Posts posted by ERS Rich
1 hour ago, JSGerson said:
The fine tooth blade will slice those 1/32" x 1/32" strips with ease
Now that’s a great suggestion about the blade, thank you very much for reminding me!
Regarding the trim/painting. One possibility is painting the trim first, white, then masking and applying black. Light color first, then dark.
To save time and tape, going to paint black first with an Iwata RG-3 mini spray gun, then paint the trim white, with a brush. Another thought is the white over black will diminish the “whiteness” of the trim, less pop.
And only paint the outboard face of the trim.
Will checkout your log to see what’s up with the stern galleries….
36 minutes ago, JSGerson said:
Very nicely done.
Hi JS, thanks for checking in. The trailboard hasn’t been glued in yet…..Liking the wood trim in a big way, especially how it looks on the timbers. It steam bends easily and glues up nice and quick.
Problem is, only 2 strips in the kit. Having trouble making more with my mini table saws - the blade chews up the wood. It’s available from Bluejacket…..
- ccoyle and GrandpaPhil
- 2
- GrandpaPhil, CiscoH and k-mart
- 3
Head Deck Gratings and Second Rail
It took me a while studying the plans and the reference books, particularly the Anatomy of the Ship, to understand the sequence to install the Second Rail. Finally understood the deck grating is where to start.
The gratings sit on a frame attached to the stem and head timbers, and the rail acts as a fascia board, covering the outboard end of the timbers and the ends of the athwartship grating support beams. Study plan detail 4A to understand this relationship.
The deck grating position drives where the beams are located on the timbers. And the location of the beam on the timber drives the final shaping of the timber top.
So started by building the grating frames. The frame aft edge is aligned to the bottom of the second strake below the sheer strake.
Picture 1 shows the port side frame. Notice the beam ends are a little long and will be trimmed and shaped to fit against the side of the rail. Also notice the rail ends offer additional glue surface area, that will help when glueing up the rail.
Picture 2 shows glueing up the rail with ends clamped and a rubber band in the center of the stem looped around the board.
Picture 3 shows the rail in place. And picture 4 shows the grating installed. Finally picture 5 shows the side view.
- Boatsinc2000, SUBaron, GrandpaPhil and 1 other
- 4
Third Head Rail
After much time checking the fit and shaping, forged ahead and began glueing the rail in position, starting with the forward end and working aft.So glued the forward end of the rail to a position just aft of the laser cut scroll work and the first timber, then clamped, and let dry. Repeated 2 timbers at a time.
After starting, realized that’s the horn on the aft end was not shaped as much as I wanted but had to go with it. Picture 1.
Picture 2 shows glue squeeze out along the rail horn, to get some gap filling. Use a toothpick to remove the excess after a few minutes. I also used a dab of CA to get a quick hold without clamping.
Pictures 3 and 4 are views after shaping the cathead support knee and the aft end of the rail, using a cylindrical burr in the Foredom - Picture 5.I think the rail horn needs a bit more material removed along the lower edge, seems a little fat in picture 3.
- WalrusGuy, Boatsinc2000, Matt D and 2 others
- 5
19 hours ago, KirbysLunchBox said:
Beautiful build! This is going to be a masterpiece foe sure!
Thanks KLB, this is the first time I’ve built such an elaborate head, the rails are intimidating. I spent a lot of time looking at the plan and the Anatomy of the Ship reference book. Finally came to realize that there are variations in the references so there isn’t a perfect answer to positioning the timbers. It’s been a very iterative process, shaping the rail, committing and installing the timbers, using the rail to mark the timber notches, checking the fit of the rail, and shaping it.
Thanks for checking in and stay tuned!
Cathead
Attached the hardware on the cathead. Used the Foredom drill press to drill the 1/64” holes for the eyebolts. The cathead face decoration is by Caldercraft purchased from Cornwallmodelboats.co.uk. Note, they are too small, so ordered the larger size. Also drilled 6 holes to simulate the sheaves. Picture 1.
Then I painted the inboard ends black and installed. Picture 2.
Last I made and installed the support knee with the template on plan sheet 5. Built it a little over wide so it can be blended into the 3rd Rail aft piece. Picture 3.
- GrandpaPhil and Boatsinc2000
- 2
Finishing the Timbers
Installed Timbers 4, then clamped the 3rd Head Rail on the timbers to mark the notch locations. Picture 1.
Picture 2 shows the notches. Notice that the lower edges of the notch follows the line of the paper templates.
Next worked on final shaping of the rail, clamped the rail to the timbers to check the fit, removed and shaped, clamp again, repeat. During this process noticed Timber needed to be moved away from the hull, so broke the glue bond and added a shim. Picture 3.Finally with the rail again clamped in place, determined the location of Timber 5, which needed a bevel on the inboard end.
Making and Installing the Head Timbers
Have the 3rd Head Rails partially shaped, but need the head timbers in place to guide the final shaping.
Started by using the plan to determine the dimensions of the required blank for Timber 3. Picture 1 shows the dimensions of 9/16” by 15/16” and two blanks taped together with double sided tape.The blanks are popular. Hardwood is best for sharp and crisp corners.
Next use a template to mark up the blank. We are taking advantage of the lower left corner and the horizontal top of the blank. Picture 2
Picture 3 shows chunks of waste wood, cutoff with the table saw.
The Foredom drill press with the drum sander makes quick work of shaping the piece. Picture 4The timber is glued to the stem, with a section of the plan used as a spacer.
- GrandpaPhil, JLong, JeffT and 5 others
- 8
Nice idea regarding the black bristles….model looks really good, Congrats!
Welcome to MSW, always open to answering a question if you need a hand.
Good luck with your project!
- Keith Black and mtaylor
- 2
Third Head Rail - Rough Cut
Making the 3rd Head Rail from a single piece, from a block of hard maple cut on the scroll saw. The technique is the same used in furniture building to make a cabriole leg, (YouTube example).
First is to determine the dimensions of the wood block. Using the plan the block dimensions were determined to be: 4 7/8” long, 1” thick, and 1 5/8” high.
Next templates of the profile and plan view were used to line out the blocks - Picture 1 shows port and starboard blocks.
The scroll saw was used to cut the block, and after each cut the block was taped back together - Picture 2.
Picture 3 shows the block on the saw.
Picture 4 shows the result after making all the cuts and breaking away the pieces.
Picture 5 shows the port and starboard rough rails, and a starboard rail, previously made. partially shaped. Use the templates to mark lines as necessary.
Last picture shows that rail in place, with final shaping yet to be completed.
- usedtosail, BobG, Boatsinc2000 and 2 others
- 5
- BobG and GrandpaPhil
- 2
17 hours ago, Boatsinc2000 said:
Trying to figure out what I'm going to do with the trailboards.
Thanks Boats, one motivation for doing the log is a record to refer to when I don’t remember how I did it the next time around….
About the trailboards, the College of Model Shipbuilding Guide shows how to make relief carvings from plastic stock, I’m not ready for that. Plan to seal the boards, then airbrush paint white, then paint the black areas and the shield with a fine brush. I think to the casual observer it will look the same as the real thing….
For the white trim, plan to also airbrush paint white, then mask the white paint and paint the remainder black. The CMS guide shows how to use plastic for the trim. However, I think plastic on wood is kind of out of character, plus there isn’t, in my opinion, such a difference between applied trim time and paint, that justifies the extra time.Happy Labor Day!
- GrandpaPhil and BobG
- 2
Hi Avi,
Wow, my heart sank when reading the beginning of your post. So sure glad that it worked out. Yes, there is a subtle, but after noticing, an obvious difference between the catalog picture and what was delivered.
Forgive me if this is repetitive, but I love plank tapering and block shaping, with the plane in a vice, learned that technique from the late Phil Lowe, Master Furniture and Cabinet Maker and founder of the Furniture Institute of Massachusetts.
Happy Labor Day!
Welcome and good luck with your project!
- mtaylor and Keith Black
- 2
Cheek Knees and Rails - Part 1
Onward to building out the stem detail.
First is to make a template of the cheek knee/rail top view from Plan Sheet 4.
First picture shows a photocopy of the stem area from the plan, on top of a 1/4” thick piece of poplar, with carbon paper in between. A stylus was used to trace the upper and lower rails.
Picture 2 shows the result, a little rough but workable.
The pieces were cutout with a scroll saw and shaped with the oscillating spindle sander - Picture 3.
Picture 4 shows the pieces on the plan, note the aft ends are long - the ends will be trimmed to fit the cheek knee pieces.
Fit to plan is one thing, but the trailboard edge governs, so the pieces were shaped to fit the trailboard - Picture 5. The tailboard itself is a nice template.
The rails were tapered towards the forward end, also using the spindle sander.
Picture 6 shows the dry fit positioning of the pieces on the stem. The aft ends of the rails need to be shaped and beveled to fit the curve of the hull. Took a while to get it all straightened out - cut one rail to short. Ended up making 6 rails.
The knee pieces were made using the template from sheet 4. They also need to be shaped and beveled to fit the hull.
Last picture shows everything glued in place. The trailboard is not glued so it can be removed and painted separately.The popular is stiff but brittle and I broke a couple of rails while shaping. The lower rail has a smaller fiddle head on the forward end, after breaking a rail while shaping it, decided to shape the forward end after glueing the rail to the stem.
- Tidbinbilla, GrandpaPhil, drjeckl and 9 others
- 12
1 hour ago, BobG said:
Impressive work, Rich!
Thanks Bob.
Installing the Berth Deck Portlights and Gundeck Scuppers
We need to drill holes in the wales for the port light and scupper fittings.
First thought was to draw a line with a compass across the hull and mark off the necessary locations.
The most important consideration is we need to get clean holes by minimizing tear-out, sharp bits are essential. So decided the portlight holes would be made in the middle of the second wale strake from the top. The scuppers were installed along the seam between the first and second strake. The portlights have a nice flange to hide a rough edge, but work towards getting a nice clean hole.
Picture 1 shows a triangle on the plan aligned on the baseline and dividers measuring the distance from the forward edge of the last gunport to the aft portlight. The dividers were then used to mark the location of the aft portlight on the second wale strake.
Picture 2 shows how subsequent hole locations can be marked based on the distance between portlights and always in the middle of the second wale strake from the top of the wale.
Use progressively larger bits to drill the hole. Picture 3 shows the tools with smaller bits on the right to the final size bit on the left.
Picture 4 shows drilling the final hole by hand. Take care, start by turning the tool to the left to compress the fibers around the hole. Then turn to the tool to the right to enlarge the hole, and occasionally to the left, to again compress the fibers.
A round file can be used to cleanup the hole, Picture 5.A toothpick can be used to help with installation Picture 6. The adhesive is a tiny bit of epoxy.
Last picture shows the lights and scuppers installed on the starboard side.
Making and Installing the Pinrails
Stained stock and drilled the holes along the stock with the Foredom drill press.
Then cut the stock to length and drilled two holes and installed 2 pin nails in each piece, with points out. Pieces were placed on the plan to keep track.
Pinrails are located 7/32” above the top of the waterway, so made a spacer block to help with positioning. Then it was just a matter of pressing the pinrail into the bulwark, with a bit of glue along the edge.
Last picture shows rails installed on the port side, with pieces on the starboard side ready to go.
- GrandpaPhil, BobG, Boatsinc2000 and 3 others
- 6
Emma C Berry 1866 by Sea Hoss - FINISHED - Model Shipways
in - Kit build logs for subjects built from 1851 - 1900
Congrats SeaHoss!
