Posts posted by Beckmann
Your model is perfekt, and your photos are as well. How do you do that? Such a white clean Background!!
- Stuntflyer and FrankWouts
- 2
SLR0346, a frigate from 1805 has got red coamings as well. At least in the waist. The quarter deck coamings are black.
Hi Martin.
A phantastic model. What a highlight for each livingroom. I made a display case out of special wood strips you can buy for cases. They fit for 4 mm glass. I painted them black. But you can also give them some varnish. Then just buy the 5 peaces of glass and stick it together with some transparent silicone. Leave the top and maybe the front glass without silicone, so you can open it, if necessary.
It worked well. Here is a photo of the display case.
Matthias
- BenD and GrandpaPhil
- 2
Maybe the coamings on the quarter deck were painted black to give them a better protection, because they were more exposed to the weather. This might have not been necessary in the waist.
This is the profile I tried to come close to.
I made the scraper out of an old saw blade. I used dremel and files to form it.
then scraping the boxwood strip. With not much force.
and then bending and gluing it in position
I find bending this profile really difficult. It is so small, but very resiliant when you want to bend it.
Matthias
- Saburo, FrankWouts, JpR62 and 6 others
- 9
Hi Mike,
the moldings look brilliant. Would you mind showing us your scraper and how you made it?
Thanks Matthias
- JpR62, FrankWouts and Stuntflyer
- 3
I made some corrections. First I managed to carefully cut loose the stern frame from the planks and filler peaces. Then I reduced the length of the planks a tiny little bit, in order to get the stern frame a bit more upright. Next, I removed the bottom peace of the qgallery. After checking with the Papier template I glued it in position again.
Matthias
- JpR62, Edwardkenway, GrandpaPhil and 8 others
- 11
Chuck, I certainly will. And thank you for your patience. You are amazing, spending so much time getting my model right.
Matthias
- Rustyj, Ryland Craze, FrankWouts and 1 other
- 4
- JeffT, FrankWouts, Matt D and 5 others
- 8
Hmmmmmm....
I propably forced the stern frames too much back, when I glued the filler pieces between the last bulkhead and the stern frame. This can not be corrected any more. Maybe I must make new quarter gallery windows with a tiny little bit more distortion. Otherwise the forward ending of the quarter gallery will lift too much up. The angle must be parallel to the planking. Is that right?
- coxswain and FrankWouts
- 2
- FrankWouts, Saburo, GrandpaPhil and 1 other
- 4
- Ryland Craze, coxswain, Rustyj and 14 others
- 17
- rafine, GrandpaPhil, Edwardkenway and 11 others
- 14
Hi Rusty,
I am not shure, but check your left and right stern frame. They seem to be too wide. I made that mistake and it was awful to correct it after having glued the transom in position.
Matthias
Hi Matt,
thank you for your compassion
Matthias
They happen quite often in my building of Winchelsea. I hope, I can reduce that in future.
I had a little battle with my Winnie and that is the result.
First I removed the small planks behind the door to the Qgallery. Then I shortened the 3 planks above and cut them loose from the frame. After correcting the shape of the frame I added the Qgallery transom peace and glued everything together again. I think it is close to the position it should be now.
And thank you Chuck and Mike for your help.
Matthias
- GrandpaPhil, Chuck, coxswain and 11 others
- 14
Hi Doug, I am fine thank you. It has been a while now, that I did some work on Leon. I was pulled away by Chuck‘s Winchelsea. But I will certainly keep working on Leon. Concerning the companionway, I am not shure. But there is so little space and the hatch is in the way. So I just did not add it yet.
I will have to do some more research.
Matthias
Thanks Chuck for the advice. I will carefully try to correct the shape by removing the short planks behind the door to the Qgallery, maybe I manage to cut lose the 3 planks above and then correct the shape of the frame.
Today the parts of chapter 3 arrived, so I have a good guide with thd laser cut part.
Yesterday I glued tue transom in position. All looked well. The ivory windows fit is not bad as well.
but today I realised, that I produced a severe problem by not sanding down the outer frames enough.
I don't know how to fix that yet.
I have seen this problem in some other build logs as well, so check that guys, before you glue the transom in position.
Matthias
- GrandpaPhil, shipcarpenter, Jack H and 1 other
- 4
Ship paintings
in Nautical/Naval History
This "afternoon quicky" is a masterpiece Jim. You should publish your watercolours. They are marvellous.
Matthias
