Dave_E
Everything posted by Dave_E
  1. Hello Sir, Did you finish your Rattlesnake? Are you still building? Hope you are well.
    1. Teikuro
      Teikuro
      Building out the hull
  2. That little bit of wisdom is going into the notebook. Thanks Fellers. 👍😀
  3. Have fun! When you get back, tell us where you went. 👍😎
  4. Hi Keith, I’m going to try and add some rope coils, however that will be after I build a jig and practice. It’s tempting to just throw the other anchor on and the upper mast stay and the swivel guns and be done, but I know I can do some learning and some experience for the Rattlesnake and get a better finish on the Lady.
  5. Thank you Glenn, that mean a lot to me coming from you. 😊
  6. Retired… it’s a holiday, lawn is wet, cloudy… good day to be in the boat yard. 😁
  7. Allan, I wish we would have connected 2 hours ago. I ended up with what I did after searching and looking at 4 different builds, all had something different. I have your reference on file for the Rattlesnake. 👍😀
  8. Perhaps do a semi hidden area as a sanding experiment to see how much you can get off? And then apply your chosen color to see what the turn out will be?
  9. Welcome aboard! What can we call you? Your stage name is quite long. 😊 Nice work!
  10. Hi Dave, Welcome to the forum, lots of experience and fun here for sure. Welcome aboard! LCdr in the RCN?
  11. Hi All, Here is what I have put together since this thread started. Pictured left to right: shellac, poly urethane, thinned white PVA, thinned wood PVA, CA, thin CA. The shellac, poly and the thinned PVA stores and works great out of the squeeze bottles. During my ratline learning experience, I used every one of these except the thin CA. They all worked. That being said, I loved the way the shellac soaked into the rope and was invisible afterwards. The poly did the same thing, except I can’t take the fumes. Can’t move things around as fast as when you use CA, and when I did use CA, yep got the shiny blob, going to have to maybe touch up with some paint. Each of these adhesives have their own personalities and uses in rigging (and any other building). I think I am a shellac convert and can see its use as a sealer before paint and as an adhesive for some rigging. The only drawback is it really drys up fast when you put a drop or two on a plate to dip a needle point into. Oh well. So, that’s my research. 😀
  12. Good Saturday Morning Everyone, As I get nearer to completion of the Lady Nelson… the thought of display now looms large in my head (Admiral is also constantly asking “where you going to put these things”?) 😆 My home with forced air heating and cooling is dusty. No explanation, ducts are clean, Hepa filter being used, register filters being used, bla-bla-bla. Maybe something to do with living in the PNW and all the trees? My choices are: build an enclosure or not. Question for the masses. Those of you who did not build enclosures: what does your ship look like 1, 2, 3 years or more regarding dust (airborne particles)? I fear mine would look like it was in a snow storm after 4 or 5 years. I can’t even imagine trying to “dust” a completed ship. Discussion?
  13. Hello Everyone, It’s Friday night and I just finished up the starboard side ratlines. First let me say… ratlines were a challenge on this first build, probably because I messed up the order of rigging. The starboard side turned out much better than the port as I learned the techniques and got better tweezers (wow what a difference they make). Lots of imperfections to be sure, but lots of learning took took place and I made notes for the Rattlesnake coming up. On to the anchors. 😀
  14. You must be retired. Your pace is incredible. 👍😀
  15. Hi Rob, welcome aboard. YEARS of talent and experience here to help your shipbuilding in any way! 👍😀
  16. No matter what I end up doing… those CNC blocks from Syren are absolutely gorgeous! 👍😀
  17. Actually it is wound, just like rope. Looks like rope up close. What I do not know about is the fuzz… 😳
