Posts posted by flyer
Very nice!
This seems to be a 18ft cutter. Do you also plan to offer a smaller 12ft or 14ft boat, suitable for your smaller vessels, such as Alert?
- thibaultron, mtaylor and Canute
- 3
Hi Nils
As we would say in Swinglish: I pull my hat before you (ich ziehe meinen Hut vor dir).
Not only have you built another unique, detailed, outstanding gem but you also finished it in about 8 months! From scratch! Without plans!
Wonderful!
Cheers
Peter
- Keith Black, Canute, mtaylor and 3 others
- 6
Hi Allan,
And a happy new year to you too!
Yes, Lees mentions '...through blocks under the fore top...' several times and the drawings show those blocks fixed at the extremes of the trestle trees - except on page 102 where a 'double block is seized to the crosstree'.
I wonder if regulations in those times really went as far as to specify the exact locations of those blocks. Lees, in his introduction, mentions that his written sources mainly deal with size and dimensions. I guess that the actual run of the lines of the running rigging he shows is an average of the many but still limited number of models he studied.
I'm always tempted to follow kit instructions if they are not directly contradicted by e.g. Lees. Respectable kit designers may use Lees or their own research for the rigging plans and certainly try to be as historically accurate as possible. But even somebody like Chris Watton may have to use approximations sometimes to construct a practicable and sellable kit. And then sometimes I'm just lazy and tempted to take the easy way out.
Cheers
Peter
- Keith Black, mtaylor and allanyed
- 3
The question I tried to answer was about the green circled blocks in the 2nd picture of #1:
I took those as indication of having two identical rows of blocks on the forward and aft crosstree. The lines then are going through the identical blocks on each crosstree thus leading free of and above the fore yard, perhaps to give some space to brace the yard.
In Lees' book you find on page 73 top right an illustration for the buntlines, installed that way. (BTW on Bellerophon I used a similar arrangement also for the main yard.)
The two outboard single block pairs were thus used for the buntlines and the inboard double block pairs I used for spritsail and sprit topsail braces. This is confirmed by Lees again on page 101 respective page 105.
- Keith Black and mtaylor
- 2
conclusion
After more than 6 years, I'd say it was a rather longish journey but I really had a lot of fun along the way and it was definitely worth the effort. The outstanding quality of the kit and the possibility to build 3 different ships makes it easy to overlook a few shortcomings, such as questionable details in the rigging plan or the very questionable gun carriages. On the plus side are also things like the very detailed plans such as the sail plans, the boats or the many fine details to build bulkheads or stern and side galleries.
A perfect kit where you may build just out of the box without research or rounding out with additions might be just a bit dull - I will probably find out more about that with my next project.
In any case this kit enables you to build a wonderful model of a 74, the backbone of the wooden walls protecting Great Britain during the Napoleonic wars. Finding a good enough place to present the rather large end result is another story...
a few final pictures.
- Knocklouder, BenD, chris watton and 9 others
- 6
- 6
Thank you all for the compliments as well as for all the support carrying me through this build.
And a very happy New Year to all of you!
Peter
- Mr Whippy, Meriadoc Brandybuck, AON and 1 other
- 4
changes, amendments and mistakes
The biggest changes were the dummy gun carriages on the gun deck and the cast gun carriages, the stern decoration as well as leaving of the spritsail topsail and its yard.
The most rewarding improvement, in my opinion, were the dummy carriages. Thank you, Michael (md1400cs). On any kit which includes such dummy guns, installation of a sort of dummy carriage should be tried.
Minor amendments were the changed curve of the stern, the scuppers, the sails fabricated my way, the flag, shot garlands, the captains skylight, the taffrail, the rudder chains, the anchor bolsters below the fore channels, the traveler on the bowsprit, anchor buoys and several minor changes.
The biggest, uncorrected mistake is probably that I did set up the preventer stays above the stays, thus having to hang the staysails onto the stays themselves.
slightly reworked gun carriage for the upper gun deck and dummy carriage for the lower
gun port with dummy-carriage and -gun / carriage and no gun / gun and no carriage
the elephant was scratched away and replaced by a epoxy-cast of Bellerophon
finished transom with new rail on top
spritsail without topsail and traveller on the bowsprit, holding the jib stay
- Kingspoke, AON, Meriadoc Brandybuck and 5 others
- 8
Thank you, Nils. When I see what quality you achieve, scratch building your Ergenstrasse, I appreciate your compliment even more.
Oh, and a very happy new year!
Peter
- Mirabell61 and Mr Whippy
- 2
empty belaying pins and ringbolts, loose ends
Despite having to overcome a shortage of usable belaying points on the forecastle there were still a few unused pin positions on the poop deck.
Also unused ring or eye bolt positions around main and mizzen mast had to be filled. The kit instructions put eye bolts into those locations. However I think that ringbolts, allowed to lie flat when unused, would be more sensible when mounted on the deck. I didn't find much about that in the web but thought it would be easier to run about on deck if you wouldn't have to fear to catch your bare feet in a ring, take a tumble and break your ankle.
To imitate a ringbolt with a small fixed ring which encloses the movable one tightly, I bent an eye bolt 90° and put a drop of glue onto it to simulate the fixed ring.
After fixing all loose ends I could find, finally...finished!
the way I fabricated the imitated ringbolts
unused ringbolts around the mizzen mast foot
fore mast foot with eyebolt(with tackle) to the left and one of the empty ringbolts lying flat on the deck
moderately busy scene on the finished forecastle
the skipper seems quite fond of his ship - and so am I...
anchors
A suitable stream anchor was added to the 5 anchors from the kit, all completed and stored. A conflict for space occurred between the sheet and bower anchors and the lower stun sail booms. The only way I could think of, was to place the anchors on top of the booms. Thus, to set booms you have to move them from under the anchors.
Anchor buoys were formed with some 2-component putty and hung into the shrouds. As I understand anchors were buoyed and buoys should therefore be shown whenever a cable was bent to the anchor making it ready for use. For size I used information from John Harland who writes that '... the anchor buoy was in length one-quarter the length of the anchor shank, in diameter, one-eight...'.
port side with sheet and bower anchors and the extra stream anchor lashed to sheet anchor
stream anchor
the cable is attached to the bower anchor and the cat block with tackle is hooked into the ring
starboard with sheet and bower anchors and the kedge anchor lashed to the sheet anchor
kedge anchor
anchor buoy stowed in the fore shrouds
the buoy rope lashed to the anchor
- KARAVOKIRIS, GrandpaPhil, mugje and 6 others
- 9
jib sail
Several tries were necessary to find an adequate size for the jib sail. To me it was clear, that the kit's plan for the sail was grossly unfitting. Trying to draw one following the description in James Lees in 'Masting and Rigging of English Ships of War' was more difficult than expected. Several attempts were tested with paper templates just to prove unsatisfactory. Finally I tried to use the same proportions in regard to rigging and the other sails as Pandora's jib in the ATOS series has. Judging by eye it looked about right.
To bend the jib to its stay I used again figure-of-eight robands. The tack was hooked into the traveler and the rigging set up with help of the kit plans and instructions and some clarification by Lees.
Now I only have to install the anchors, to check the natural hang of all lines and to clean up everything...
Oh yes, and to find a suitable berth for a rather big model...
trying to find the right size - the smaller blue outline is the final one
detail of the peak
all sails are now installed
Brian Lavery in 'The Arming and Fitting of English Ships of War' also writes of using cuprous alloys. He doesn't say what kind of alloy exactly but he writes about the problems with the strength of bolts made from pure copper and the search for a suitable alloy almost as strong as iron.
Comparing different copper alloys I think the solution probably was some bronze - copper and tin - as it is the strongest. What the cost of such fittings was, is another question but losing a ship because of the decay of iron bolts was certainly costlier.
Peter
Hallo Franz
Your Barbara plan seems to me a really valuable discovery. Building her with the Pickle kit seems an excellent idea. If you like you could still name her Pickle and be probably closer to the real boat as Caldercraft or me.
By the way - I didn't suggest that Calcercraft was using the Adonis class plans but that I would use them to overwork their Pickle.
You could further consider a contemporary painting by Robert Dodd which probably depicts Pickle in the foreground on the right. There you see a vertically stepped foremast.
Looking forward to your build log!
Herzliche Grüsse
Peter
Allan's advice is of course good and sound - and you really are your own skipper and use the paint you like.
However to ensure a lasting joy of your build I would like you to consider something I also wrote in my present build log:
(In a book, written by a professional model railroad landscape builder he explains about colour scale. By that he means that if you look at a model in scale 1/100 from a distance of 50cm it should look the same as the prototype from a distance of 50m. And from that distance colours look less bright because of the air absorbing some of the intensity. He says that's the reason that models tend to look like toys if you use original colours. He recommends to always mix in a bit of white or grey and to avoid shiny colours.)
Following this advice I always mix about 15% of dull white into all paints, including black. And I use only dull colours. Some very nicely built models are in my opinion made to look like cheap toys, only because of the use of too bright and gaudy colours.
Peter
do kit designers dislike travelers? or
setting up the jib stay
Since I started making the sails I had problems with one of them: I simply didn't like the cut of that jib.
Although in the book Bellona of the AOTS series the jib looks similar or perhaps even stranger than that on the kits plans, all other sources showed quite differently cut jib sails. First I tried to reshape the sail more in accordance with Lees explanations. Very slowly I finally realized, that in the kit the jib sail was wrongly set on the fore topgallant stay and the jib stay completely omitted.
I guess sometime during the making of the bowsprit I was glad not to have to make a traveler for the jib stay assuming that on a 74 a different arrangement was used. Well, it wasn't.
Furthermore I think, I never met so far a kit with a decent traveler included. Perhaps there were some approximations like combining stay and out hauler and leading the stay directly through the hole in the jib boom which represents the sheave or setting up a simple ring around the bowsprit.
But after seeing how much thinking goes into representing beautiful, detailed stoves which are mostly invisible on the finished model a decent traveler shouldn't be asking too much for...
Fortunately the necessary cheek blocks on the fore topmast are included in the instructions. So, the difficulty was only to set up the traveler around the finished jib boom.
I searched some stiff brass wire with 0,7 and 0,4mm diameter in the leftover box and bent the 3 parts: ring around the bowsprit, shackle for the stay and hook for the tack of the sail. Owing to the reduced availability of material and my clumsiness the parts are rather a bit oversized.
Shackle and hook were finished with a bit of soft solder, threaded onto the opened ring, the whole forced onto the jib boom and the ring closed and soldered. While the jib boom was protected with some masking tape the whole arrangement was now painted. A small block was fixed to the ring for the down hauler.
As jib stay I fixed some 0,5mm black thread to the shackle, led it up and through the starboard cheek block on the fore topmast and down the fore channels. I set the end up with a simple tackle, hooked into a ringbolt on the channel. The out hauler is 0,5mm natural thread (slightly oversized again), leading through a hole in the outer end of the jib boom (this represents a sheave) and back towards the portside knighthead. Again it is made fast with a simple tackle, hooked into the lower part of that knighthead.
Now I made an adapted paper template to test the jib sail and found it looking definitely more convincing.
the skipper checks the parts of the traveler
the ring is not yet soldered
finished traveler in place
jib stay through the starboard cheek block
jib stay tackle inboard of the shrouds
in hauler set up with a tackle to the knighthead - its end is belayed in front of the skipper
adapted jib sail template on the new jib stay
- davyboy, Kingspoke, DonSangria and 7 others
- 10
You should use the Victory Models plans only as a general guideline and check carefully with Lees. The plans are generally good but may have some disputable details.
There were also several changes in the rigging from Bellona to Vanguard - e.g. Bellona still had the lateen mizzen yard.
The Victory Models plans on the other hand show for example the topmast stays rigged below the associated preventer stays which is quite likely the wrong way around.
- allanyed, GrandpaPhil and mtaylor
- 3
fore topmast staysail
This as well is set furled. By reducing foot and leech each by 20%, I got a sail area of roughly 2/3 of that on the plan. The sail was again made in a simplified way and bent to the fore topmast stay.
Because I did earlier rig the preventer stay above the main stay I had to set the staysail on the stay itself. Perhaps thismeans, that the arrangement of the stays is in fact incorrect.
The sail was bent to the stay with robands and all lines were added.
While now furling the sail tried to follow the explanations of John Harland in 'Seamanship in the age of sails' - as well as I understood them. The outcome doesn't look to bad and after belaying the lines, I'm now ready to move on to the last sail, the jib.
plan with reduced sail area
sail set, not yet furled
...and furled
looking ok
- AON, Techtonic, Thukydides and 7 others
- 10
spritsail yard and sail
A by 30% reduced and furled spritsail was bent onto its yard. Without the spritsail topsail yard the rigging could be a bit simplified. On the other hand I did add the guys according to Lees' description. The yard was triced up by about 20°, as on the painting above.
I rather like the dynamic impression Bellerophon gives with this arrangement.
the spritsails and John Harland
James Lees in 'Masting and Rigging English Ships of War' explains nicely the different elements of the bowsprit rigging but doesn't always indicate what's right and wrong. Additional information such as own research or flawless kit plans are needed.
John Harland is the author of 'Seamanship in the age of sail'. Actually I was just looking for some information about how to set spritsail yards and eventually a sail. But then I found in his book a very interesting chapter about spritsails (page 85ff.). A few questions were answered but still more raised. What he writes, especially about the sprit topsail, had me thinking. He states that - and I hope I understood him correctly:
When the flying jib boom was introduced together with the flying jib, immediately the dolphin striker and martingale stay followed to hold the new boom down. However the martingale stay made the setting of the spritsail topsail impossible and the spritsail topsail yard became useless and disappeared. The martingale backstay at first made an almost vertical return to the bowsprit to allow the spritsail to be set. Later the martingale backstay was led directly to the bow, thus preventing also the spritsail to be set and it passed into disuse as well.
The proposal of the kit to have dolphin striker and spritsail topsail yard simultaneously seems illogical although John Harland states that this configuration may be seen on contemporary models and even on today's HMS Victory. On the other hand the way the martingale backstay is set up, which initially baffled me, is now explained.
So I seemed to have 3 options:
- scratch the dolphin striker again and set both spritsail yards (yay - all that work on the 2 replacements for nothing!)
-scratch the spritsail topsail and its yard and have a somewhat ambiguous situation with a dolphin striker and no flying jib boom.
- add a flying jib boom (yay again!)
Then I noticed that just on John Harland's book cover a situation like the second one seems to be depicted. Also, if you had to take in the flying jib boom for some reason, you would leave the dolphin striker in place . So, option two was it.
Additionally he stated that near land the spritsail was never set because it hampered the forward vision from the quarterdeck too much.
Finally he explains that when sailing by the wind the spritsail yard was triced up also without a sail set and the guys on the lower or weather side were hauled taut to give additional downward pull to the jib boom.
Conclusion: I will scratch the spritsail topsail and it's yard and adapt the rigging of the spritsail yard accordingly. The spritsail yard with a furled sail will be triced up by about the same amount as all the yards are braced. I will also add the missing guys to the spritsail yard.
In this Thomas Luny painting (found in the web) Bellerophon is depicted with dolphin striker, flying jib boom and without spritsail topsail yard.
Another Thomas Luny painting (also found in the web) showing a two-decker with similar configuration sailing by the wind and showing the triced up position of the spritsail yard.
5 hours ago, allanyed said:
Can you give us the name of the textile paint and the TC of the cotton cloth you used?
After using it for years and now taking the picture I noticed, that the red isn't actually textile paint - but works anyhow.
The TC is an estimated 200 - 260 (per inch). The second picture compares the fabric delivered with the kit (right) with what I found in a small local mercer after asking for the 'lightest, densest, natural cotton you have'. The somewhat ham-fisted sailor btw is in scale 1/72.
Cheers
Peter
https://en.pebeo.com/catalogue/couleurs-pour-textiles
Hi Alistair
Thanks a lot for the compliments.
Also, I appreciate your appreciation of the concrete. The backdrop is a wall connecting the house (kind of yellow clinker, the same Mario Botta sometimes used) to a later added outlying concrete garage, thus forming a nice protected patio and outdoor photo spot.
Hi Alan and Meriadoc
An uncoloured but sincere thank you for the flattering feedbacks.
Cheers
Peter
fore topgallant yard and sail
The fore topgallant sail was again a reduced and simplified one as it was to be furled. Similar to previous sails all the lines were attached and then yard and sail hoisted and fixed with tie, lifts, braces and parrel rope. However sometime during that process I found that the main topmast stay was broken. The eye around the mouse had somehow parted. After pondering about repair possibilities I had to admit that the cleanest solution would be to make a new stay. All this promoted of course the use of some creative language...
Fortunately my running rigging's belayings are fixed with diluted white glue which may be dissolved again with some water. The fore bits are quite crowded with rigging but most of the time I was able to untie the correct lines and other times I had to revert again to creative expressions. The new stay was set around the masthead and then threaded through the robands of the topmast staysail and led to the point above the bits, where a new block was spliced into its end. Now after re-belaying a zillion lines I could finish the topgallant yard.
fore topgallant yard with furled sail in place
hoisting the flag
Sometime during all that sail work I also made a flag to hoist at the mizzen gaff. I wanted to have a red ensign with the pattern after 1800, the one Napoleon might have seen, when he was aboard. Trials with an inkjet printer didn't work. It was not possible to print congruently on both sides of the fabric and, worse still, the ink would run with any liquid including something to seal it.
Some patience, textile paint and fiddling with masking tape brought an acceptable result. The flag is hand painted onto the same cotton I use for the sails.
Hoisting it was a bit difficult. Obviously the flag line leads through a block at the gaff but where to belay it at the deck? The kit's plans show a block at deck level with the ends of the flag line seemingly joined into a loop. But no information where on deck that block was positioned. Information in my clever books and the web was also vague about the lower end of flag lines.
As the length of the loop of the line should be adjustable to the position of the gaff I decided to hook the lower block into a free ringbolt at the taffrail, and join the line ends with some spare length coiled and hanging there. I have no idea what the navy way was but that's the best I could come up with my way.
Well, thanks, I'm as fine as I hope you are.
In a way of speaking, the Bellerophon build did interrupt by itself. While struggling to hoist the fore topgallant yard I found the main topmast stay broken - the eye around the mouse parted somehow. I had to make a new stay, to replace the broken one and set up quantities of rigging anew. But I'm on track again and hope to have an update within a few days.
Peter
- Mirabell61, mtaylor, GrandpaPhil and 3 others
- 6
HM Cutter Alert by flyer - Vanguard Models - scale 1:64 - naval cutter
The Naval Cutter Alert by flyer - Vanguard Models - scale 1:64
The next project is another step ahead in kit quality – a Vanguard Models kit. The HMS Vanguard kit itself was also a Chris Watton construction, however with his own line of products I believe he took quality one or several steps further.
Although the kit looks great, there are – fortunately - still possibilities to change it to my liking or even to improve it a bit. For additional information I will count on Peter Goodwin’s ‘The Naval Cutter Alert 1777’, a book of the AOTS series.
My first thoughts are:
The cutter must have a boat. With the kit I ordered Vanguard Model’s 18ft cutter with the intention to shorten it to 14 or 16ft to easier find room on deck. In the meantime, Chris Watton announced that he will soon offer a printed 14ft cutter. I will consider this or – if it is still too large – perhaps commission Caldercraft’s 14ft jolly boat.
Sails will be hoisted. But I will make my own as the kit’s ones are not to my liking.
The rigging layout could be changed to an improved and standardised cutter rigging without spread yard and with spreaders for the shrouds. However, right now, I think the kit’s rigging scheme has its very own charm and is not only confirmed by the contemporary model of the cutter Hawke but also by contemporary paintings of Charles Brooking. Decision to be taken later.
Shipping in Light Airs in the Thames Estuary by Charles Brooking 1723 – 56
