Everything posted by cog
Nulli Cedo by peveka - A Dutch War Clog
cog replied to peveka's topic in - Build logs for subjects built 1901 - Present Day
Maybe get some sneakers, your mind is running 'round like crazy! -
Or do you prefer it in Delft blue, if it's a boy? -
HMCSS Victoria 1855 by BANYAN - 1:72
cog replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Well done Pat- 1,013 replies
- gun dispatch vessel
- victoria
If you use a rod to bend it around this requires far less accurate bending in the beginning. The importance is to have a rod slightly undersized, so you can get the ends meet flat-ish- 1,013 replies
- victoria
If this is pre-planning ... I'll take up hibernating for prolongued periods
- 599 replies
- sidewheeler
- arabia
(and 4 more)
so it seems ... are you goin' to throw with your clog now? -
darn, gave you the wrong instructions ... should have given the one that let you around in circles ... -
at the top of the page press the down arrow besides your avatar. Select 'account settings" which opens a new page, select "signature" In the text input box type "Current build" with the link tool you can add a link. save the signature. Go to the first page of the build log which is your current build.. Copy the text in the address bar. Go back to edit your signature. Use the link symbol (chain in the menu bar) past your address into the upper textfield, and put the name in the lower. That should get you what you want -
Yes, I can. -
Pat, Bend the strap around a round bar, oval would be even better. use a piece of metal wire to align the first holes (the ones at both ends) and start pressing it flat together. Starting with a rod, gives you some flexibility in "folding". If you use an undersized rod, the ends will meet and can be flattened already, by using a handtool. Using a small nail or wire makes it possible to align the first hole and press on.- 1,013 replies
- victoria
And I have more problems the smaller it gets ... Moving along nicely Mark. One advantage of BIG tweezers ... you can squeze Sam when he is nagging you
Een dubbeltje op z'n kant (narrow escape - a dime on it's side) Hope those aren't milk teeth, and those work -
I'm afaraid the strech line like EZ line will pose the same problems you have with the other rigging. I would personally go for the streched sprue, eventhough it is more work, you won't have the tensioning prblems. On my plastic builds I use EZ-line, but my masts are from brass, so I don't need to take the flexibility from those into account
- 90 replies
- bomb ketch
- pyro
Do you use masking tape or e.g. carboard to get the sharp line for the oilcanning effect? Shouldn't you have the light side from the effect at the bottom of the hollow and the dark side at the top. I know I am a pain right know. It looks like the light comes from right under. It looks very real, as if you can touch the hollow
maybe we should tip-toe on and not disturb the master, so his vains do not clog up from the stress we cause Fortunately those will be de-clogged within 350 years -
I see you have taken off in your German sieben miles Boot. -
it may even take a reboot to clear ones thoughts -
Very nice result on that scale. Your pumps turned out very well
- 4,152 replies
- cutty sark
- tehnodidakta
