hamilton
Everything posted by hamilton
  1. Thanks Allan! I'm flattered you came by! So far the toughest aspect of scratch building is figuring out how much material I'm actually going to need.....I have a suspicion that I'm going to spend a lot of money on wood and other materials that "won't end up getting used" - in quotes because I know they eventually will get used...... Also - starting with the BN feels more like dipping a toe in the lake rather than diving right in......I'm not sure what's on the bottom or exactly how chilly the water is......the MS plans are very detailed and take a lot of the guess work out of things - though developing some drafting skills is something I would truly love to do.....more for the future! Bye for now hamilton
  2. Hi Jond: The trip to Lunenburg is definitely worth it. I grew up just up the road from you in New Brunswick (spent a bit of time in Portland and Bangor as well). Anyway, I wish I had the kind of space you've got for modelling! This will be a really interesting project to see come together. hamilton
  3. Hi Jond: Thanks for stopping in - I took a look in on your build log - that's going to be HUGE! I'll follow with interest for sure....bye for now hamilton
  4. Minor update on Bluenose...... All the 3/16 framework parts are now cut and I've begun to refine them and prepare them for assembly, section by section. Because I can only work on Bluenose for a few hours a week, the progress is relatively slow. I started with the forward keel piece (1), testing it against the plans and marking it up where adjustments needed to be made - a particularly fussy area was the joint with the centre keel piece (2), which needed quite a bit of shimming and trimming for a decent fit. I'll also have to do a bit of work on the fwd joint of keel piece 2 (especially at the top/deck line) to make things fair..... I then needed to mark on the rabbet and bearding lines on both sides of the keel part....technically I should have waited to do this until all the keel parts were assembled so I could be assured of a smooth run of these important lines....but I decided instead to throw caution to the wind! I figure they're just pencil marks so I'll see how things line up and make adjustments later - worst case scenario I'll have to make a template of the full run of the lines and remark them.....not the end of the world. I made templates off the plans and marked the lines from the templates. They look a little rough in these photos but I've cleaned them up since.....Once these lines were on, I drew in lines from the bulkhead slots to the bearding line for purposes of squaring the bulkheads.... The next step was to dry fit the bulkheads. This was a matter of filing out the keel slots on the bulkheads slightly (all were tight) and the bulkhead slots on the keel slightly. Some of the slots needed to be filed down a bit so the reference lines would line up properly and so the tops would be flush on the top of the keel. In seating the bulkheads I noticed a couple whose tops needed to be sanded down a bit further to sit flush. The tops also needed to be filed down for the deck sheer, and then faired slightly (using sanding blocks and files on both the outer edge and the inner edges of the bulkhead extensions). Final fairing will be done later obviously.... I also discovered that I had to recut bulkhead "A" and make significant adjustments to bulkhead "E". This is what I did today. That does it for the forward keel and bulkheads....next week I'll start work on the centre section..... That's all for now. Thanks for stopping by hamilton
  5. Hi Jon I invested in the first volume of TFFM and it describes what you're talking about in great detail (with illustrations and photos to help with visualisation). I have not built a fully framed model, but I can see how this and the other TFFM books would be invaluable in this process, especially for those cutting their teeth on this approach. I will likely buy volume 2 this Christmas and use both for general tips in the construction and outfitting of my Echo cross-section (once I build up the guts to tuck into that project....) hamilton
  6. OK - it's time to turn this into an official build log by documenting the beginning of the build....these photos may look familiar - in fact they're almost identical to photos posted earlier of my tests...the difference is that this is the real deal.... I remade patterns for the keel pieces, bulkheads, sternpost and rudder and arranged these on 4 3/16" birch ply billets. I then dragged out the bandsaw and managed to get through 2.5 of the billets before my wife came home with the kids and I had to pack up.....I also took my disc/belt sander for a test drive cleaning up the parts after cutting - I already see the great utility of this tool! One issue is that because of the depth of the gap between the belt sander and the frame I can't use the belt sander to clean up all the bulkhead slots....I'll take a file to these later....in the meantime, I'm quite pleased - I've only really botched one part so far (bulkhead "M", which I'll have to redo) - with a bit of finessing, I think the framework will come together just fine.... Anyway here are a couple of photos - it'll probably be back to the America during the coming week (making sails, and finishing the rigging), but while the weather's nice, I'd like to get as much into the Bluenose as possible - once the framework's done, I'll be able to move the build inside for planking, etc.... bye for now hamilton
  7. Thank you all for your comments - very sage advice!! I'll have to give it some consideration - fortunately I do have an excess of fabric so I can try a couple of things to see what works/handles best - I'm definitely not going to spend 300$ for a grommet press!! I think that's a definite.....as for the rest, seems like there's latitude for experimentation. Thanks again and bye for now hamilton
  8. Hi there: I've seen grommets represented on the feet, luff and head of sails (mainsails) through which the lashing runs. Can anyone describe/post photos of a technique for attaching these to the sail? The instructions that came with my Mamoli America kit are extremely vague but reference riveting the grommets on....there are some extremely small grommets that come with the kit for this purpose, but I have no idea how to rivet them, nor how really to attach them to the sails....my instinct is to simply fasten them on from the display side only, but I think that ultimately this would look bad..... Any and all suggestions would be most welcome! Thanks a lot! hamilton
  9. Hi Tim: The parts you're referring to are "hearts" -- there are closed and open varieties - the open ones you'll normally see on forestays of the 18th century (perhaps beyond and probably prior, as well). The ones on America are closed -- they should be seized into the shrouds with the grooved side facing away from the line. They are rigged using lanyards - I usually tie the lanyard to one of the hearts using a simple overhand knot and then you just wrap the line between the two hearts....I'll get a picture up soon I promise.... Yes I quit on Dec. 6, 2006. I had been a committed smoker for about 10 years at that point and an occasional one for the 6 or 7 years prior to that. It was pretty tough, but definitely the best decision - I still indulge very occasionally - usually while travelling, which I do frequently and mostly alone. It's relaxing to sit at a cafe somewhere and have a cigarette with few worries or commitments. I'm heading to Spain this Saturday and will undoubtedly have a few cigarettes over the ten days I'm there if the humidity goes below 65%....otherwise it's just gross..... hamilton
  10. Hi Tim: Thanks for the tip.....I'm a little short on cigarette lighters (quit many years ago) but I'll have a try of this method....I'll see if I can get a decent picture later today and post it for you....bye for now hamilton
  11. As promised, a very small update - have not taken many photos of recent progress, though at this point I've constructed the foremast, mainmast and maintopmast and stepped and completed standing rigging on the fore mast. I have served the lower portion of the shrouds with white sewing thread (following Tim's build), but it has become really fuzzy....I was thinking I would paint on some diluted PVA glue to calm the frizzies down....but I'm open to suggestions.... Anyway, here's all I've got! Quick snap of the foremast head as a teaser....more later hamilton
  12. Hi Tim: Yes you're right - not the kit-supplied thread, which I don't plan on using. I have a stash of thread of various gauges left over from other builds (mostly the model expo thread) and also some Syren thread that I bought in bulk a while ago. I've tried to go as light as possible with the gauge, but I was having a lot of trouble with the 1/8" syren double blocks - mostly because I needed to widen the holes and I don't have a collet for my pin vice that will hold smaller bitts....So I ended up going with 4mm blocks all around for the bobstay tackles (though not for the martingale backropes...) Anyways.... I understand your decision to avoid sails....they are very tricky. I haven't done sails in a while but I will try on this one....we'll see how they come out. Not a huge amount of time for modelling these days (or for the next few weeks - the admiral's down in NYC for the week and then I'm off to Barcelona the week after that, then my classes start the day after I return so it's a very busy time.....Some small update on America later tonight or tomorrow no doubt.... hamilton
  13. Ahhh ratlines! Thankfully my current build doesn't have them.....listening to whatever music soothes you is as good a prescription for creeping ratlinitis as I can think of..... hamilton
  14. Thanks a lot Frank! This is exactly what I've been looking for!! Much appreciated! hamilton
  15. Beautiful work - thanks for showing your technique on the mast woldings - I'll definitely borrow this technique for future builds! hamilton
  16. Beautiful craftsmanship as always, Bob! Thanks also for listing the paints you use! The wood-toned one seems pretty authentic, considering it's paint! Very nice work! hamilton
  17. Just catching up here - the shrouds look really well done - great work hamilton
  18. Hi Peter: I almost bought the dremel moto saw, but the one thing that held me back was that to do angle cuts you had to hold it like a coping saw.....I preferred to have something with a tilting table for angle cuts.....the band saw works well, though I have nt had extensive use of it - seems to cut curves nicely, though the 1/4" wide blade does not do tight curves, which is why I'm trying to find a thinner blade - 1/8", which I heard was available, but have never actually seen.... At some point, this will turn into an actual build log, I promise! hamilton
  19. The bowsprit rigging was quite straightforward - though getting the dolphin striker to stay in a 90 degree position from the bowsprit was tricky. Here are some photos -- until next time! hamilton
  20. OK - time for another update. I've completed the bowsprit and jibboom as well as the standing rigging on both. I'll split this update into two posts....first, the bowsprit. The bowsprit is made from a 5mm x 5mm strip of square stock. The first step was to mark off the transition between the inboard (square/white) and outboard (rounded/black) sections. I decided to add a bit of chamfering to the inboard square section, as you'll see here. A tenon was created on the inboard end to fit into the bitts.... The bowsprit tapers to 3mm at the outboard end, so using my compass set to 1mm, I marked out the outboard end - the idea being to taper each of the square faces and then round the tapered strip. Here are the results I then drilled out holes for the inboard cleats and threw a few coats of while and black paint on..... Two irons are fit at the end of the bowsprit - one a simple iron ring that takes the standing ends of some of the rigging and the other a gammoning iron for the jibboom which also carries some lines. These fit on relatively well and their completion was not particularly exciting....you'll notice the martingale attached here - it did consist of two rings, but one of them snapped off and I had to improvise a bit.....the jibboom is here just a dowel cut to length.... Continued in next post...... hamilton
  21. Haha! That's an argument for keeping them where they are, I suppose......despite the oddity.... hamilton
  22. Hi Per: I'm not sure if you're offering to pick this up for me? If so, thank you, but I have to decline! I don't really have any room for it, though it would be a nice addition to the collection..... Tim - thanks for dropping by! Yes, this one is currently still in development - I was hoping to commence this month, but it doesn't look like I will....America will have to be finished first.....and even then, I'm heading into another academic year and my modelling progress will slow altogether....I plan on teasing out the Bluenose in tandem with other kit builds.....Syren is next up on the docket, though I may take September to focus more on Bluenose and dive into Syren later in the Fall.....much depends on feeling out what kind of year it's going to be - the last two have been really nutty, and though I'm hoping this one's calm, it's already shaping up to be very busy........ bye for now hamilton
  23. Thanks for the tips Peter - Dremel doesn't seem to make their scroll saw any longer - they just have a hand held "moto saw", which has a clamp so it can work as a stationary table-top device. I haven't seen any dremel scroll saws on sale at any of the usual online places.....I'm going to try to source some thin band saw blades, but so far have been absorbed in finishing my Mamoli America and, of course, other commitments! I hope to get the keel and bulkheads cut before it gets too rainy up here........thanks again for the comments! hamilton
