Everything posted by Rustyj
Ah the one good thing about winter. More modeling time!
- 399 replies
- winchelsea
- Syren Ship Model Company
Thank you Don, Bob, Glenn and Joe and all the likes too. Much appreciated. I'm working on the eye bolts, spanshackles and cover boards for the stove stack and chapter 9 will be complete!
- 642 replies
- winchelsea
I moved on to the fcastle rail and knightheads. The knight heads are laser cut but the tops needed to be shaped on all four sides. The laser cut rail needed to be sanded smooth and the edges softened. This is where I ran into another oops moment. I hooked the end of the rail snapping off the end two slots. I broke out some sheet stock and remade the first three slots. Why three you ask? This way the joint would be over the cathead and covered by the cat block. Just in case the seam was visible plus added strength when glued in place. The fun part of the cat block was it needed to be sanded to the curvature of the rail. Not difficult but I needed to go slow to make sure I didn't over sand! Once everything was test fitted it was painted and glued in place.
- 642 replies
- winchelsea
That looks really good Mike.
- 607 replies
- winchelsea
Beautiful work Glenn. So much more fun than planking that huge hull.
- 840 replies
- winchelsea
That was my though too. Just wanted the group opinion before I adjust them. Thanks!
- 642 replies
- winchelsea
Congratulations on a great model and a build log that was enjoyable to follow and will be a tremendous help to others who follow.
- 855 replies
- Sphinx
- Vanguard Models
Well, I went back and rounded off the 1/32' X 1/32" strip to make the waterways. They were added as well as the breasthook. Next I assembled the catheads. Like the belfry take your time and they come out looking nice. I then cut out the notches for the catheads. They are placed but not glued. I'm trying to determine if the angle they are at is correct. The cathead sits flush on the margin plank but they look a little high to me. Hmmmmm.
- 642 replies
- winchelsea
Another fine masterpiece! It's been a great joy and learning experience following along with you. As Mike said enjoy your vacation and I can't wait for the next project!
- 1,784 replies
- winchelsea
Thanks Chuck, Your design and patience made it really fun! Thanks Glenn, Yes adding deck pieces really start making her look good. Thanks JJ, After doing the Confederacy in box I wanted a different look and I'm glad it came out nice. After you finish the Winnie you can do your next one in cherry! Thank you, Mike and Ben. Your kind words are always appreciated. Thanks for all the likes too! Oh by the way while working on the breasthook I noticed I completely forgot to put on the waterways so I'll be doing that next too! 🤪
- 642 replies
- winchelsea
ancre Le Gros Ventre by ChrisLBren - 1/36
Rustyj replied to ChrisLBren's topic in - Build logs for subjects built 1751 - 1800
Nice progress Chris! -
Thank you, Vlad and Frank. Also, thanks for all the likes. I've spent a couple of days building the belfry and the belfry rail. Next, I'll fit the breasthook at the bow.
- 642 replies
- winchelsea
Your work continues to be exceptional! I love seeing your updates. Well done on the calendar too!
- 840 replies
- winchelsea
She's looking fantastic!
- 1,784 replies
- winchelsea
Hi Ron and Glenn. Yes, both the Indefatigable and the Speedwell are looking like winners to me. I'll enjoy dreaming about them while working on the Winnie. I'm saving my bottles and cans to fund them. 🤣
- 201 replies
- Duchess of Kingston
- Vanguard Models
Excellent Glenn job on building a wonderful model. Your log will be an inspiration and great guide to those who follow!
- 476 replies
- sphinx
- vanguard models
Thank you Derek. I'm glad to see you back at you DOK.
- 201 replies
- Vanguard Models
Thanks Jeff! The fcastle work continues. The coamings were added along with the planking and the bitts that were made quite some time ago. Also the mast coat was made from the Syren laser cut parts. Next I'm on to the belfry.
- 642 replies
- winchelsea
Thanks Dusan and Frank. Also thanks for all the likes!
- 642 replies
- winchelsea
Thanks Chuck, I'm sure there will be a good bit of "adjusting" when I finally get there. FYI still having a ball building her! Thanks Tim, I was trying to help out by letting everyone know it's ok when you have to make adjustments. Just look forward to how the adjustments can have a positive or negative effect on other aspects. Thanks Bob, I learned from you and others! Thanks Glenn but I'm sure with your preparation you won't even need to "adjust" this planking.
- 642 replies
- winchelsea
