous and extremely absorbent. Another Point is, that it as far less stable then plywood, the narrow beams of bulkhead 27 for example will probably just break of, if you sand them in shape. That might actually happen to all the small top parts of the bulkheads.
Hello everybody,
to finish this build Log, here are some photos of the Display case. I altered the baseboard by reducing the mirror-surface. I think it looks better like this and confuses not so much, if one looks at the model. The mirror area still allows , seeing the unplanked bottom of the barge. Now I just need to finish the varnish of the baseboard, and thats it done.
One word to Chuck:
Thank you for this fantastic kit, it was really fun to build it. Looking at the barges in NMM, Greenwich or the book about the Kriegstein-Collection makes me think, how nice an oarsmen-crew would be. Maybe one day, you should talk to your chinese carver, (Jack was his Name?) to develop a resin-casting for one ore two types of oarsmen. This is such a popular model, I am shure you will sell hundreds of oarsmen, to man all the barges. How many did you sell by now? Maybe 150 barges, that is a demand of 1500 oarsmen :) !!!
Matthias
- bruce d, GrandpaPhil, Ryland Craze and 5 others
- 7
- 1
Okay, I will use cedar then.
Just a question: using the cedar laser cut kits and planking with boxwood strips is propably not a good idea? Or do the both match well together?
- FrankWouts, Jorge Diaz O and mtaylor
- 3
40 minutes ago, Beckmann said:
They look really fancy. If I would buy them, my daughters would take them away anyway for bookstands on their shelfs, so I better make some simple ones myself
- FrankWouts, Saburo and GrandpaPhil
- 3
- AnobiumPunctatum, Saburo, JpR62 and 10 others
- 13
Hi everybody,
after finishing the Queen Anne-barge, I am quite excited to join in the Winchelsea project.
Yesterday I got started, printing all the plans and cutting the first plywood peaces for the bulkheads.
I use 6 mm birch plywood (the heavy one) and made the main part out of one Peace (not 3 peaces like the laser-cut Version)
Matthias
- GrandpaPhil, FrankWouts, tarbrush and 12 others
- 15
How did you blacken the planks? Did you paint them or pickle them, before you glued them in position, or did you use ebony wood?
- Canute, mtaylor and FrankWouts
- 3
Yesterday I installed the oars. I like them being in place like seen on the photos, it gives an Impression of speed. Although this is quite a space-consuming way of displaying the model, I think I will go for it. I also made a mirror-baseboard, so one can see better the unplanked bottom of the model. Next I will made the showcase.
Matthias
At the moment I am busy making the oars. I had some Problems, sanding the blades in shape, because they kept breaking off. Maybe it is an idea to make the pole and the blade out of one peace. The adhesive Surface between them is very small.
- KARAVOKIRIS, Chuck, CaptainSteve and 3 others
- 6
HMS Winchelsea by Beckmann 1/48
in Member Build logs for the HMS Winchelsea
Posted · Edited by Beckmann
Don't wory, I wont get ahead of you. Your careful step be step instruction and the laser cut kits makes it so easy. I rather wait on chapter 2 than making mistakes.
