hamilton
Everything posted by hamilton
  1. Hi Jack: I built the BN at this scale about a year and a half ago and I ended up leaving the dorys off - I found them far too frustrating to complete! It's actually really nice to see them here - they really do add a lot of authenticity to the model. Great work! hamilton
  2. Just read through your log - excellent work - I especially admire the sweeps - really impressive! hamilton
  3. Excellent attention to detail here. Looking great hamilton
  4. Hi Max: I love the commitment to detail you're bringing to this build. Really nice work. My Phantom is currently in a dilapidated state in my son's room, but your build is adding some motivation to strip the thing and re-do it. Thanks for sharing hamilton
  5. Hi John I've never seen a build log for this one before - very interesting ship and a nice build! hamilton
  6. Of course Ferit - though we're very far apart geographically! I'll give a hint - I'll be using a kind of lino-cut technique using card stock. Depending on how sharp I can keep the knife, it might actually work, though I have to scale down the source material from 1:64 to 1:100 - the success will really depend on whether the patterns I'm using remain workable once they're scaled to 1:100.....Stay tuned.... hamilton
  7. Thanks Augie, Ferit, Alistair & Andy! Much appreciated as usual - and thanks again Alistair for sending on the Fly files....I'm hoping to scale them this week and have another go at the decorations... hamilton
  8. Thanks Andy and Mark - so I have not yet given up on the bulwark decorations, but I have put them on pause for a bit...To pass the time while turning my mind around my latest approach to that problem, I've decided to make the rudder and the cannons - it's fortunate that with projects like this there's always something else to do while you're figuring other stuff out! I made the rudder three times. The first was out of 4mm x 4mm beach that I had left over from another build. This didn't work out - I messed up carving out the slots for the pintles and gudgeons. The second was from 3mm x 3mm lime, planked with .5mm lime. This didn't work because the shape was off. The last one was from the same material as number two, but I used a template to get the correct shape and it worked out quite well. Finished in white, Golden Oak and Red. For the Pintles and Gudgeons, I abandoned the metal parts supplied in the kit and used 1/16 x 1/64" brass strip, blackened. I had thought of installing bolts, but at this scale and with only a pin vice to work with I decided against it. I did add ring bolts for the rudder chains. No photos of the cannons yet - I'll save that for another post later....In the meantime, here's the rudder....Bye for now - hope you're all enjoying the weekend. hamilton
  9. Hi Augie - any day now, eh? Can't wait to see her cross the finish line! Also very interested in seeing your (future) Essex! hamilton
  10. Hi Brian: I wish I'd seen your sheave block making technique a couple of weeks ago when I was doing this exact same thing on the Blandford!! Your approach (regardless of the questions over scale) is much better than mine (which was simply to drill a couple of holes into a 3mm x 4mm bit of scrap wood.... anyway - these will look great when installed hamilton
  11. Excellent work, Ferit - the alignment of your shrouds is perfect - did you use a jig or just eyeball them? Whatever the approach, the result is fantastic. Also - on the right hand side of the first photo there's a small single block on a pendant on the aft side of the channel - what line is this for? Just curious! Thanks for sharing these great photos! hamilton
  12. Wow - all this support has nearly brought me to tears!! I can't say how much I appreciate all the encouragement and helpful suggestions from all of you Thank you so much!!! J - this is a great idea for a newbie such as myself - I'm not sure I would use Chuck's screens for the pinnace, but I will use this idea I think Augie - I've used sculpy before for some very simple decorative scrollwork on the Sultana (another Chuck Passaro practicum suggestion). I think I'll follow Ferit's link above and check out Doris' work Ferit - I can't thank you enough for your kind words! You've convinced me not to just give up - and you're absolutely right - if we're unwilling to give our time to improving our talents through this process and to making our work as nice as possible (within our own "reasonable" standards) then what's the point! I've already made the ship's rudder twice out of dissatisfaction with my results and will make it a third time tonight! So why not take a stab at this other thing? Thanks for passing on such inspiration! In any case - an opportunity has presented itself that may result in some nice bulwark decorations...may take a bit of time, but it will work much better and be closer to historical than my initial (misguided and bizarre) idea of the brass tree frames! Thanks once again to all - what a great group is to be found here! hamilton
  13. Hi Ferit: There is some indication in Goodwin's Anatomy of the Ship Blandford - scroll and leaf patterns. The book actually presents the Blandford in a slightly larger scale (1:96) than the Corel model, but either way it is very small detail work. In any case, I know I'm not ready for it, so I'm going to leave it blank....sad as it is. hamilton
  14. Isn't that always the way with construction! A pain - but hopefully the results will be worth it! hamilton
  15. Nice work, Andy, even if this one doesn't do the job - as BE says - trial and error (with me it seems mostly trial...) Maybe you can mail that collar out to me in Vancouver - I might be able to use it on the Blandford....though the heart would be way out of scale.....enjoy getting out of the big smoke - we're not as hot as you out here, but I still can't wait to get out to the Islands end of next week! More relief from yard work than from heat.... hamilton
  16. Hi Mobbsie: Great bulkhead finishing! Nice contrasts and it really brings that area of the model to life. Love to see this beautiful ship coming together! hamilton
  17. Of course you're right - not to mention, the "stately elm" - neither of which will figure on the Blandford..... hamilton
  18. Hi Andy: It's these kinds of jobs that will probably permanently bar me from scratch building - carving and decorative finishing....I say "not my strengths", but I really should say that I don't even know where to start....anyway...at some point I'll have to just sit down with a knife and a stick and start practicing.... hamilton
  19. Weren't hedges ever in fashion as ship's decorations? Just dolphins and unicorns and cherubs and stags I guess...What about the mighty hedge!!! hamilton
  20. Well I guess the word is in....I agree....I was looking at the dry-fit piece again this morning and realising that I was really just "improvising" in a situation where it isn't appropriate. Thanks all for the intervention!! hamilton
  21. Another brief update - not much modelling done recently, but I have managed to finish the forward hatches and the build the 3 ladders running from the main to the lower deck. Here are a couple of pics.... On another note, I mentioned in an earlier post that I purchase some brass bare tree frames from a local model train store that I thought I might use for the decorative elements along the bulwarks forward & aft and on the transom. Here is a shot of the item I bought. And here is a bit of it dry fit onto the bulwarks aft.... Be honest with me, people - I know this is not really historically accurate and I'm willing to live with that - but beyond that, do you think it works? It will be very painstaking and tedious to apply this stuff, and I would rather have something on the bulwarks than leave them bare - I don't think it will look awful, but I'm just not sure it's worth it to go through with it....Unfortunately I have no real back-up plan and if these don't go on, I'll simply leave the bulwarks undecorated......your thoughts will be much appreciated...thanks as always! hamilton
  22. Thanks for the comments all! Very much appreciated....Ian - unfortunately I'm allergic to cats!! And as for more - the sun has finally come out in the Pacific Northwest (a rare enough event) so I've been spending a lot of time getting some much needed yard work done. In the evenings I have barely enough energy left to lift a mug to my lips let alone fiddle around at 1:100 scale....but more progress should come soon... In any case - thanks all for your thoughts! Despite the limitations of this kit, adapting it to the Blandford has been a real adventure so far....my first real kit bash, and a lot of fun. I think the next one's going to be something very simple and straightforward.....HA!! hamilton
  23. That rudder looks magnificent - a beautiful tone and finish all around - that jig works wonders on the pintles/gudgeons! hamilton
  24. Hi Ferit: I feel like I've been starved for pictures of your beautiful Berlin! And now I see you're on to the rigging! It's looking good close up but I'd love to catch a glimpse of the whole thing....but maybe you're saving that for later..... hamilton
  25. Congratulations on the twins! I feel like we have our hands full with just one! And this work is exquisite! Such a pleasure to look at! Looking forward to more hamilton
