Rustyj
Posts posted by Rustyj
  1. I've returned to the second planking layer of the wales now. The first four strakes are 3/64" x 7/32" and will be painted black.
    The fifth strake is the black strake will be added after the wales are finished being painted and will be left natural in color.
    As the wales and black strake are supposed to taper to almost nothing at the stem. This is to make them look like they fit
    into the rabbet. I pre sanded them down to 1/64" before gluing them in place. This helped me smooth them down without
    having to take as much off and risk damaging the stem.
    Here she is in all her dirty glory. The starboard side is unpainted and the port side with a first coat of paint.
    I am using Admiralty Paints "Matt (Metal) Black"
    Many coats of paint to go and then I'll add the black strake.
  2. Thanks VTHokiEE.
    4 hours ago, BobG said:
     Is it relatively easy to work with and bend? Also, are you using Chuck's method of gluing the planks with just a small dot of CA on the frames?
    Thanks Bob,
    Working with it is nice. Holds a good sharp edge and sands well. I feel it's harder than Cherry thus making it a little harder
    to bend but nothing that makes it more difficult. As far as Chucks methods I edge bend, twist and curve with heat to the
    shape of the hull just as Chuck describes. As to the gluing I try to mimic Chuck as much as possible but I resort to some
    edge gluing a bit more the Chuck does. I haven't gotten that good yet.
    I grabbed a scrap piece of cherry and pear, wiped a quick coat of wipe on poly and took a picture.
    You can see there is a bit more visible grain and a little lighter color with the cherry. In my opinion they both are great wood to work with.
  3. I've spent the last couple of weeks completing the first belt of hull planking on the starboard side. Both sides have
    been preliminarily sanded with 150 grit and received one coat of wipe on poly. Once I finish planking the rest of the
    hull I'll give it a good final sanding with 400 grit sandpaper. Now that I have completed the first band of planking I'll
    now go back and add the wales. From this point on I'll do a majority of the planking with the hull upside down.
    This will minimize the damage to the wales and their paint from my clumsiness.
  4. Hi All,
    It's that time of year where my part time job becomes more than full time. Plus the admiral decreed
    that the rec room needed new decking. At least it helped me work on my plank shifting! :)
    So I used Chucks supplied tick strips and lined off the hull. I then I proceeded to plank the six rows of the first belt
    on the port side. It's been lightly sanded and I will wait until the full hull is planked before finishing the sanding.
    I'm off to start on the first band of the starboard side.
    DSC00085.thumb.JPG.12006ad52245090989a7b73fd6907a95.JPGDSC00086.thumb.JPG.7f88b993940f691e218705a8e79c3692.JPG
