Everything posted by hamilton
Hi Peter! Happy New Year. The ship's boat looks great - have you decided how to add it? I haven't seen any images that might act as guidance but if I come across any I'll send them your way.... hamilton
Excellent work Tim! Love the coppering and the special sans-sails rigging! I'm looking forward to following your Cutty Sark when the time comes - hope you have a great holiday and bye for now! hamilton
Hi Tim: She's looking really great! Nice work on the rigging - the "fake" running rigging shows some interesting set-ups. Well done hamilton
Like the way you set up the topmast backstays - I followed the kit plans but I think yours look much better! hamilton
Alright Tim! I've also rigged ships without sails in the way you describe (most recently the Fair Rosamund). I think either way is acceptable. As for Syren - I have had the bandsaw out!! I had to cut a new bulkhead because one of the kit-supplied ones had really bad wood - big old holes in the face of an already-fragile bulkhead extension....the new one works great and is very solid - if I had enough 3/16" ply I'd have remade them all, but I need my supply for the Bluenose when I finally get back to her in the Spring....Syren is slow moving, but I've started on the gunport framing (last night, which was my first night modelling in almost a month!)....anyway, looking forward to more updates here hamilton
Hi Tim: Here are a couple of pictures of my Glad Tidings to illustrate some running rigging with no sails - peak and throat halliards are included on the gaffs, but you can see they're lowered to deck. Forward I also included the jibsail running rigging (halliard & downhaul anyway). I imagined (perhaps incorrectly) that the gaffs and booms would be lashed together (though this was "modeller's convenience" since I didn't want the gaffs floating free on the horizontal and wagging back and forth). With America this would be tricky with the fore gaff since there's no boom....I'm really not sure how you would fix it, except at the jaws. On some of my early models, I set a small rod at the fwd end of the gaffs and then drilled a hole into the mast to receive it - this would fix the gaff and provide extra support and reduce any lateral movement....Anyway, hope you don't mind me posting the pictures here..... hamilton
Good to see an update here Tim! She's looking spectacular! I like the optical illusion in one of the photos of the tweezers floating in the bowsprit rigging! Had to widen and narrow my eyes a few times to correct for it! Anyway, the rigging looks great - really brings her to life! Looking forward to more hamilton
Looks great Peter - I found the holes on the belaying racks to be too small on mine as well. But instead of trying to widen the holes (didn't want to try after my experience with the deadeye strops) I sanded the belaying pins themselves to be a little thinner....Anyway, the masts look really nice - she's shaping up very well hamilton PS - where I am in Canada there is maple, but not much - mostly softwood here - back east it's much more plentiful h
Looking good Peter - the stand looks very nice - I just used the one that came with the kit....yours is much nicer hamilton
Hi Peter: Actually once the deadeyes/chainplates were attached to the hull there was no issue. But one modification I made to the chainplates (not sure if you did this) was to snip off the mounting pegs on the back side of the chainplates and just glue them directly to the hull with a small amount of epoxy. I was a little nervous that they wouldn't hold, but in the end they were fine and there was no snapping or breaking of these small parts....thankfully! The Syren is moving slowly! It's a really busy time at work, so not much modelling getting done at all. I did have to cut a new bulkhead because one of the ones provided in the kit had a great big gap running along the edge, weakening it considerably. Fortunately, I have a decentl supply of 3/16" maple ply lying around from my Bluenose scratch build that I could easily cut a new one. I've now gotten to the point of assembling the basic framework and rough fairing the hull. When I'm able to get back to it, I'll be starting on the gunport framing.....I might post a casual log once my plate clears at work.....perhaps over the Christmas holidays.....in the meantime, I'll just enjoy your build and others on this forum! hamilton
Looks really beautiful John - you should be proud! I love the choice to show the forward port side whaleboat being launched - a classy touch! On the the next? And what will that be? hamilton
- 159 replies
Hi Peter: Looking good - I found those deadeye strops to be way too soft! I ended up breaking one and improvised a repair by using a modified gudgeon leftover from my HMS Blandford....it's on the non-display side of the model so it's not too offensive. You obviously were more careful with yours than I was! hamilton
Hi Chris: Are you following the planking expansion that ME provides as a plan sheet with this kit? So far your planking looks good, but when I was reading about your woes earlier on, I wondered if you were following their scheme or spiling the planks on your own.... Where the plank edges are exposed, you should use a scalpel blade (#10 x-acto) to "take the edge off" and then sand liberally to get a nice smooth hull. Keep on going my friend!! hamilton
- 54 replies
- glad tidings
- model shipways
Hi Chris: Per's right - there is little space between the bulkheads! But I think you'll find that this makes fairing and planking quite a bit easier. I built this kit a couple of years ago and it still stands out as one of my very favourite builds - lots of fun and at a large scale that allows for some interesting detailing. Looking forward to seeing yours come together and happy to answer any questions you might have as you go through the build (if I can remember!) hamilton
- 54 replies
- glad tidings
- model shipways
Hi Peter: I found the scuppers to be very tough too...I ended up drilling them out very slowly starting with micro drills that were quite small and very gradually opening them up from both sides and using jewelers files to square them up. Another trick I learned was to clamp a piece of scrap hardwood on the opposite side of the drill to prevent the wood from flaring out when the drill went through...mine still did not turn out perfect...it's a very tricky business...but I still think your America is coming along very nicely.... hamilton
Thanks Tim - welcome aboard! Hope you're a patient man! I have no dry-cleaning bag to put BN under, but at present, I have no keel, and no time or ability to cut a new one at the moment.....could be a long time before I strike this build up again....I have to do all my cutting outside and we're in the rainy season up here....waiting for a dry spell to make new keel pieces, and then onwards.... The good news is that I just got a wood shipment for this project and can proceed with some speed once the framework issues get sorted out....bye for now! hamilton
Thanks Jond - I imagine that a lot more work goes into people's models than often makes the log - I can think of a few notable exceptions here. I hope that my error can be of help to anyone going down this path in the future.... hamilton
I guess you have to be a bit grumpy to balance out the food, wine and scenery..... hamilton
