Mirabell61
Everything posted by Mirabell61
  1. Valeriy, wonderful brass metal work, and joining into the hull, it looks top !! Nils
  2. hi Ian, thats a beautiful build and a beautiful picture illustration too. Very well done !! Love those sights to the landscape surroundings, your comments and the seasons as they come and go, even wild life in the garden..... Wish you all the best with the further rigging Nils
  3. Hi Danny, your Yamaha bike looks wonderful, its amazing what you can do with card !!! Nils
  4. Good to hear Michael..... wish you interessant and pleasant lecture of that book when it arrives.. Nils
  5. A lovely built ship Alex, looks mighty fine with those taned sails..., and super stuctured deck housings Nils
  6. Michael, yes, it is a "spinnaker pole" (may have had a different nomination in those days) for a mighty size triangle sail, that is rigged, and standing out about 90° to the ships axis Nils
  7. Hi Michael, many thanks for looking in again..... I`m pleased you like the method for bringing on the bolt ropes. When I did it first I was searching for a way to sew the bolt rope to the sail edge per sewing machine because I just could`nt do it with a steady and evan hand stitch. And yes, the British cutter "Genesta" and its build is still one of my favorites as I fell in love with those beautiful lines, and she`s a "must" to start a build with one day..... Best regards Nils Pic of this lovely model, built by Jürgen Willing, is borrowed from the web
  8. further on with the Chebec`s glass case making.... the slotted rods unfortunately come only in 900mm lengths, due to the required length of the base and the glass panes, the rods will have to be shafted. I chose a brass reinforcement profile in order to strengthen the shafted joints. The complete glass bonnet and its frame will be guided and centered in 6 places for removal..... (at four corners and one on each length side) Nils this is my little model, which I take to the glasser, when ordering the panes, together with a scetch comprising the dimensions, pointing out why the dimensions and tolerances are important to hold corner / side guide sleeves and pins to centre the removeable bonnet later on shafting the bottom length sides at 25° angle, with brass reinforcement profiles (assemly with CA) the reinforcement will hardly be visible afterwards the frame will be flush with the upper outside base contour
  9. Many thanks 2Millimetra, I am pleased you liked the pictures..... Nils
  10. Beautiful propellor / rudder assembly valeriy, Nils
  11. Valeriy, nice jig-arrangement for propshaft alignment. I looks like the two mounting screws through the propshaft housings will disable the shafts from turning.... is that wanted this way ? Nils
  12. Hi Patrick, with all those cool curves she`s coming along very nicely, hope you never loose the orientation with all those lines.....😉 Nils
  13. Valeriy, many thanks for your kind compliment, it is much appreciated, and I`m pleased you liked the "Pamir" build log.... Nils
  14. Top work Valeriy, the making of hull and props is masterly done, she´s going to be a beauty..... What other models did you do before this one,....any pics available ? Best regards, Nils
  15. Doris, breathtaking artwork, your beautiful ornamentation is wunderbar !! Nils
  16. Thanks for looking in Martin, cutting the 45° angles of that molding works well, if the piece is pressed and held firmly in the corner of the miter guide surfaces Nils
  17. Today I started building the Chebecs casing.... it will be a bit larger than usual (width) due to the sticking out oars on stb. side, and the ships boat on the port side. The display place will be swapped with that of the Gorch fock, momentarily in my hobby room, which I will place upstairs instead. I have foreseen an old cast iron foot base of a former heritage sewing machine for Gorch Fock`s new stand-on support...., will have to exchange the glass plate against a sturdy wooden base for safety reasons... Nils cutting the edge pieces of the baseplate only little (minimum) clearance to the stb. glass side. Will apply cherry wood stain afterwards, like my other casings have and to the port oar of the boat This will be the new stand support for the "Gorch Fock" model`s glasscase. Need to exchange the glass plate against a 1200 mm long wooden plate in adequate thickness
  18. Wow !! super stuff Danny... Nils
  19. Hi Thormin, many thanks for that excellent link to those ships pictures..... Nils
  20. Wunderbarer job Michael ! Congrats, its been a delight to follow that restoration, and I`m sure your client will be more than pleased with the result.... Nils
