Everything posted by dvm27
ancre Belle Poule 1765 by j.guydal
dvm27 replied to j.guydal's topic in - Build logs for subjects built 1751 - 1800
Your brass work makes a very convincing substitute for the carvings. Bien fait! -
NRG VIRTUAL WORKSHOP - USING THE TABLE SAW
dvm27 replied to kurtvd19's topic in NAUTICAL RESEARCH GUILD - News & Information
Great workshop Kurt. I also suffered saw-finger once and I'm betting those of us it happened to will never let it happen again. A question regarding the Preac zero-inset with blue tape tip - I'm snow birding so don't have access to my saw but isn't the blade very close to the blade elevating screw? I may be wrong but perhaps this violates the 3" rule? -
I certainly agree with Hakan. Those inset molded details on the bitts and cross pieces are fabulous. Do you use a small chisel, scraper or a combination of both?
Thanks, Shipman, for drawing attention to this lovely model. Congratulations to the builder for making a commercial kit into a unique diorama.
- 40 replies
- la tartane
- heller
I agree with Druxey. I have tried ammonia and it did nothing additional but discolor my wood. Currently I use a heat gun (carefully) on wet wood and if you go slowly you can actually feel the lignin fibers relaxing. Also, there is always a degree of spring back so adding an additional 15-20% curve to the formers usually corrects for this.
Such a pleasure to see your work in progress. While I included every detail in my Swan class build as well it is a sad fact that most of your current work will not be visible on the finished model, even with partially planked decks. If I had a do-over I would seriously consider adding LED lighting in some of these areas (such as the lanterns in the light room). I know nothing of these things but it seems very doable at your scale.
Great gratings Siggi. I learned long ago to make the gratings first to insure full borders on all sides. The coamings and head ledges can always be modified a bit to fit.
Well done Rusty, especially when you consider how many variables are involved by the time you get to this area of the ship. That you are so close to spec is a tribute to both your building skills and Chuck's excellent design.
- 642 replies
- winchelsea
- Syren Ship Model Company
Best wishes for a speedy recovery Kevin! Keep away from the sawdust for a few days.
- 1,126 replies
USS Delaware 1817 by threebs
dvm27 replied to threebs's topic in - Build logs for subjects built 1801 - 1850
Where do you keep this impressive fleet? This is the kind of collection that museums would hope for. -
Swan-Class Sloop by Stuglo - FINISHED - 1:48
dvm27 replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
Nice job Stu. You might try using Titebond or carpenters glue mixed with black pigment powder. It doesn’t affect the bonding and leaves a nice clean line after sanding. As with all glue I always clean up with water and a small brush after clamping. Much easier to remove while wet.- 475 replies
NAIAD 1797 by Bitao - 1:60
dvm27 replied to Bitao's topic in - Build logs for subjects built 1751 - 1800
Best Holiday Wishes for you as well, Bitao, and thank you for sharing your exceptional work with us.! Greg
