Everything posted by Mahuna
I'm trying to print from TurboCad to a Brother MFC-5890CN, which prints on 11x17 paper. I've run into a problem where printing at 1:1 actually prints slightly larger. A test I ran with TurboCad attempted to print a straight line exactly 12 inches long. The printout actually measured at slightly under 12.25 inches. To determine if the problem was in the printer or the software I printed a 12 inch line from Excel, and the printed output measured exactly 12 inches. I'm relatively new to TurboCad, but I think I've learned enough to start producing some CAD drawings for my next build. However, until I solve this print issue I can't reach that stage. Can anyone suggest ways to get my printed output to measure accurately? Thanks!
Hi Mark As a fellow Arizonan (Sun Lakes) I'll be watching your build. I'm fortunate that my shop has A/C, but I understand your heat issue.
- 71 replies
- cutty sark
- mantua
ancre Le Fleuron 1729 by rekon54 - 1:24
Mahuna replied to rekon54's topic in - Build logs for subjects built 1501 - 1750
A friend of mine recommended today that I look at your log. After looking through only a few of the recent pages I'm absolutely in awe of your build. I plan to spend a lot of time catching up from the beginning - I think I'm going to learn a lot by doing so. -
With the deck on, she's looking superb. I can't believe the detail you're able to get. Great job.
Hi Ron I've stopped using dowels for the same reasons you've had trouble finding any that you like. I now make my spars from square pieces of stock, even the very small upper yards on the Mayflower I'm working on. Shaping can be done with a chisel, rotary tool, a file, or even a sanding stick. The key is having a way to make the octagonal shape using the 7-10-7 rule. The attached PDF is an image that can be used to find the correct marks (using a tic strip). 7-10-7 Sheet.pdf Also attached is a link to a very nice article on the subject from the MSW database. http://modelshipworldforum.com/resources/Mats_and_Yards/Mast-making.pdf
Jay - Here's the Sherline instruction sheet for the Sensitive Drilling Attachment. Sensitive Drilling Attachment.pdf The only real drawback to it is the need to mount it for drilling, but that's not a big deal. To me it's the best way to use the very small drills for machine drilling, and it works great with the carbide drills.
I actually use my mill a lot. For fine drilling I use the Sensitive Drilling Attachment, and for regular drilling I use the z-axis hand wheel. I stopped using my mini drill press, so I sold it. I recently used my Rotary Table and the Tilting Angle table to produce the mast tops for my Paragon (modified Mayflower). I still consider myself a novice, since there is so much more to learn.
Hi Brian, Patrick, and Bob Thanks for the kind wishes. I’m going to keep trying whatever alternatives there are until we get this resolved, or at least under control. I’m enjoying life too much and am not ready for things to change yet. Brian – the meeting this Saturday will still be OK. I have some things ready for you, and have a couple of interesting new tools to share.
Hi Everyone: Just a little update. I had the shot a week ago, but unfortunately it hasn't worked so I haven't been able to continue the ratline work on Paragon. I have a follow-up consultation with the doctor at the end of the week so we can determine next steps. In the meantime I've been doing a lot of research and prep for my next build, so I'm trying to not waste a lot of time. Thanks again for all of the good wishes.
I'm along for the ride - looks like an interesting project.
- 59 replies
- norske lowe
- billing boats
Ed - I continue to learn new techniques from you - thanks! The idea of holding the scraper for the rabbet in a vise rather than the other way around seems like common sense, but I think I would have struggled for a long time before coming up with it myself, if ever!
- 191 replies
- young america
- clipper
Nicely done Brian. One question, though: I thought you had the Domanoff serving machine - am I misremembering, or was there a reason you decided to use Chuck's version?
- 831 replies
- Armed Virginia Sloop
- Model Shipways
The guns look great (and very uniform). Worth any struggles you faced, and a great learning experience for you.
- 831 replies
- Model Shipways
Domanoff serving machine 2.0 or 2.5
Mahuna replied to CPT_D's topic in Modeling tools and Workshop Equipment
I have the Domanoff Prozak and am very happy with the workmanship and the functioning. The limitation is how high can you hang it. I'm able to make 6' strands and that has worked out OK for me. I've also seen the Domanoff serving machine and it's a quality piece of equipment. I think you'll be happy with what you get. -
REEFS - good advice. Another alternative is to spray some alcohol on the wood. This raises the fibers and evaporates fairly quickly (and doesn't have the odor of acetone).
- 831 replies
- Model Shipways
Bilge Pumps 1870/80
Mahuna replied to GAW's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
Hi Gerald - I'm very impressed with your work - thanks for the link to your page. However, I tried the 'Current Project' icon, and it's only an image file, not a link. -
Thanks Bob. The shot itself was OK (I haven't had any bad experiences with them - this was my fourth). Unfortunately no benefits yet on the bad leg - the other leg was initially where the pain was, but that cleared up after the second shot. Not so on the current problem. We'll just wait and see. Thanks for the concern.
I've learned to use a glue stick (like the kids use in school) to temporarily attach drawings - faster and much less mess, and hardly any drying time.
Thanks Ed. I've learned a lot by watching your beautiful builds. Your comments mean a lot to me.
Hi Ron: I think if you wet the glued-on paper pretty well and let it sit for a little while you could probably scrape the paper off using the side of a razor blade, rather than sanding it off. Less risk to the piece you just made.
Very well thought out. An engineering marvel!
- 831 replies
- Model Shipways
Hi Mark Thanks, and please give your wife my best wishes for dealing with it. I go in for an epidural tomorrow and hope that will bring some relief.
