marsalv
Posts posted by marsalv
Very nice work. Proxxon milling maschine is irreplaceable working tool.
- WackoWolf, Dubz, shipcarpenter and 6 others
- 9
Hi Alex,
wonderfull . Your log is great inspiration fo my work.
- maggsl_01, Mirabell61, NMBROOK and 7 others
- 10
Hallo Alex,
thank you for compliment. As you can see I was very inspired by your Sphynx log .
- harvey1847, giampieroricci, Archi and 27 others
- 30
Hi Michael,
I will try to answer your qustions (sorry for my bad english).
Proxxon drilling maschine has 3 spindle speeds and I use the medium speed. Each treenail is made only with one down/up movement of cutting needle. Sequence is following - down with needle, up with needle, movement wit XY table and again. It´s pretty fast. You must only watch, if you can see treenail in the wood block after drilling. If you see no treenail (black hole), needle is propably blocked with wood and you must clean it. It is also the answer to your third question - treenails MUST stay in wood block. After drilling cover the face side with holes with adhesive tape, carefully cut off the opposite side and then push and remove the treenails from the block. It is easy .
Thank you all for nice comments .
I used usual hypodermic needle with diameter 0,8 mm (21G). Needle is carefully ground to the tip - see pictures. As wood is used pear, a necessary condition is that the wood fibers would be parallel to the needle. Is it possible to make treenails with diameter 0,45 mm (needle 0,7 mm 22G). You can see the comparison between 0,55 and 0,45 treenails in the last picture.
- Duanelaker, NMBROOK, daHeld and 20 others
- 23
- fnkershner, tadheus, druxey and 10 others
- 13
- Captain Poison, PeteB, sparrow and 23 others
- 26
- SawdustDave, Archi, fnkershner and 17 others
- 20
- fnkershner, daHeld, Dimitris71 and 22 others
- 25
- AnobiumPunctatum, wyz, Dimitris71 and 25 others
- 28
- Archi, Wishmaster, NMBROOK and 14 others
- 17
- Gabek, PeteB, Elmer Cornish and 22 others
- 25
Royal Caroline by marsalv - FINISHED - Panart
All the ends are secured with diluted PVA glue to the stay. It is very important that the "skeleton" from thread must contain an odd number. Then just drag out another thread throughout the "skeleton", alternately one under, one above thread. It is little difficult and time-consuming work.
The stays (and their accessories) is ready and installed on the model.
