cog
Everything posted by cog
  1. The triangles you use for strengthning ... could those be a tad to long down the inside wall ... If you bent the railing round the nail, you have had the stanchion crooked before bending. On the Smit Nederland and Rotterdam I only fixed the first few stanchions, then mount it, so you get the bend at the right spot, and can still move the stanchions around. If you want to paint it before you do the final mounting, you kan fix the stanchions with a drop of CA and take the railing of for painting
  2. Ok thanks. It's quite dark on the funnel, mebby add some light grey ...?
  3. Jack, whilst you still can get to it easily, why don't you cut those top masts of and replacce them with a brass rod as you stated. Drill a hole on the spot where you uct it off and CA the rod in. Will be a lot nicer ... you're doing great mate If Sunny needs some help to boss those rafter dwellers around I'll send "the Bitch" as reinforcement
  4. Did you spray paint the "linoleum" decks or use a brush? It starts to look like a (well used) ship instead of a hull ...
  5. Didn't help much I reccon ... She won't skin him, than he will be useless to her ... Coventry is much better ... she could also send him to the Netherlands ... on foot
  6. Linseed oil I presume? It does give her a very pleasing colour, Kortes
  7. Glenn, Thanks for explaining. Got a question, since we're at it. This is for a single led, what happens to an array of leds? Just multiply the voltage by the number of leds?
  8. You could just change the resistor, but I wonder if that is the wisest way. You might take a look here: https://www.instructables.com/id/Choosing-The-Resistor-To-Use-With-LEDs/
  9. You might have as much fun as I with the WWII Tribals ... Peter Hall has some very nice PE. Got the stanchions from him too (steel). Maybe I should have looked for barrels , but at the size for these destroyers, I wonder if you can really see the difference. Nice kit, nice gesture, al the more reason to keep at the Pearl. You may find some details lacking, but you'll probably still have some PE leftovers you can jugle with to add those
  10. Took you a while to get those men in the bottle - should have been two ginies, a lot easier And again a wonderful built Igor
  11. Stunning, Igor. still cannot comprehend how you got the mast and sails fitted
  12. Wonderful build, Reci. The hull is still my favourite, vraiment magnefique
  13. I knew it, you were out of wood!!! Now Gwen's mapple needs to pay for it.
  14. Kortes, Some of the leeboards (singular: zwaard, plural: zwaarden) have a hook attached to the metal rim like this
  15. impressive view, seeing her with bared teeth ... I can imagine the disapointment with the brackets. I think I wouldn't have gone for the PE version anyway, although you were forced into that decision. Especially at the spots where the bend must be made it is often very weak. Again marvelous work ... you are getting in the habbit of delivering but that
  16. Thanks Piet. Nice to see you have some spare time left, and visit us poor bunglers Hope you do get back to one of your buildlogs soon
  17. So I can send you to take photographs :) Why spoil everything ...
