marsalv
Posts posted by marsalv
- giampieroricci, albert, Ponto and 21 others
- 24
- Mahuna, allanyed, Bluto 1790 and 15 others
- 18
- garyshipwright, rtropp, tlevine and 20 others
- 23
Thank you guys for comments, but you are not right now.
I'm not satisfied with the already finished parts (lower and upper cheeks), and so I decided to make them again. It's hard for me to explain it with my bad english, but used wood has a distinctive structure across the fiber and on the manufactured parts is this structure too visible. I had to choose another orientation of parts on wood.
A few minor details is completed - wash cant, gammonig chock, bolster nad lining in the hawse holes.
- Captain Poison, mtaylor, albert and 16 others
- 19
- Mahuna, Mike Y, Bluto 1790 and 17 others
- 20
- paulsutcliffe, albert, zoly99sask and 12 others
- 15
Thanks to all for very nice comments.
To RedDawg - blackening solution is desribed in post #206, with regard to nuts and bolts I used the following parts that simulate bolts and nuts:
http://www.litomysky.cz/kadee/kad088.htm.
So the guns are finally done, rigging will be added immediately prior to installation aboard.
- archjofo, dvm27, Bluto 1790 and 19 others
- 22
- Mirabell61, Bluto 1790, wyz and 16 others
- 19
To Allan - the monogram is not my production, these are made by "etching" company (http://www.etchworks.cz/). Normally are parts etched simultaneously from both side, here is etching made only from one side. Before gluing is necessary to roughen both surfaces (eg. tweezers) then glue adheres well (I had to repair two pieces from 20). The solution for blackening - heated solution water and patina for Tiffany technique (ratio 50 : 1) (http://www.vensy.cz/vensy/eshop/12-1-Tiffany-technika-cinovani/31-2-Chemie-pro-cinovani/5/345-Patina-cerna-tiffany-technika)
Carriages assembly.
- Bluto 1790, Erik W, Mike Y and 9 others
- 12
Hi to all,
so after a long break back to "work" .
To Tom - used wood is boxwood and steamed pear
To Nigel - No, I don´t.
To Greg - I had to instal the hanging knees before beams due colloring of inner bulwarks, but I like it.
To aviaamator - sorry for flaws. I agree that real part of deck is little bit simplified because the interior will not be visible.
Sorry for delay with reply.
As another part I chose the production of guns. Guns will be turned from brass, the problem is that turning is a completely new thing for me and so far I'm learning it. I've ruined so much material over and spent so much time that would be cheaper to buy finished guns. On the other side it is the great challange for me. I hope that in a few days I will be able to "show" some result. For now at least I prepared various eyelets and hooks.
- druxey, aviaamator, wyz and 14 others
- 17
Hi Daniel, the blue color is acrylic paint from czech producer (http://obchod.agama-model.cz/cz-detail-235034-r29-p-tmava-sedomodra.html).
Aft cabin bulkheads are finished and installed on the deck.
- BLACK VIKING, Vivian Galad, EdT and 36 others
- 39
To toms10: The lettering is made with scroll saw. The same procedure is used for ornaments (with some hand carvings).
To EdT: I am very happy that you like my work because YOU are the true master on this forum .
I started with preparation of aft cabin bulkheads.
- zoly99sask, PeteB, Dubz and 33 others
- 36
Pandora by marsalv - FINISHED - 1:52
Thank you Tom, but the reality is not so simple as the photos show .
I attached the false rails, main rails are installed on the model.
