Everything posted by WalrusGuy
I'm so sorry to hear that, Bruce. Taking a break will help. I'm very far off the head rail chapter but I know that's a very tricky part of the build. I struggled with that for the Syren build. Enjoy your time with the Cobra!
- 126 replies
- Finished
- confederacy
Thank you for your kind words, David! I read some of the logs here and found there were some issues with the plans, some of which were pointed out in @flyer's build log. For example, I saw that he modified the bow and stern areas. I don't plan on going for something fully accurate since I could not find plans of the Pickle on RMG website. Instead, I have opted for more freedom in the build process and will be following some of the build logs here and the practicum for Chuck's Cheerful build. Just hoping it goes nice and smooth 😅 I also want to carefully single plank the hull as it will be nice practice for the future. And from going through the plans I realized some of the rigging is simplified for a kit. So I'll study some rigging guidelines for schooners and will follow that instead. Hi Peter, I read through your log when I was researching on this ship and was deciding if I wanted to follow your footsteps. But I did not feel very confident in making the big changes as I may get stuck in the process. I'll still be following your log for your nice ideas. Your ship with the sails looks amazing btw! 🙂
Wow!! Thanks Chuck! I had no idea there is a section for only contemporary models here on MSW. I'll spend a bit of time looking through all of them. Unfortunately there are no naval museums where I live, but I will be sure to add some pictures if I visit one sometime.
- 1,784 replies
- winchelsea
- Syren Ship Model Company
If I may ask, where do you get all these photos? I looked at some models in the RMG site but the photos were not as good as the ones you posted here. Or did you take these photos yourself?
- 1,784 replies
- winchelsea
Lots of progress since my last post! I glued in all the bulkheads and finished framing all the gun ports and uprights. I had to modify some of the kit's parts for me to accommodate the framing (incl. the stern and bow areas as shown here): For the stern gun port uprights, I used some scrap wood and glued to the bottom piece: I forgot to take a picture of them glued (since I messed up their placement a few times and had to unglue), but here is where they are installed: Next, I used a batten to locate the gun port sills: Then, the sills were glued in and the upright locations were marked. This was done by transferring the locations from the laser cut sheet onto a paper then to the hull: Then, I glued in the uprights. Scrap pieces of wood were glued on the sides of the upright to provide some more support. Not the prettiest thing but it works 😉 Next I will begin decking the lower deck and paint the gun ports
Thank you for the nice comments! And I don't mind at all 😁 Yes I'm using bamboo, but I've seen that some brands of bamboo skewers don't have a nice finish (they have more of dots or speckles when sanded smooth). You can see this in Mike's post here: From his post he also drew boxwood till the 2nd hole on the drawplate. So I tried a couple brands of bamboo skewers before settling on the no name brand from SuperStore I go all the way through to the second smallest hole on the drawplate. This is the only size that fits nice with the smallest drill bit I have (0.3 mm). The smallest one is too loose and the 3rd smallest is too tight.
The treenails look really good and neat. Looking forward to more progress pics 😀
- 322 replies
- enterprise
- caf
I finished treenailing (using drawn bamboo through a drawplate) and gluing the keel/stem onto the bulkhead former. Before gluing these in, I prebent and glued a strip of pine on the former as this will help in tucking in the planking onto the stem. I also created a small rabbet onto the stem to serve the same purpose. I then applied tung oil onto the keel and stem. I may try using wipe-on poly for the planking and decking for a bit of contrast, but let's see how it goes as I progress through with the build. So far I am liking how the wood looks with the oil. Here are some pics showing this: And here are some pictures with the bulkheads dry-fitted: I'll next start gluing in the bulkheads, begin decking the lower deck area, then will start framing the gun ports
Wow!!!! The planking looks amazing! Your work is really inspiring. I may also hire you to plank my Confederacy 😁
- 345 replies
- Duchess Of Kingston
- Vanguard Models
