Posts posted by Edwardkenway
B and Q do a clear pine board, 1.2m x 400mm x 18mm for around £30.
2.4m is £50
Is the tug wider than 400mm? Other than that most builders merchants have a timber section.
Would not a good sheet of marine ply be suitable? A 2.4 x 1.2 x 9, 12 or 18 mm would be around £30-50 respectively.
Just chiming in here😉
Looks absolutely wonderful Fred, and yes between you and Glenn, I'm very sorely tempted to do a Cheerful. Maybe a year or two down the line it may come to fruition.
Winnie is keeping my hands full at the moment.
After seeing what great work you've done with Cheerful, I think you'd certainly make a Winnie to be proud of.
Keith, welcome to MSW
- mtaylor and Keith Black
- 2
, welcome to MSW
- Ryland Craze, mtaylor and Keith Black
- 3
2 hours ago, Landlubber Mike said:
Good thing I'm not going to be buying any more kits so that should no longer be an issue...famous last words 🤥
Resistance and futile come to mind🤔
26 minutes ago, Egilman said:... and get us to believe it....
We all know....😁
- CDW, Jack12477, Landlubber Mike and 6 others
- 9
Cheers Dave E.
Not wanting to put it off any longer, I sat down with some brass strip and a flat file. The following results may not be perfect, but for a first attempt, well..... blackened makes them look a tad better
Need to make some small eyebolts and split rings now.
New skills being learnt, as I would have gone off the peg and purchased them before this build.
To everyone looking in, commenting and giving the thumbs up, many thanks.
Cheers
- FrankWouts, Steve20, Rustyj and 17 others
- 20
Denis, welcome to MSW.
Do please set up a build log when you start your steam launch.
- Dave_E, Keith Black, mtaylor and 2 others
- 5
Just a small update, I've dry fitted a couple of ring bolts
Just to see what they look like on the deck
I've used brass wire at .5mm, which according to the conversion chart is equivalent to 24 gauge, and blackened
If I'm honest, I'm doing these, just so I can put off making the port lid hinges. I'm not sure how or where to start with those, even though I've read and reread the hinge bit in the monograph 🤷😬😕.
Any pointers be will be gratefully received.
Thanks once more for your comments, likes and visiting.
Cheers
- Rustyj, FrankWouts, CiscoH and 8 others
- 11
Looks great! Very nice planking Indeed.
Another Winnie to aspire to.
57 minutes ago, scrubbyj427 said:
Next time I build gun ports I decided that I will do them during the planking process and use the same planks as I'm using on the hull so they match better.
I know what you mean. I saved all the offcuts from the hull planking, even the very short ones, now I'm glad I did not throw them out.
I'm definitely having the ports open as a couple of them are very oddly shaped🤔
- Dave_E, Jack12477 and FrankWouts
- 3
With the deck done and finally just going with something approaching a quadrant profile for the waterways, I've moved on to the rudder.
I had a mishap with topmost bracket on the sternpost, as in breaking it getting it from the fret🙄.
With the hole in the counter drilled, I fitted the cabin benches.
Also a start be was made on the gun port lids. Inbetween all this I'm also making up some eyebolts and split rings. I tried Glenn's (glbarlow) method for the eyebolts, not a great success for me, I could not make them consistent, so I went back to the twist method.
Thanks for all the comments, likes and dropping by. All is greatly appreciated.
Cheers
- glbarlow, Steve20, FrankWouts and 12 others
- 15
I'm with EG, the lighter one, I think the darker grey is too dark for a sea grey.
- Old Collingwood, Egilman, mtaylor and 3 others
- 6
Thank you very much for this very timely post! I'm just starting to make some the many eyebolts and split rings.
- glbarlow, Dave_E and FrankWouts
- 3
Michael, welcome to MSW
- Keith Black, JeffT, Dave_E and 3 others
- 6
and welcome to MSW
- Keith Black and Ryland Craze
- 2
and welcome to MSW
- Keith Black, mtaylor and Dave_E
- 3
Your finish looks very nice Gary.
and welcome to MSW.
It would be nice to see what you do with the model.
- mtaylor, VitusBering, Keith Black and 1 other
- 4
Ralph, welcome to MSW
Your Bellona model looks great!!
- Keith Black, JeffT and mtaylor
- 3
Blackburn Buccaneer S.2C by CDW & AJohnson - FINISHED - Airfix - 1:48
in Non-ship/categorised builds
Hearty congratulations!!!, nicely done against what appears to be stiff competition.
